Torsion arm angle - Fiberglass RV
Old 03-07-2010, 08:52 PM   #1
Trailer: 1975 Boler
I'm doing a little preventative work on my boler. I did have a crack so I thought may as well do a frame off work over. Other than the crack the frame is in great shape. The axle is 35 years old and that bothers me. It still has bounce and their is no signs of the tire rub. My question is....Is the anle of my torsion arm close to original, at original, or no where near original? Please let me know what you think.
Roy Kleiner is offline   Reply With Quote
Old 03-07-2010, 08:57 PM   #2
Trailer: Scamp 13 ft
Original is 0 degrees (parallel with the frame) unloaded. Yours looks about the same as mine on my 77 Scamp. It was rubbing on one side. I'll be replacing my axle during my restoration.
ReilleyS is offline   Reply With Quote
Old 03-08-2010, 06:40 AM   #3
Trailer: 1975 Boler
Thanks for the reply. Time for a new axle.
Old 03-08-2010, 09:25 PM   #4
FRANK MOLIS's Avatar
Trailer: 1980 (Circa) 13 ft Scamp (A WORK IN PROGRESS)
A crack in the frame may be due to a bad axle. If the axle has no bounce left, all the bumps in the road go directly to the frame. I just replaced my 1970's somethings 13 ft Scamp axle and used the Dexter 22.5 degree down axle which Scamp shows to use per: http://scamptrailers.com/Portals/0/S...nersManual.pdf on page 7 of 16. It worked out great.
My frame was also cracked due to the bad axle that was replaced. Bolers may however have a different start angle. If your trailer seems to be riding low to the ground, thats another good indication your axle is shot. I gained several inches of clearance after changing mine.
FRANK MOLIS is offline   Reply With Quote
What a torsion axle should not look like John and Jaci Care and Feeding of Molded Fiberglass Trailers 16 05-07-2010 01:19 AM
Trailer Axle 3500lb Torsion Kevin K Classified Archives 0 08-08-2009 06:53 AM
Torsion Axle Lifespan David Schroeder Towing, Hitching, Axles and Running Gear 14 01-25-2007 04:25 PM
torsion axle lifetime? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 17 07-10-2003 07:46 PM
Angle of axle Dinver M Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
