Tongue weight - Fiberglass RV
Old 03-01-2011, 07:59 PM   #1
cpaharley2008's Avatar
Tongue weight
I was looking at the new Outback 2.5i with 2700# towing and 200# tw- The tongue weight limit seems low for a 2700 pound trailer.
I got my Sherline scale and measured my Egg today-410# was the tongue weight. My trailer is about 2200# but I have dual 27 batteries up front.
So unless Subaru changes their numbers that leaves the Outback out- it is a nice car with the CVT transmission. I have the salesman verifying the tongue weight limit.
Old 03-01-2011, 08:23 PM   #2
Greg H's Avatar
Trailer: 72 Boler American
Indiana
I'm thinking 410 pounds is pretty heavy, the class III on my dually was only 500 pounds for tongue weight.
Old 03-01-2011, 08:29 PM   #3
I figure 15% of 2200 is 330# plus the extra battery and "stuff" in the tongue storage box on the trailer puts me over the 400#. The box is full so it can only go down!
Old 03-01-2011, 08:55 PM   #4
410lbs on the tongue is getting up there all right! You are very correct that it is way over the limit for the Outback and probable a number of other tows you may be considering.
You do need to keep in mind the Outback is not at all built like a truck or many of the SUV's out there so the 15% rule goes out the window! If I remember correctly Subaru actually suggests something in the 8-10% range.
I keep my tongue at about 10% and the car tows the trailer just fine with that.
Old 03-01-2011, 09:07 PM   #5
The reason for this mental exercise is economics. I have a Dodge Hemi that is overkill for the Egg in towing and I average 15 around town and about the same towing. With gas going up I was looking for something smaller and closer to the Eggcamper's limit and the Outback was offering 30-35 mpg around town and maybe 20-25 towing. My other choices were the Xterra, Toyota FJ, Honda Pilot, Jeep Unlimited- all are 6 cyl and 3500-5000 lbs towing. The Subaru was the least expensive @$24K, FJ was most @ $30K
Old 03-01-2011, 09:23 PM   #6
Trailer: 1980 Burro
The the gas mileage you were hoping to get may be optimistic since the Outback is rated at 22 mpg city and 29 mpg highway when not towing.
Andy B is offline   Reply With Quote
Old 03-01-2011, 10:33 PM   #7
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Is that kind of tongue weight within the design tolerances of the TRAILER??? You don't say how much, if any, propane you're carrying up front- but even without tanks, you've got WAY too much lead on the tongue.
Get rid of whatever power vampires you're dragging along and go down to one battery, or get a bigger tow vehicle.
Old 03-02-2011, 01:25 AM   #8
Borden's Avatar
Name: Borden and Carole
Go to weight distribution hitch and redistribute the load inside trailer
1978 Ontario made Boler
Old 03-02-2011, 05:22 AM   #9
Trailer: Chalet XL for sale. Hoping to get a Snoozy.
I have a Subaru Tribeca which has a 3500 towing weight and came with a towing package, trans cooler, etc. It is 6 cylinder, 3.6 liters. I dont know the tongue weight capacity but I am planning on towing the 16' Scamp with it. The Tribeca is a great car but they are not particularly popular so good deals are easy to get. I had the Forester for years but I think the Tribeca is so much nicer and safer...lots of airbags and traction. The gas mileage is good on the highway, not so good around town. I don't really keep track of mpg but I know when I fill up.
CarolMarie is offline   Reply With Quote
Old 03-02-2011, 05:54 AM   #10
Borden's Avatar
Smile
Subaru is nice TV; weight distribution systems double the tongue weight possible and with a 3500 lb tow rating it is all you could need for most of the light weight fiberglass units.
Old 03-02-2011, 06:00 AM   #11
Borden's Avatar
The 17' boler is listed in the manual as 2372 lbs. total with 2170 lbs. at axle with gear can be maybe 3000 lbs. your 16' scamp should not be more. so you are all set. The boler manual does recommend a Load Equalizing Hitch and scamp may also.
Old 03-02-2011, 06:11 AM   #12
Borden's Avatar
With water tank and propane tanks full and items in front bins ours is about 210 on the tongue. (balanced load) cars are lower to ground than trucks.
The hitch manufacture says to add tongue weight, hitch unit weight and load in trunk and that is the rating of the WD system needed.
250 tongue + 60 hitch unit + empty trunk = 300 lbs total so 400/4000 will work
Old 03-02-2011, 06:18 AM   #13
Borden's Avatar
Weight distribution system distribute part of hte trailers hitch weight toward the front wheels of the Outback and that will give you 200 too 400 lbs less the WD hitch weight 400 - 60 = 340 available, less the amount in trunk. This would make a 400/4000 unit work. But check out a hitch specialist for more detail.
elite units the 400/4000 has a 100 to 400 lb. tongue range and 600/10000 has 200 to 600 range (from site info)
Old 03-02-2011, 06:30 AM   #14
This is why a tongue scale is important. My factory specs listed 240# before options. My Sherline shows 410# loaded. So unless one weighs the trailer, it is all guess work. I'm contacting Subaru to see if the w/d will effect their rating.
weight
tongue weight Rob M Towing, Hitching, Axles and Running Gear 10 01-10-2008 06:26 AM
Tongue Weight chemong Problem Solving | Owners Helping Owners 5 07-04-2006 11:59 PM
Tongue weight Jana J Towing, Hitching, Axles and Running Gear 20 05-31-2006 09:44 AM
Tow Weight/Tongue Weight Legacy Posts Towing, Hitching, Axles and Running Gear 7 11-29-2002 07:49 PM
Tongue Weight Chester Taje General Chat 0 12-31-1969 07:00 PM
