02-23-2014, 03:58 PM
#61
Trailer: '78 Trillium 4500
Originally Posted by Darwin Maring
Floyd, You R in a no win situation. No solution mentioned has been acceptable to the experts.
That since we're dealing with "experts" who are willing to believe in the possibility of truly crossing the chains at all using a single point of attachment because that's how Scamp puts the trailer out.
And Scamp knows everything there is to know about towing, so...Until we hear from Scamp itself, we can't know anything. About anything. Period.
What shall we talk about while we wait?
02-23-2014, 04:01 PM
#62
Check the following publication where you will find a Twist on the discussion. :
http://www.generatorjoe.net/html/trailersafety.pdf
It States: SAFETY CHAINS CAN PREVENT RUNAWAY
TRAILER in case hitch/coupler fails.
1. Always use safety chains when towing.
2. Cross safety chains under coupling to prevent tongue from
dropping to ground.
3. Allow only enough slack for tight turns.
4. Do not let safety chains drag on ground.
5. Twist safety chains equally from hook ends to take up slack.
6. Use safety chains rated equal to or greater than twice the
maximum gross trailer weight rating.
02-23-2014, 04:07 PM
#63
I'm lost on what we're discussing now, and just what I'm supposed to be positive about LOL. But Carol, note my chains aren't welded on, it's the tabs they attach to that are welded. Is there a one only 100% correct answer here, I don't know. I'm just throwing out some ideas, and with what I hope others recognize as some humor added in. I'll make no further comments on this topic so as not to annoy anyone more than I already have. Lot of good points though in this thread, thanks all.
02-23-2014, 04:14 PM
#64
What "expert" here suggested that you can truly cross the chains using just one single point attachment? What post number did you read that? As I clearly missed that.
Looks to me as if we have at least one party who has acknoledged already having changed there Scamp set up to using two bolts and another such as myself is considering doing the same as I don't actually like having to wrap my chains over the side of the tongue to get a true cross.
02-23-2014, 04:43 PM
#65
Will it do for an answer if I simply quote your repetition (?) just now?
I don't actually like having to wrap my chains over the side of the tongue to get a true cross .
02-23-2014, 04:44 PM
#66
Me too! LOL time to bail as well.
02-23-2014, 05:40 PM
#67
Thank you Carol for a civil explanation.
I appreciate that.
baglo
02-23-2014, 10:06 PM
#68
Risking being accused of beating a dead horse, I want to ask: has anybody actually tested the length of the chains on his/her rig? I mean *statically* of course, NOT on the highway! (No, I have not.)
Paul
02-24-2014, 01:05 AM
#69
I have to admit, I've not. The connection to the hitch receiver is on the third link from the end of the chain and was determined at Escape when they set up the weight distribution hitch.
02-24-2014, 08:23 AM
#70
As I have towed mine with more than one tug mine have been checked. I actually need to sort it out again with my new tug. Not hard to check them in the driveway. Just hook up the chains to the tug, not the ball and pull the tug forward until the chains are straight out from the coupler. Then crank the tongue wheel down and you should get a pretty good indication as to whether or not the chains are actually going to catch the tongue as it goes down.
