Tongue Weight Issue??? - Fiberglass RV
Old 05-19-2008, 08:08 PM   #1
Trailer: 1976 Boler
I don't like the spare tire mounted directly on the fiberglass body in the back of my 13 ft Boler, so I would like to mount it on the front next to the propane tank. I would have my battery on the other side of the tank also. Does anybody see a problem with there being too much weight up front with this set up? Thanks.
Dave Mc is offline   Reply With Quote
Old 05-19-2008, 10:32 PM   #2
Just curious. It's been on the back for 25 years, is it causing a problem now? Or you just don't like the looks. And yes, you should probably consider packing things just a bit differently inside to keep the weight balanced as before. Although a tire/wheel doesn't weigh all that much in the grand scheme of things.
Old 05-20-2008, 06:45 PM   #3
Pete Dumbleton's Avatar
Unless your tow vehicle has severe TW limitations, moving the spare to the front will likely make a better tow (any weight as far back as it can get from the axle is a sway contributor). Try it with some U-bolts on side or underneath.
As Donna says, however, it's been there for a while and not causing problems...
Old 05-20-2008, 08:45 PM   #4
Trailer: 1976 Boler
I think it was leaking through the holes where the tire was attached as I found some water damage underneath. I would also like to put a small storage rack on the back onto a hitch sleeve for a little extra storage space.
weighing, weight
Weight Issue Clark Martin Problem Solving | Owners Helping Owners 22 04-27-2010 11:34 PM
tongue weight Rob M Towing, Hitching, Axles and Running Gear 10 01-10-2008 06:26 AM
Tongue Weight chemong Problem Solving | Owners Helping Owners 5 07-04-2006 11:59 PM
Tongue weight Jana J Towing, Hitching, Axles and Running Gear 20 05-31-2006 09:44 AM
Tongue Weight Chester Taje General Chat 0 12-31-1969 07:00 PM
