Tow Casita 17' with 4Runner V6 - Fiberglass RV
Old 07-20-2007, 04:33 PM   #1
Hello All,
I'm new, just joined up. Seems like a happy crowd.
I'd really like to know who's happy towing a 17' Casita with a V6 4Runner...and who's not! And why, of course. I'm about to plunk down my money for a new Casita, and would like to use my 4R as tow vehicle.
Any advice offered is welcome and I will consider it carefully.
Thank you,
Steve Seitel
Steve Seitel is offline   Reply With Quote
Old 07-20-2007, 06:15 PM   #2
Trailer: 84 16 ft Scamp
My brother-in-law has a V6 4Runner, but the only trailer he's towed is a tent trailer that he rented or borrowed. It was fine for that. He lives in So. CA. and towed out to the coast.
I notice you hail from Montana. You would be at a lot higher elevation, so the satisfaction of someone towing at sea level might be more than a little greater than someone in your area.
Normally the standard advice is to choose your trailer first, then select a tow vehicle.
On the other hand, 4Runners are quite highly regarded, so they bring a good return on the used or trade-in market. So if it doesn't perform to your desires, you won't have a problem trading up.
So my advice would be to give it a try.
Loren
Old 07-20-2007, 09:39 PM   #3
Administrator
Mary F's Avatar
Hi, Steve. I know of at least one person who tows (or towed, she doesn't post often here anymore) a Casita 17 with a 4Runner.
Try our Search function (search All Forums for "4Runner" without a space or hyphen), and set it to show the results "as posts" -- there are a couple of good discussions about choosing tow vehicles. (One discussion is about tows for the 17.5 ft Bigfoot, which is a slightly heavier trailer than the Casita, I think.)
Anyway, you should be able to find some useful comments, while you're waiting for somebody with more current info to come along and share this week's opinion.
Oh yeah, welcome to FiberglassRV.com!
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 07-21-2007, 09:09 AM   #4
can't tell you about a new '17, but we have a used 90's 16' liberty with furnace, frig, shower, etc, and towed it home fine with our 99 runner V6 4x4.
the casita towed closer to the vehicle than my utility trailer (or at least it appeared to in the mirror).
no sway, a little high in the brake pedal on stops, so we're going to look into a brake controller. 4runner brakes stink anyway on the 3rd Gen runners.
Gas mileage wasn't really effected more than a few miles per gal. We didn't clock it, but with the a/c and cruising 65 didn't see much gas loss.
If the tach went above 2.5 I'd hit the OD button for a little climb power on hills. Flipped it off downhill and straightaways. Didn't need ECT. That just caused drag on the transmission. Shutting off OD and ECT would drop the tach down to 2.5
We're very pleased with the tow handling of our runner (w/126k miles) and the casita. We haven't had the trailer weighed yet, but the runner really only knew it was there when starting out. You can 'feel' something is heavy and then remember, oh yeah I have a trailer attached
the footprint behind the runner is almost a perfect match. It's actually not as wide as my 8x5 utility trailer w/fenders, so it was a joy to tow.
hope this helps.
tracy.c is offline   Reply With Quote
Old 07-21-2007, 01:29 PM   #5
Pete Dumbleton's Avatar
Besides getting advice from folks who are doing it (there can be drawbacks to that; the other folks may just have not had a problem yet, or may have different equipment, or as pointed out, may be towing on the flats in mild weather), I'm going to give some generic advice.
Towing is a tripod of pulling, controlling and stopping -- Newbies often see only the first, but a V8 on a motorcycle is not a good trailer-towing choice...
1. Research on this group how much your intended trailer is likely to weigh; if you can't find that, then the next best 'paper' number is the GVWR of the trailer (unless the trailer manf is **known** to have a lot of cargo capacity built in). Nothing is ever quite as good as actual scale numbers from YOUR trailer, as you have loaded it for a trip, but you don't have it yet...
2. Look in the Owner's Manual for YOUR vehicle as equipped for the trailer towing capability and compare it to #1 above. It's best to have the tow capability about 20-25% higher than the trailer's wet and loaded weight.
Many things affect towing besides the engine: Transmission, rear end ratio, engine and transmission cooling, suspension, wheelbase, frame design, electrical system, brakes, etc.
Please bear in mind that tow ratings are usually set at sea level in moderate temperatures and terrain. Ford OMs state that tow capacity should be reduced by 2% for every 1,000' of altitude, plus power will drop and tranmission temps will go up in high ambient temperatures.
Old 07-21-2007, 05:10 PM   #6
Brian B-P's Avatar
One of the reasons why I didn't get a 17' Casita is that it has a very high tongue weight for its size; since I was limited in hitch weight capacity, it was out. The 17' typically seems to have much higher tongue weight than the 16'. This may be a concern with the 4Runner, which is a typical mid-size SUV, in that its wheelbase is short compared to minivans and "full size" trucks and SUV - short wheelbase and high hitch weight are an unfortunate combination.
Pete is right about checking the specific vehicle capacities. A V-8 4Runner would have the drivetrain to handle two Casitas, and even the V-6 should be fine... but the manual and a calculator will provide the real story.
Old 07-21-2007, 05:13 PM   #7
Hello again...
To all who took time to offer advice, thank you! And thanks for the nice welcome.
I had worked through all the weights and ratings for my 4R, loaded. On paper it does have excess capacity to tow the Casita optioned and loaded without exceeding GCWR, either vehicles GVWR, or the 4R's GAWR's and tow and hitch limits (including hitch weight). So on paper it looks okay.
But I know figures on paper are no substitute for the experience of those who have tried it, and so I am grateful to you for sharing those experiences and advice. With your indulgence, I'll be asking more questions from time to time, I'm sure.
Steve Seitel
P.S. Brian B-P...would you explain a little more about why a heavier hitch load and short WB is a bad combination? Thanks
Old 07-21-2007, 06:41 PM   #8
Brian B-P's Avatar
The weight of the trailer on the hitch uses the truck like a lever (such as a child's see-saw or teeter-totter) to lift the front, pivoting on the rear axle. The longer the wheelbase, relative to the rear overhang, the less of this effect there is. There are a few consequences of the load transfer caused by this lever effect, including (but not limited to) high rear axle load and some lift of the front possibly affecting alignment and causing a nose-up attitude (just annoying, or a headlight aim problem). The work-around to this effect is the weight-distributing (WD) hitch, which adds weight and complexity which would be unnecessary if there were less front-to-rear load transfer.
Even with the axle loads "fixed", controlling the mass of the trailer on the end of the truck's rear overhang is made more difficult by a short wheelbase. An interesting discussion of this subject is in Towing with a Jeep CJ, YJ, TJ, LC FJ-40, LR SIII 80?. (The listed vehicles are particularly short.)
My guess is that a 4Runner with the tongue weight of a Casita 17' would be required to use a WD system. On the other hand, much bigger and heavier trailers are towed by the 4Runner and comparable vehicles; it's not at all unreasonable.
Old 07-21-2007, 07:05 PM   #9
Thank you, Brian. That does explain it, and yes, I certainly intend to use a WD hitch (and anti-sway, but that's another issue).
Good traveling!
Steve
Old 07-31-2007, 07:00 PM   #10
Trailer: Casita Spirit Deluxe
Hello All,
Thank you,
Steve Seitel
We are very happy with our 2007 4Runner..and we tow a Spirit Delux...for sure going up a steep hill I'm doing 40-45 and in 3rd. or 4th. gear and it doesn't have the quick excelleration but it is great in the cooling area...needle always stays slightly below center....mileage towing is 17-19.
I cruise in the flats to rolling hills at around 60 mph.
Larry and Yvonne Robinson..Sacramento
Larry Robinson is offline   Reply With Quote
Old 08-01-2007, 07:09 PM   #11
Ed Harris's Avatar
Steve
You never mentioned which year and engine your 4runner has?
They have been available in a rane of power outputs for sure.
I am wondering which t is.
Old 08-02-2007, 08:02 PM   #12
Trailer: 2004 Casita 17 ft Spirit Deluxe / 2000 4Runner Lmtd
Steve,
I have a 17 Casita Spirit Deluxe and I tow with a 2000 V6 4Runner. I do not have a sway bar and I have had no problems what so ever.It pulls very nicely and the width is not an issue either. I can see clearly with the factory installed mirrors on both sides.
I also installed a brake controller, which in my opinion is a MUST. I don't know what gas mileage I get with the 4Runner without the trailer, because I've never driven it without it.
I second everything that tracy.c said for the most part.
Hope that helps,
SS
sherri s is offline   Reply With Quote
Old 08-03-2007, 10:23 AM   #13
Brian B-P's Avatar
I don't know what gas mileage I get with the 4Runner without the trailer, because I've never driven it without it...
I think that makes the 4Runner an accessory of the Casita...
4Runner Engine Trivia
According to Wikipedia, a 2000 4Runner is the third generation, and its V6 engine is the 3.4 L 5VZ-FE; a 2003 or newer would use the 4.0 L 1GR-FE.
Old 08-04-2007, 07:00 PM   #14
Hi, All...
Well, thank you all...the consensus seems to be that the 4Runner is an acceptable tug, which is what I was hoping to hear.
So now, I've made the plunge...and ordered a new 17SD! Dee and I will pick it up in March 08 (winter over by then, wife retired at last...I hope!). I'm sure I'll be pestering you experts with more questions during the long wait until then.
Interesting that Casita talked me out of an equalizing hitch after all.
Thanks again to all,
Steve
P.S. Ed Harris: Our 4R is a 2000 model, with the 183hp V6 and 4-speed OD automatic transmission.
Old 08-04-2007, 07:43 PM   #15
Ed Harris's Avatar
Congrats on the descision,I am sure you will like it.
I recently got an 01 Tundra with the same motor and tranny as your 4runner and it goes well with my Fiberstream..
I think the Fiberstream may be somewhat heavier than the Casita and I have had no trouble towing thru Arizona,New Mexico,OK and Missouri.
I do have tandem axles on the Fiberstream which help smooth out the ride but I am thrilled overall with the match.
Have fun.
Ed
Old 08-06-2007, 10:11 AM   #16
Roger H's Avatar
Steve, I've towed an '02 Scamp 16' custom deluxe and an '04 Bigfoot 17' with my 3.4L V6 Tundra 4WD auto. The drive train is a good match for these fiberglass trailers. You'll do fine! Just make sure that you load the trailer properly and use some sort of anti-sway device with your short wheelbase.
Roger
Old 08-06-2007, 09:10 PM   #17
Trailer: 2008 Casita 17 ft Spirit Deluxe / 1997 Toyota 4Runner LTD (Draw-Tite WDH
Steve,
In our experience and opinion, the Toyota 4Runner is more than adequate to pull the 17' SD. You may recall that the recommended towing weight is no more than 75% of your tow vehicle's maximum tow rating. On the 4Runner, the max rating is 5000 lbs; 75% of that is 3700 lbs. The Casita 17' is rated for a maximum of 3500 lbs --- 250 lbs less than your Toyota's maxium.
We will be picking up a 2008 Casita 17' SD this October 22 in Rice, and towing it home with a 1997 Toyota 4Runner. We will have installed a WDH hitch (Draw-Tite, 2-torsion bars) and a Sway-Bar that Casita will install. We know from experience that we will have no difficulties towing with the Toyota because between December 2003 and October 2004, we towed a Wilderness UltraLite trailer behind our 1997 Toyota 4Runner across the U.S. The trailer and its contents weighed between 3650 and 3675 lbs (I weighed EVERY item we placed in it and checked the final weight on each axle on a scale). We towed it up the steep mountain that separates Jackson Hole from Grand Targee and across the flatlands of Oklahoma. We went up very steep hills rather slowly at that weight, and always switched to 2nd gear when going down steep hills. Our experience was that others on the road were patient and courteous, particularly as we pulled over whenever we could.
We would suggest that you install a WDH hitch both to ensure that the trailer and the Toyota operate as a single unit (this is a primary advantage of a WDH) and to distribute the weight over the axles for better tow vehicle performance.
If you have not already made a choice about a brake controller, we would like to suggest that you consider the Jordan Ultima; it enables you to increase/decrease the extent to which the trailer brakes are engaged as a function of how hard you brake your tow vehicle.
Again, if you have not already done so, you will need to have a transmission cooler installed in your Toyota 4Runner.
By restricting our speed to 55 to 65 mph, we found that our mpg was not significantly more than it was without the trailer.
Our Toyota is now in its 10th year and is in astoundingly excellent condition. We have chosen to buy the Casita to a large extent because we don't want to replace our Toyota.
Best,
Petit Lapin
E. Graham is offline   Reply With Quote
Old 08-08-2007, 06:53 PM   #18
Trailer: Casita 17 ft
Steve:
I have a 2003 Toyota 4 Runner with 4 L V6 and have towed a 17' Casita for the last 2 years. I am very happy with the combination. I do not use either an anti sway bar or weight distributing hitch (although I am willing to consider one) and have had no problems from sea level to over 8 K feet. It tows fine. The car is rated to tow 5000 lbs and I figure the trailer weighs 3000 loaded, so no problem.
Steven Berry is offline   Reply With Quote
Old 08-08-2007, 07:11 PM   #19
We have: 05 17' LD towed by '02 4Runner Sport, WD (sway bar hitch).
Pulls great!
Note: Toyota owners manual said to not use OD, but I believe it is that Toyota wants the deceleration offered w/ OD off. I use the OD, but do shut it off before I hit the brakes on long or steep hills. (Note: the '02 and earlier "Sports" had larger front disks!)
We average 13-14 lugging around No. NE hills, and have see 16mpg on a long Interstate pull.
(The only draw back that makes us think about a Tacoma is hauling a generator and bikes, but with some welding we plan to add rack to hitch for a Honda & put the bikes on top of the TV.)
Good choice you'll have fun!!
John Wells is offline   Reply With Quote
casita
Used Toyota 4Runner to tow 16' Casita Monica M Towing, Hitching, Axles and Running Gear 15 01-11-2009 07:17 PM
No Longer - Trade 17' Casita for 13' or 16' Casita, Scamp, pennyg Classified Archives 11 03-04-2007 09:38 PM
Trailer Mirrors - 1999 Toyota 4Runner Victor Benz Problem Solving | Owners Helping Owners 3 05-14-2006 10:40 AM
