Old 03-06-2011, 04:40 PM   #57
honda03842's Avatar
Name: Norm and Ginny
New Hampshire
A little more perspective, the per capita auto death rate in most European counties is virtually identical to the United States.
Norm
honda03842 is online now   Reply With Quote
Old 03-07-2011, 06:41 AM   #58
Borden's Avatar
Name: Borden and Carole
Proper safety chains will hold trailer if it is unhitched! Also in Ontario we are required to clip or lock the hitch when pulling to prevent this. Brake away switch would help by applying brakes also helping to prevent problems if wrong chains strength used?
People will over load trailers (utility) see it all the time. Have seen tires over pressurized (common), too soft or wrong type causing additional sway. Have seen a gentleman argue with a tire dealer about what tires are best! Have dropped back from trailer that had the TV unable to steer properly due to tongue load/improper hitch setup for job at hand. Have seen trailer with axle alignment out and tracking to the side excessively.
I may not be an expert but read and ask the experts when needed as we all do. Just went to How to Use an Equalizer Hitch | eHow.com for a refresher on setup while towing ( over 30 years since was shown how ).
At fiberglassrv We are all responsible people and take the time to learn and check our trailers for tire pressure, hitch alignment, brakes, wheel bearings, lights, balance our load and other items each and every time before we tow. Most would not pull at the same speed they drive, personally like to stay off of the 400 type highways enjoy the ride doing 80 kmh/50 mph to 90 kmh/55 mph max.
Example: I would not tow over 500 lbs without trailer brakes even though it is legal personal preference only; we all lean to the safe side when in doubt.
Dangerous Trailers should list condition of TV, trailer, how they had the trailer and car setup. Speed doing 120 kmh or more?
1978 Ontario made Boler
Old 03-07-2011, 07:01 AM   #59
Borden's Avatar
Thumbs up
honda03842 a level head like yours is always needed in a discussion of this type.
Old 03-07-2011, 07:09 AM   #60
Borden's Avatar
P.S. I do set the drop a bit greater at the back of TV when setting up due to general opinion usually about 1/2". (again safe side)
Old 03-07-2011, 12:12 PM   #61
honda03842's Avatar
New Hampshire
Thank you Borden.
First I could remove all credibility by saying I was a politician for 6 years. LOL
Second, after reading about all the accidents where people became "unintentionally unhitched", I will add a breakaway switch to the Casita and Scamp for a little more margin. I was surprised to see they don't have them even though our 1982 lighter Sunline had one.
Is it the norm for Scamps/Casitas not to have a breakaway switch?
Always time to learn,
Norm
Old 03-07-2011, 01:14 PM   #62
The reason Scamp says you don't need them is because they (breakaway switch ) are not required in Minnesota even though it is required in other states.
I took a breakaway switch with me when I picked up my Scamp.
Bill K
Originally Posted by honda03842 View Post
Thank you Borden.
Norm
Old 03-13-2011, 08:19 PM   #63
Roger C H's Avatar
In the report from Wisconsin Highway Patrol, the idiot towing the trailer used a carabiner to attach his safety chains to his truck.
I use a Campbell Chain Clevis Slip Hook
SLIP - CLEVIS HOOKS - CHAIN - CABLE FITTINGS
The trailer came with quick links
ACE QUICK LINK - REPAIR - CONNECTING LINKS
but I got tired of crawling under the car to unscrew them.
Old 03-13-2011, 10:10 PM   #64
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Thumbs up
I'm with you on the clevis hook- I use the one with the safety latch CAMPBELL CHAIN CLEVIS SLIP - SLIP - CLEVIS HOOKS
Did the Wisconsin police report say why the trailer came off the hitch?
So many people don't think to grease or maintain their trailer coupler and hitch ball- did that have anything to do with it?
Old 03-22-2011, 12:57 PM   #65
Borden's Avatar
We are required to latch trailer then add a Coupler Lock, clevis pin or bolt In Ontario Canada. MTO gives chain ratings needed per load in detail. Our chains clip on; same with both trailers. Wonder if trailer had to light of ball or hitch lock broke; maybe clip came off the Class III Pin & Clip, 5/8", groove style receiver pin?
COMBO LOCKS (HITCH & TRAILER) sounding better
The only addition we added was the breakaway switch. The original owner used WD system with sway-bar on the boler. Will consider adding brakes to the smaller trailer even though not a legal requirement. since car has the module and harness.
Old 03-25-2011, 05:39 AM   #66
cpaharley2008's Avatar
Trailer: 2012 Escape 19' with Ram Hemi or FJ Cruiser
Update:
I purchased another tongue box made with plastic vs aluminum and reinstalled the 2 batteries and small propane tank. I reinstalled the spare on the rear and filled my water heater in the rear with water. My tongue weight is down to 310# which is about 30# over factory stock due to the extra battery. Pictures will be posted this pm. I'm a happy camper since the class II hitch on an Outback is rated 300#. Now if I can get the Subaru dealer to drop his price a little.....
Anyone want to purchase an unused aluminum tongue box real cheap?
Old 03-25-2011, 09:04 AM   #67
Yup it is amazing how moving things about can change the tongue weight but keep in mind that although the hitch on the Outback is rated at 300lbs you are still 120lbs or well over 50% of the allowed tongue weight of the Outback itself. It is very normal for the hitch to have a higher rating than the tow itself.
I understand why you really want an Outback :-) I love mine and Im very happy with its towing ablility but I personally would be concerned with possible warrenty and perhaps handling issues if I was towing that much over the tongue limit.
Carol H is online now   Reply With Quote
Old 03-25-2011, 01:13 PM   #68
John as I mentioned earlier I think the difference **may** be that your Dodge is a rear wheel drive (or 4 x 4?) and the Subaru is a All Wheel Drive so they are built with different components and weight distribution in an unloaded state. Obviously in a 2 wheel drive when you put your foot on the gas the weight transfer is to the rear wheels only and on an All Wheel Drive weight is transferred to all 4 wheels. As I understand it a rear wheel drive vehicle is built with a lot more weight at the front in an unloaded condition than an All Wheel Drive vehicle. Its also my understanding that a vehicle that is built as an All Wheel Drive will be a heavier vehicle than the same vehicle if it where built only as a 2 wheel drive due to all the extra parts needed to make it an All Wheel Drive.
To complicate things it appears there are big differences in how the All Wheel Drive vehicles are designed as well. Subaru's system is different from that of Honda and other manufactures or at least it appears to be. How and why is a bit beyond my understanding of cars. ;-) But a while back I found this interesting video which does not actually explain the differences in how the various All Wheel Drives are designed to work but it does show that there is a differences in how they responded to different situations which would suggest they are not all built/designed the same either.
I'm not an engineer but I have a hunch that how we load up an All Wheel Drive may have a bigger impact in regards to traction and its safe drive, than it does on a rear wheel drive. I tend to think that the manufactures know how they are designed, so I’m probable better to go with what they say in regards to weight loading than to go with a general rule of thumb.
In straight line forward accelleration weight transfer is always rearward,... and in braking, weight transfer is always forward.
In limited slip and AWD applications, power[not weight] is transferred to the wheel with with the most traction.
The videos inadvertantly explain why electronic traction control equipped vehicles commonly have a button which allows traction control to be deactivated when stopped or at slow speeds.
Old 03-25-2011, 01:48 PM   #69
Floyd - its all to complicated for me! =:-) So is what you are saying is that the impact of putting more weight on the back end of them wil not impact their tracking/handling ability when accellerating? My understanding was that there a number of different all wheel drive systems out there and that depending on what one is being used the answer to the above may differ. Is that not correct?
I recall that my first Outback had a button on the shift that had to be pushed for it to go into all wheel drive - actually it may have been 4 wheel drive at the time - it was more than a few years ago and a couple of Outback later :-) Last 2 Outbacks have had no button they are always in all wheel drive.
Old 03-25-2011, 03:12 PM   #70
The button to which I was refering was for "electronic traction control", not to engage the drive system. It is an extension of the ABS capability.
Too much tongue weight will definitely have a deleterious effect on both handling and tracking, at all times, especially when accelerating.
Of course it's all a matter of degree.
weight
tongue weight Rob M Towing, Hitching, Axles and Running Gear 10 01-10-2008 06:26 AM
Tongue Weight chemong Problem Solving -- Owners Helping Owners 5 07-04-2006 11:59 PM
Tongue weight Jana J Care and Feeding of Molded Fiberglass Trailers 20 05-31-2006 09:44 AM
Tow Weight/Tongue Weight Legacy Posts Towing, Hitching, Axles and Running Gear 7 11-29-2002 07:49 PM
Tongue Weight Chester Taje General Chat 0 12-31-1969 06:00 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
