Tongue Weights - Page 3 - Fiberglass RV
Old 08-25-2012, 04:24 PM   #29
[QUOTE=honda03842;328392]
As you can calculate, we are typically in the 8% tongue range. We have never experienced sway.
/QUOTE]
hummm correct me if I am wrong Norm but I could have sworn that you have an anti sway bar on your hitch. I would be really worried if it was to manage to sway with one of those on it.
Old 08-25-2012, 07:03 PM   #30
honda03842's Avatar
Name: Norm and Ginny
Hi Carol,
I know you can get sway even with an anti-sway bar. No one should ever think that because they've added an anti-sway bar that they're free of a sway situation.
Every day when I start up in the morning I reach for the brake controller's trailer brake activiation switch and activate the trailer's brakes to test them and to reinforce that should I get sway, that I can stop it by activating the trailer's brakes.
I do have an anti-sway bar on the Scamp 16 however I've towed our Scamp 16 about 2000 miles without an anti-sway bar and towed a Casita 16 about 4000 miles without an anti-sway bar. In both cases I have never seen sway and in both cases I had well less than a 10% tongue weight.
As to the anti-sway bar, before we ever towed I investigated whether I should purchase an anti-sway bar. The reponse was you'll probably never need it but in an emergency it's nice to have. Since it was only about $50 and easy to install I bought one.
We have had two emergencies, neither related to sway. I've published the second on this site where our trailer's receiver hopped off the ball due to a receiver modification by a previous owner. In that case the anti-sway bar held it all together.
The first situation was a full bore emergency stop, the worst of my life, where an extend cab truck pulled across the highway blocking both lanes forcing an emergency stop from 55 mph, smoking tires and all. The trailer stayed perfectly in line with the Honda. Did the anti-sway bar do anything in this situation? I don't know but I was glad every thing stayed together as it should.
It's quite clear that the Scamp tracks very well. It has never moved from side to side at all with or without the anti-sway bar. I make no secret of the existance of the bar and have mentioned it many times on the site.
I will also say that load distribution is important. We had an earlier non-fiberglass trailer where we mounted a small generator on the rear bumper. We had an anti-sway bar on that trailer, yet it swayed in the first 10 miles, enough so I stopped and pulled over and moved the generator inside. Obviously balance matters with or without an anti-sway bar. I think part of the Bailey testing mentioned in an earlier post shows that weight distribution is important.
When someones sends me a PM asking about towing with our CRV, I send them a 3 page document where I state we tow with an anti-sway bar and as well that we've towed without an anti-sway bar. I try to take this subject seriously and be totally open because some people are suspicious of our Honda CRV and our towing methods. After 5 years of towing all over the continent with our Honda CRV I am very happy with the results and more than willing to share what we've learned, just PM me if you want a copy.
I considered posting this document on Towing with a Honda CRV on the site but have refrained because too many people get their dander up over our towing style. Some are concerned about our potential liability, some think I'm a danger to others.
The reality is that we're very careful and conservative people, checking and rechecking our tow vehicle and trailer almost daily. We've even gone so far as to install pressure sensors on our tires to know what the tires are doing. We're careful but more importantly our Honda has done the job without a single drive line repair in 8 years, 5 years of extensive towing. We're now into our 284th day on the road this year. No one has tooted at us because we're too slow or too fast, even on the many long and high passes we've crossed. We're happy with our Honda. We only wish Honda's marketing department would give us the same ratings they give the Europeans. More so we wish they would import their 4 cylinder diesel. Then we could do well better than 23 mpg.
Safe Travels,
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 08-25-2012, 11:54 PM   #31
Sorry Norm you seem to have gotten side tracked. I wasn't questioning your choose of car or trailer combo. This thread is in regards to tongue weights as was my question.
The reason for my question was I felt the OP who may be new to towing should know that IMHO a very important piece of information was missing from your post in regards to your practise of towing with a 8% tongue weight. As you went to the expense of purchasing and installing a sway bar you obviously felt it was a worth while investment with your set up. Its a piece of equipment that I think you will agree will have a pretty big impact on how frequently or infrequent you find yourself with a sway with such a light tongue weight.
As you know I tow the same make and model and vintage trailer as yourself & actually manged to towed 12,000 miles last year without a sway bar and without any sway issues. But I know very well that under certain circumstances I could very easily get my trailer to sway especially with an 8% tongue weight. Bottom line is sending someone out who is new to towing with an 8% tongue weight IMHO its a recipe for a disaster, especially when one considers the party may not know under what circumstances a sway is likely to occur or even know what to do or not do if the trailer does start to sway
As indicated its just MHO.
Old 08-26-2012, 06:59 AM   #32
cpaharley2008's Avatar
I believe Norm's trailer came equipped with the sway from prior owner and Norm utilizes it. Whether or not he has some sway can not be determined. But proper weight on the tongue should help alleviate sway. Thus any newcomer should be aware of following the trailer manufacturer's recommendations. I think it is better to have the trailer handle sway in lieu of the sway control constantly fighting to keep things straight. I have seen dual sway setups and I wonder why someone would want to tow knowing the unit had an issue with swaying so much. I once owned a trailer for less than 6 months because of it's horrible sway which I could not alleviate no matter what I did.
Old 08-26-2012, 07:57 AM   #33
In my experience, sway is a result of inadequate tongue weight and the "Tail wags the dog". Years ago a friend of mine somehow thought that less tongue weight was better and loaded up the back of an 18' ski boat on a trailer to almost zero out tongue weight, a really bad idea.
He hit his brakes going down a steep grade on I-90 in WA and the trailer started whipping around and, before he thought to accelerate or try manual trailer brakes to stop things, they were off the road and the trailer was on it's side, having twisted the entire front part of the frame into a pretzel and the boat was damaged beyond repair. Fortunately no injuries, but lots of pants needed changing.
That said, I carry a $5 flea market scale and try to stick with about 15% tongue weight, it do make a difference.
Old 08-26-2012, 08:36 AM   #34
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
For engineers and wonks, I found this excellent analysis of tongue weight and trailer sway on another forum. See postings by Ron Gratz
Don't ask me to explain it.
RV.Net Open Roads Forum: Travel Trailers: Towing stability physics
Old 08-26-2012, 08:38 AM   #35
honda03842's Avatar
Difficult to Explain
1. I've towed 3 trailers, a 15.5 foot stick built Sunline, a 16 foot Casita and a 16 foot Scamp.
2, Each trailer had tongue weights in the 8-9% range. My intention is to keep the tongue weight at or below 220 lbs, the Honda's limit.
3. None of these trailers had anti-sway bars when purchased.
4. Initially I towed all these trailers without anti-sway bars. The Casita and Scamp were towed for 1,000s of miles without anti-sway bars. Sway was never experienced.
5. I installed an anti-sway bar on the Sunline. It swayed once with the anti-sway bar in place when I put a small generator on the rear bumper. The anti-sway bar did not stop the sway; I stopped it by hitting the trailer brakes (note not the Honda's brakes) and eleminated the sway by moving the generator to over the trailer axle.
6. I added a anti-sway bar to both the Sunline and Scamp, not to prevent sway though I'm sure it would help with sway, but rather for emergencies. The Casita was never towed with an anti-sway bar.
6. My opinion after 2 non-sway emergencies is that an anti-sway bar is very inexpensive insurance.
7. I am not suggesting what others should do but rather stating what works for me. Simply sharing information.
The only thing that bothers me about 10 to 15% is that people state it but never seem to be able to explain why it's necessary.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 08-26-2012, 09:58 AM   #36
I don't think that the physics of the question are as important as the results.
As Norm pointed out, placing a generator on the back of his trailer (thus reducing tongue weight or, more correctly, front to rear trailer balance) contributed to sway, and moving it forward fixed the problem. Again, the tail wags the dog.
Not mentioned is the probabilty that vehicles with front wheel drive may be more prone to sway issues simply because the point of "pull" is further away from the pivoting center of the trailer, as well as FWD vehicles have a higher ratio of vehicle weight on the front wheels and less on the back.
I know when I pull either of our trailers with our 4 cylinder Sonoma pick-up rather than with our 2009 Honda CRV, it seems that the trailer has less control over tow vehicle.
Old 08-26-2012, 10:05 AM   #37
Thomas G.'s Avatar
I have a hunch that the two are not separable.
Old 08-26-2012, 10:26 AM   #38
What with all of the formulae offered in the link explaining trailer sway, maybe I should have said:
"I don't think that "understanding" the physics of the question are as important as the results. "
If I drop a bowling ball on my foot, I don't need to know why it hurts more than a tennis ball.
Old 08-26-2012, 11:12 AM   #39
Thomas G.'s Avatar
I'm not sure. Could you post a video of you dropping a bowling ball on your foot?
But seriously, getting the "it isn't the tongue weight, it is the lateral forces due to angular momentum of the trailer" part keeps you from adding large weights to the ends of the trailer.
Old 08-26-2012, 11:35 AM   #40
Want's Pain Pics?
Actually I had to give up bowling from frustration after blowing my very first 300 game, (in the second frame). After that it was all down hill.....
And... It's the trailers transrotational nexxus value, when added to the angle of the hitch dangle, divided by the current phase of the moon that determines actual sway pressure when measured as inverse momograms. Needless to say, this makes it much safer to drive in a full moon when the pressure value will be the inverse of 1.
Old 08-26-2012, 12:16 PM   #41
Tom, Mr. Gratz's explanation is actually a pretty good/clear one. I know its hard to believe but its a lot clearer than many of the text books and instructors I had to try and understand in order to obtain my professional designation ;-) Just thinking about it brings back bad memories about the time spent trying to come up with a clear understanding of all that gibberish! :-))
Unfortunately it was a necessary evil in my profession as the numbers needed to calculate stability changed daily sometimes hourly and people lives were at risk if I got it wrong. Sadly most of us when we first start towing don't know much if anything about the basics of stability and those who have been here awhile know all to well that it can result in someones vacation coming to a grinding halt in a bad way and a brand new fiberglass trailer being written off all to fast.
Weights and distant are an important part of the calculations of just how stable a tow may be but there are many other forces that will impact it. Speed and grade are two big factors. IMHO speed is one of the big reasons we see a difference in the common tongue weight recommendations quoted in Europe vs North America. It might surprise some to know that even on the German autobahn - which I suspect many think of as the highway of speed that passenger trucks and cars pulling trailers are limed to 80 KPH/50MPH.
As most here are aware the speed limits found in much of mid USA are 75 MPH and in Montana 80 MPH. There will be a big difference in the stability of a trailer that is being towed at 50 mph vs 70 mph and not in a good way. Another influence as has also been pointed out is grade. A quick way to determine if your trailer set up is as good as you think it is would be to wind it up to 75 or 80 mph and head on down a long down hill run - I am not suggesting that anyone actually try! Especially those who do not have lots of experience and know what to do and how to do it correct should the trailer start to sway. I have mentioned it only as an example.
One of the upsides of my profession was it allowed me to spend time in Europe at the company's expense & I honestly dont recall seeing any swaying trailers during my time in various European counties - even while on the autobahn. I have seen more than I would like on the highways in NA though. I was almost taken out by a swaying trailer passing by me in the left hand lane on the I5 this summer while heading to the Bandon meet. IMHO speed was a big factor in that trailers sway issue combined with what appeared to me to be a light tongue weight. As a result of our close encounter the person towing the swaying trailer dropped his speed way down & slowly faded away in my rear view mirror - suspect he scared himself as badly as he scared me!
The sharing of information and experiences on this list is the GREAT thing about it. But as I indicated early its MHO that its equally as important that when we share our experiences we take into consideration the experience or lack of experience of the people we may be sharing our experiences with.
I believe it was Alexander Pope who said:
A little learning is a dangerous thing;
drink deep, or taste not the Pierian spring:
there shallow draughts intoxicate the brain,
and drinking largely sobers us again.
or at least some think thats what he said!
Old 08-26-2012, 01:35 PM   #42
All of this technical stuff is giving me a headache, I either need some aspirin or
Trailer Weights Listing Pam Garlow Forum Admin, News & Announcements 1 05-04-2012 06:09 PM
16' Casita v. 16' Scamp Weights CarolMarie Problem Solving | Owners Helping Owners 6 01-14-2011 10:15 AM
Trailer weights Rich Morrison Towing, Hitching, Axles and Running Gear 20 11-03-2010 08:37 PM
Trailer Weights...What are They Really? Pamela H Care and Feeding of Molded Fiberglass Trailers 55 12-01-2009 01:21 PM
Need 1977 Surfside 14' Weights Raunie Aasland Problem Solving | Owners Helping Owners 2 04-24-2006 07:12 AM
