Tongue weight problem - Fiberglass RV
Old 08-01-2015, 06:45 PM   #1
Ellpea in CA's Avatar
Well, I suppose this is never easy.
LilBea weighed 1300 even, on the nose on the way home. Which works out great for the Volvo, which will tow a 3300 lb trailer *with* brakes (all details on Volvo below). But she's only supposed to have a 165lb tongue weight, and LilBea just weighed 220!
http://www.fiberglassrv.com/forums/m...icture9043.jpg
Bea has a 2" hitch, and Volvo factory receiver (still waiting for this to be installed) is class II and has 2" drawbar, so that all lines up. She has the battery and propane tank on the front. The battery weighs around 25lbs probably. Not sure yet about the LP, or how much gas is in there.
http://www.fiberglassrv.com/forums/m...icture9052.jpg
I hate to think we would have to move the battery and tank to travel (plus we couldn't recharge battery...) but are there any other options? Bea has front dinette and a porta potty under one front cabinet (not an absolute necessity), but there is no heavy stuff stashed up front.
Any thoughts?
Ellpea
(grinding teeth)
Deets on the V70:
GVW 4690 lbs
Curb weight 3380-3595 lbs
Permissible axle weight, front 2330 lbs
Permissible axle weight, rear 2470 lbs
Max trailer weight w/o brakes 1100 lbs
Max trailer weight w/brakes 3300 lbs
Max tongue weight 165 lbs
Ellpea in CA
1988 13.5' Lil Bigfoot
2002 Volvo V70 (turbocharged)
5 cylinders, 5 speed auto transmission
Ellpea in CA is offline   Reply With Quote
Old 08-01-2015, 07:01 PM   #2
Our Lil Bigfoot tongue weight managed to stay well under 200 lbs fully packed.
There's a couple of way to help your tongue weight problem:
When you start packing stuff in be sure to minimize what goes in front under the front seats & dinette. Save that space for light things like clothing, bedding and linens. Or better yet, don't use it at all.
The Biggie: Have the battery relocated to the left under bed seat, just aft of the sink counter. It doesn't need much rewiring because the wire from the battery already goes there. That will take weight off the front as well as put some slightly behind the axle. That's about 50 lbs.
Your bedding, Flat screen TV and what ever stuff you put in the rear over bed cabinet will also help. We even added shelves over the side windows with more stuff. And a 1/2 full water tank will also help.
But moving the battery helps a lot. Wait until you get it packed and ready before you get frustrated on the tongue weight.
Old 08-01-2015, 07:03 PM   #3
Move some stuff inside the egg to the back. Do you have a fresh water tank? If it is in back filling it up will help. If it is ahead of the wheels towards the front, empty it.
Old 08-01-2015, 07:08 PM   #4
There is a water tank under the back dinette, and it's currently empty...
So 1/2 tank of water and moving the battery might solve this problem????
Ellpea in CA
Old 08-01-2015, 07:45 PM   #5
It might.. and it might create another problem.
You are not going to like this reply.. it gets a little complicated. If, in your attempt to get the tongue weight under the limit for your tow vehicle, you get it too low (i.e. somewhere below 10% of the total trailer weight), then you might have problems with sway or the like. It could cause a wreck.
IMHO, in general, you should not go below 10% of the total trailer weight on the tongue.. and if that amount is over the tongue weight limit of your tow vehicle, then you need either another tow vehicle or a way to increase the limit on your current tow vehicle (such as WDH or air bags in the rear springs). Your dealer should be consulted in this case.
Old 08-01-2015, 07:48 PM   #6
Weight transfer
It will all help. But the battery is the big one and it is very easy to do. All of that extra tank cover stuff may also add a few unnecessary
lbs on the front.
I think that the front jack on yours also removes with a simple clamp. I take the one off of my Hunter for clearance reasons, 3 nuts and 3 minutes, it weighs about 6-8 lbs.
Old 08-01-2015, 07:59 PM   #7
Trailer: trailswest campsterl, 1996 Scamp 16 foot
Idaho
Volvo towing
IMHO Gordon is on the right track at trailer weight of 3300 lbs and tongue weight at 220 you are already deep into trailer sway territory. Decreasing the tongue weight to 165 is a disaster looking for a place to happen. Maybe there is a mistake in the 165 lb tongue weight limit ? I can't imagine a trailer weight limit at 3300lbs with a 165 tongue weight. Lee
Lee Senn is offline   Reply With Quote
Old 08-01-2015, 08:07 PM   #8
Ian G.'s Avatar
I agree with Bob, the battery will easily weight between 50-65 lbs, relocating it will be the easiest way to balance the tongue weight
Ian G. is online now   Reply With Quote
Old 08-01-2015, 08:14 PM   #9
Ell[peas Lil'Bigfoot trailer currently weighs 1300 lbs. empty and dry. The 3300 lb figure is the towing limit for the XC-70 TV.
Ellpea can add up to 300 lbs and still have a 165 lb tongue weight at 10% of total weight.
The Lil Bigfoot's water tank is right against the back edge of the wheel well and adding water for ballast will not create that Polar Rotation Moment issue so may know and love.
And we have done the dance on XC-70's towing specs. twice in the past 2 weeks. It is what it is, no mistakes, misprints or conspiracies to sell pick-up trucks involved.
Old 08-01-2015, 08:14 PM   #10
honda03842's Avatar
Name: Norm and Ginny
Things that can help.
How many inches does the tow vehicle drop when the tongue is put on the ball?
The effect of the tongue on the tow vehicles springs can be reduced a little by pushing the ball support in beyond it's normal pin position and drilling a new hole for the ball support pin. The goal is to get tongue weight as close as possible to the tow vehicles rear axle.
I marked the ball support and brought it to the local welding garage and they drilled the hole for $5.
What are your tow vehicle tire pressures? What is normal for your tow vehicle.
Where did you measure the weight of the tongue? Was it at the location of the ball?
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 08-01-2015, 08:15 PM   #11
There have been endless discussions on this regarding Volvos. I don't know WHY they have these restrictions, but this one does. 165 lbs, no mistake.
Will be careful about overloading the rear. We're getting a good brake setup, and the hubby has around 50 years of towing experience... race cars and boats, and various 18 wheel set-ups. This is the first RV.
Ellpea in CA
Old 08-01-2015, 08:18 PM   #12
There is a good discussion on Volvo tongue weight here. Max Tongue Weight for Hitch
Ziggy is offline   Reply With Quote
Old 08-01-2015, 08:19 PM   #13
Bob, just a reminder, mine is a V70, not a XC70 (cross country model). The XC is *slightly* more beefy than mine.
Norm, can't yet answer your question, the receiver has not yet been installed. Can guarantee the tire pressure on tow vehicle will be perfect, hubby is just that way...
Ellpea in CA
Old 08-01-2015, 08:33 PM   #14
Well then it seems there is little more to say.. except.. err on the side of too much tongue weight rather than too little. Too much might cause your TV to bottom out, or wear out the suspension components sooner. But too little could make your trailer sway or disconnect from the TV resulting in the loss of the trailer, tow vehicle, and more. Always stack the odds in your favor.
I would love to know what your husband thinks of this discussion.. it might be: "well, duh!". LOL
weight
Eggcamper Weight, Tongue Weight & Towing with Outback coastsignal Towing, Hitching, Axles and Running Gear 108 10-01-2015 07:20 PM
is my weight distribution hitch worth the tongue weight and effort. beachcamper54 Towing, Hitching, Axles and Running Gear 24 01-25-2014 11:41 AM
Tongue weight or hitch weight Cathi Towing, Hitching, Axles and Running Gear 26 04-23-2012 11:38 PM
Tongue Weight Legacy Posts Problem Solving | Owners Helping Owners 1 06-09-2003 12:58 PM
Tow Weight/Tongue Weight Legacy Posts Towing, Hitching, Axles and Running Gear 7 11-29-2002 07:49 PM
