Too crazy or good fun? Legacy pulling 13ft'er across country - Page 8 - Fiberglass RV
Old 11-25-2012, 06:50 AM   #99
SilverGhost's Avatar
Trailer: Egg Camper
Originally Posted by Mike Magee
Personally, I would not hesitate to tow a 13er with a Subaru. I would think about air bags for the rear suspension, though... pump them up when towing to stiffen the suspension, let air out when commuting.
The Toyota Rav4 is another great vehicle for towing a 13. With the V6, you'd have way more power than the Subaru.
A Tacoma won't handle much more than an empty camper shell on it. Anything more will be too heavy. Four Wheel Campers makes a stripped popup camper that's about 1100 lbs IIRC, and that's empty inside! But the Taco could tow, too.
Good luck with your shopping.
My dad had a 4wheel camper on his Frontier. It was pretty well equipped for its size and the Nissan handled it fine. But you are limited by the size of the truck bed.
Jason
SilverGhost is offline   Reply With Quote
Old 12-08-2012, 06:09 PM   #100
Trailer: In the Market
Connecticut
Well...I'm still going the Subaru route! Decided it would be a better choice. Not sure when I will pick up a camper, but it seems like the best all around option. Thank you everyone
Zealous Interiors is offline   Reply With Quote
Old 12-08-2012, 06:50 PM   #101
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I think you made a wise decision- most practical daily driver comes first, in my opinion.
And after all this hashing over, I'll bet you've got a MUCH better idea as to what to look for in a trailer!
Good luck, and keep us posted...
Francesca
Old 12-08-2012, 08:36 PM   #102
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Cool, keep us updated. I think you'll find it solid to tow with, I'm curious how the power is.
Old 12-24-2012, 04:56 PM   #103
Marv Watson's Avatar
Trailer: 1978 Trillium 13 ft
Great Lakes area-US
Thought you might like my take on using a Subaru Outback (2006 2.5i) to pull a 13’ ft fgrv (1978 Trillium). We bought the Subaru new in 2006. We bought the Trillium in Sept. 2008 on a whim. Didn’t know much at all about fgrv’s - had seen a couple over the years while tent camping. We didn’t even think about whether the Subaru could pull it safely or not. I didn’t read up on it (owner’s manual, internet until after I had towed it 50 miles home - live on the edge!)
We put electric brakes and new tires on the Trillium and by the middle of Oct. we were in Albuquerque NM! Left it there with relatives, drove back to Michigan. Went back out in Feb., hooked it up and “prowled” our way home over the next 5 weeks via TX, LA and points north.
Since then we’ve pulled the trailer at least 20,000 miles - the latest from Michigan to Cape Breton, Nova Scotia through Canada, return via the States from Maine. The Subaru loves it! No problems. And, since we replaced the axle last spring, it pulls even better, with a slight improvement in gas mileage (19.5 mpg).
I drive at 59 mph, but the Subaru will accelerate nicely up to 70 when needed to jockey around on Interstates in tough traffic situations. We’ve been over 8,000 ft altitude several times. On steeper mountain grades, speeds slow to under 40. I use the “Sport Shift” feature mostly, but under ideal conditions I can leave it in Drive with cruise engaged.
Hope this testimonial is beneficial to you.
Marv Watson is offline   Reply With Quote
Old 12-26-2012, 11:11 AM   #104
Nothing like the ('nother!) voice of experience!
Glad you posted, Marv- too many times real experience gets drowned out by the "gotta-have-a-pickup" crowd...
Francesca, also a Heretic
Old 12-26-2012, 02:28 PM   #105
MC1
MC1's Avatar
With 3.5 engines in full size pick ups towing 10,000lbs the 2.5 in your Sub towing 2,000 lbs seems very reasonable. Glad it's working out.
Old 12-26-2012, 04:03 PM   #106
Brian B-P's Avatar
Comparison of the two engine sizes is irrelevant - that one 3.5 L Ford engine towing 3500 pounds is a turbocharged and direct-injected engine installed in a truck; it is equipped with a suitable cooling system for high loads, and a transmission suitable for the job. It has no relationship to the normally aspirated engine and car transmission in the Subaru, any more than the truck chassis is relevant to the compact station wagon chassis.
The Subaru Outback 2.5i might be entirely suitable for towing 2000 pounds, but not because a Ford F-150 EcoBoost 3.5 can tow 10,000 pounds.
Old 12-26-2012, 04:53 PM   #107
Never mind, "W"...( "Dubya" ?)
Though admittedly a bit obscure, I for one got the ironical tone of your post...
Francesca
Old 12-26-2012, 05:30 PM   #108
Mike Magee's Avatar
Trailer: Li'l Hauley
I'm surprised that it seems no one here has a Subaru Tribeca. V6 and 3500 lb tow rating. Seems like a great choice for Subie lovers.
How to prepare Tofu
Step 2: grill some meat
Old 12-27-2012, 05:22 AM   #109
Trailer: Egg Camper
Point of fact - H6 not V6. Same engine as in top of the line Outback, at least it was when they first started building them.
Jason
Old 12-27-2012, 06:55 AM   #110
MC1
MC1's Avatar
Irrelevant????? Give us all a break. Both are gas engines that produce HP/TQ and are in vehicles that come with a tow rating.
Next you will be telling us it is irrelevant to compare......
Fords and Chevy's
Manual and auto trannys
Imports and domestics
Etc. etc, etc.
Re the restrictions......I get bored just thinking about it! LOL
Old 12-27-2012, 11:24 AM   #111
You forgot "apples and oranges"...
Francesca
Old 12-27-2012, 01:21 PM   #112
Brian B-P's Avatar
Yes, irrelevant... or
  • a 3.5 L F-150 towing 10,000 lb indicates that a 7.0 L Z06 Corvette can tow 20,000 lb, and
  • my 2.0 L Focus with a tow rating of only 1000 lb indicates that a 14 L big rig should only tow 7000 lb (rather than the usual 60,000 lb).
Safe and reliable towing capacity has little to do with the engine's displacement, power, or torque output, and even less to do with the type of fuel used.
It looks like Francesca got the point
Crazy good weather... sfoss General Chat 13 04-08-2012 08:15 PM
Pulling Power Mary Ann in MN General Chat 18 04-19-2011 08:24 PM
Casitas and Fun in the Texas Hill Country brian m. Camping, Campout Reports 0 04-09-2008 07:34 PM
Good clean fun.... Gina D. Jokes, Stories & Tall Tales 4 10-22-2007 08:01 AM
Casitas and Fun in the Texas Hill Country brian m. General Chat 0 12-31-1969 07:00 PM
