Tow Speed - Fiberglass RV
Old 09-26-2010, 07:24 PM   #1
Tezha's Avatar
Trailer: Scamp 16'
North Dakota
Tow Speed
Is there a speed that gives the best MPG or does it depend on the TV.
Tom T. American Red Cross
(USAF First Sergeant "Retired")
2008 Scamp 16'
2005 Chevrolet Extended Cab Silverado
Tezha is offline   Reply With Quote
Old 09-26-2010, 08:08 PM   #2
It depends on the tug. Each vehicle will have a "sweet spot" based on the trailer being tugged and route of travel. My F-150 gets the best mileage while towing at about 58-59 mph on the flats. Drops like a rock the faster I drive and more mountains I need to climb. I'd rather go slower and leave some $$ in my pocket. YMMV
Old 09-26-2010, 08:29 PM   #3
Raya's Avatar
I think a lot of it has to do with wind resistance, but that said, as Donna mentioned, there are many variables with tow vehicle, engine, camper, etc. There's really no way to put a general number on it, except to say that (due to the wind resistance factor), a slower highway speed probably always better on fuel, as long as it is appropriate for the road and for the rpms of your vehicle (no lugging!).
Raya
Old 09-26-2010, 08:46 PM   #4
Chester Taje's Avatar
Ease off on the gas pedal and keep tires inflated to proper air pressure. I have driven or towed my units at just under 60mph.
Old 09-26-2010, 09:37 PM   #5
IllAnnoy
When towing with my Escape 4CYL,about 58MPH does the trick, slower gives little gain, faster gets costly quickly, on my Ranger 4.0 that spot is about 64MPH.
Gearing and Engine type are important, as are wind resistance and grade, fuel quality, vehicle maintenance, tire size and pressure, and overall weight.
Rapid ACCELERATION is the most expensive automotive thing you can buy, and it costs by the pound.
The opposite of a tow vehicle....
My 95 Mustang produced it's best highway mileage at 80MPH...
Lots of HP and low end torque + great aerodynamics + 2:73 gear with 275/45 R17 tires and overdrive = 2000RPM @ 80MPH just barely touching the bottom of it's efficiency. OF course with no trailer! [lol]
Old 09-26-2010, 10:34 PM   #6
As has been said many things effect best mpg and tow speed. However there's another or two to consideration when towing. ST tires are generally rated for 65 mph max. Also many states have a maximum towing speed of 55 mph. In our case here in Oregon it's not well published, but is in the laws. California posts maximum towing speed. To avoid speeding tickets check the state laws you'll be towing in or do as I do always tow between 55 mph and 60 mph. I like to stay closer to 55.
Byron
Old 09-27-2010, 02:11 AM   #7
Roger C H's Avatar
Air resistance factor goes up as the SQUARE of the speed.
40 mph = 1600
for a 125% increase in speed you pay a with a 156% increase in drag
50 mph = 2500
for a 120% increase in speed, you pay with a 144% increase in drag.
60 mph = 3600
and compared to 40 mph for a 150% increase in speed you get a 225% increase in drag.
Which is why auto mfgrs try to keep their air resistance figures low.
Old 09-27-2010, 07:31 AM   #8
I have said it before and it is worth repeating.
Towing or not, my Escalade gets its best MPG at 30 MPH with cruise control engaged. Engine speed is just above idle.
Anything speed above that and it gets worse and worse.
There's an old myth, repeated again and again by over the road truck drivers, "My truck is geared to get the best MPG at 70 MPH".
It is also a myth that your "MPG sweet spot' is any MPH above zero.
This is not 'rocket science' its 'physics'. Every revolution of your engine takes a specific amount of fuel. If you think your 'sweet spot' is 80 MPH a 2,000 RPM, you woulfd be amazed what it would be if you just lower your RPM by 1500.
IMHO
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 09-27-2010, 07:51 AM   #9
Trailer: 13 ft Scamp Deluxe 2007 and 40' Allegro Bus
Iowa
Send a message via AIM to RSchleder Send a message via Yahoo to RSchleder
I generally run about 60mph when towing my 13' Scamp. I guess I'm concerned about those 13" tires spinning too fast at speeds much higher.
RSchleder is offline   Reply With Quote
Old 09-27-2010, 09:14 AM   #10
IMHO
I agree that speed has a lot to do with towing fuel efficiency but that relationship is not completely linear. Towing at maximum torque (my 7.3l diesel Ford maximum torque is at 1600 RPM) will likely be most efficient. Towing at RPMs below and above the power band (between peaks of maximum torque and power) will not be efficient especially above power peak.
George.
Old 09-27-2010, 09:29 AM   #11
Trailer: Fiber Stream
Cool It depends on what gauge you read...
I have found that my Tachometer is the 1st gauge to follow for maximizing mpg, and my Speedometer is a modifier for road conditions. I try to keep it at 1500 rpm's or lower, and really get amazing fuel economy at 1000 rpm's. However, I have found that since I strengthened the frame on my Fiber Stream which raised it by 2", most freeway speeds happen closer to 2000 rpm's. Any speed above 2500 rpm's really sucks the gas.
As a Californian, I set my cruise control to 55 mph when towing, stay in the right lane, and allow everybody else to pass.
Name:	Tail <a title=Light Closed.jpg Views: 9 Size: 79.8 KB ID: 31435" style="margin: 2px" />Drive55.org - Home
Old 09-27-2010, 10:25 AM   #12
IllAnnoy
40 mph = 1600
50 mph = 2500
60 mph = 3600
You make a legitimate point here, this is one of the reasons that a Scamp tows so much easier than most other trailers.
Old 09-27-2010, 10:36 AM   #13
IllAnnoy
IMHO
While one could easily take issue with most of the misapprehensions in your post, the most vulnerable is the first sentence, next would be that
"IMHO" thing.<_<
Old 09-27-2010, 10:52 AM   #14
IllAnnoy
Many TVs are designed to run the air conditioner in several settings, including those which involve "defrost". The air conditioner can adversely affect fuel econmomy, to varying degrees, If you don't need it on don't run it.
Preemptively....<_<
Yes, I have heard the data on rolled down windows and air conditioning.
Frederick;
Another guage which used to be common and installed for watching fuel consumption is the Vacuum guage.
The thing worked pretty well, but it was distracting, tedious and annoying when used properly.{lol}
Speed Nuts Mike Bromley Care and Feeding of Molded Fiberglass Trailers 5 04-30-2010 08:15 PM
Fan-Tastic Vent Speed Mod Patrick M. Modifications, Alterations and Updates 7 03-05-2008 11:40 PM
Speed Limits Bigfoot Mike General Chat 10 02-15-2008 03:12 PM
Two Dahon 6-speed Folding Bikes Steve & Terri Classified Archives 0 03-22-2007 09:43 AM
More Speed and More Fun Legacy Posts General Chat 4 05-31-2003 09:24 AM
