12-12-2012, 08:21 PM
Trailer: Hunter
tow vehicle
This is a very general question to say the least. What vehicle can I get to tow a 13' hunter that weighs about 1000 to 1500 lbs.? It should cost around $3500 or so(more or less). Prefer rear wheel drive but not an absolute requirement. It should be something someone with somewhat outdated mechnical skills ( I've done a lot of work on '70's and older cars and think I could sharpen my modern skills) could work on.My newest current vehicle is an '81. It would probably be about 15 years old. Also fuel economy is a factor.I need something that isn't too exotic to find parts or service for in West Texas or rural Montana. Does such a vehicle exist? Thanks for your comments.
12-12-2012, 08:28 PM
Trailer: FunFinder
In 1992 I bought a new Toyota small pickup. 4cyl (22RE), 5 speed manual, steering, brakes and air. It was a so called "king-cab" ( little jump seats behind the 60/40 bench ). THAT was a great little vehicle. Easy to work on, cheap on gas, pulled a lightweight cargo trailer easily and got about 18mpg doing so ) and was durable as all get out. In 2006 I bought a new truck, so I gave the old Toyota to my son, and he got several more years out of it. If you can find a decent example of one from that era, it would be a jewel for you.
12-12-2012, 09:42 PM
Ford Ranger, best small truck ever made, cheap to buy and operate, and great for the task at hand.
Jeep Cherokee 4.0L, 2WD, great motor...decent chassis, solid body.
12-12-2012, 10:49 PM
Trailer: 1984 Scamp 13'
Maryland
What vehicle can tow a 1,000 to 1,500 pound camper? Pretty much anything.
-Jesse
12-12-2012, 11:00 PM
New Jersey
pretty much anything with 6 cylinders will tow it without a problem. Some larger 4 cylinders will as well. VW made a few year of the new bugs that could tow 2000lbs. Lots of options out there.
deryk
12-13-2012, 08:45 AM
Maryland
My 1.8 liter Toyota (Scion xD) pulled my Scamp just fine. The VW New Beetle is built on the same platform as the Jetta/Golf, which was rated to tow up to 3,400 pounds, depending on the engine/trans combo, and which country it was sold in.
-Jesse
12-13-2012, 08:48 AM
How about a Ranger pickup truck? Millions of them made and it certainly would tow a 13 footer.
12-13-2012, 09:16 AM
Trailer: Class A Motorhome
Considering your specs as to age and budget, I'd also opt for the Toyota pick-up. But a few words of warning. The 3.0 V6 (pre 1996) is a bit less reliable than the later 3.4 version and both are a bear to work on at home. The 4 cylinder 22R & 22RE (1985 on) are renound for reliability and long life, many hitting over 400,000 miles. Can't say that the Ranger has that same claim to fame.
12-13-2012, 09:43 AM
Trailer: FunFinder
Of course the challenge when looking for a vehicle in this age and budget category, is finding a good one. Utilitarian vehicles tend to just get used up, so the majority of them truly are gone and forgotten. But....there ARE good examples out there, so it's just a matter of being persistent and patient, and perhaps being willing to travel a little ways to buy the one you want.
The good news is they made a lot of the Toyota's, Ranger's and some would say the S10 is also a contender. The V6 in the S10 was a solid little performer, although it burns a little more fuel than the 4 banger Ranger or Toyota. Shop carefully and find one of these little trucks that does not have any rot/rust going on.
Some might also mention the Nissan trucks of that era, but in my observation, there were some pretty serious body rust issues with many of those.
A budget of just $3500 is going to be tough to stick to if you want decent cosmetics, but who knows....keep pounding the ground and you might find a good one.
12-13-2012, 10:33 AM
How many timing chains and warped heads have you changed on those "venerable" 22Rs? Compare that record to the 3.0L all cast iron V6 in the Ranger or the all cast iron Lima 4Cyl.
Here's my 2001 Ranger which has been outside for most of it's 12 years in midwest winters and worked hard towing and "sport" driven the whole time. It only has 150,000 miles on it now. I may not live to see 400,000 miles at this rate, but I can tell you that it won't be replaced any time soon...
(photo is one year old)
12-13-2012, 11:01 AM
Trailer: '78 Trillium 4500
You don't need a pickup to tow a trailer that light...You're pretty restricted by your price range, though.
A late '90's (possibly earlier)Subaru Outback would tow that trailer, possibly even if equipped with only four cylinders.
Also:
My own tug is a first generation ('97) Kia Sportage 4 cyl and I've towed about 2000 pounds over many miles with it.
It IS 4wd, though, an enhancement I find necessary to make up for the light weight of the vehicle when on loose gravel/steep Forest Service roads.
Francesca
12-13-2012, 11:41 AM
It is good that you brought this up. In my experience, customer perception of quality tends to lag actual quality. Because American vehicle quality has improved greatly over a relatively short period, it lends an opportunity in the used vehicle arena. In short, used American vehicles tend to depreciate faster than their actual quality warrants.
An anecdotal example: My wife bought a one year old Taurus in 2005 for $10,000. In the intervening years and 90,000 miles, it has been flawlessly reliable only needing tires and brakes. Granted it is an old design, like the Ranger, but time tested with the glitches worked out.
12-13-2012, 12:35 PM
I drive Toyoya PUs.
I've never HAD to get rid of one, I just got tired of it and wanted new featueres.
I have had several which had over 200,000 miles on them.
My youngest grandson is driving one of my old Toyotas and it has close to 500,000 miles on it. Several timing chains, two clutches, one since a teen has been driving it, and routine maintenance is all that's ever been done to it.
If you're buying older your best bet is a Toyota.
12-13-2012, 01:36 PM
Originally Posted by Perry J
I drive Toyoya PUs.
Sounds great! Same experience with the four Rangers I've owned and the twelve I had in fleet service. (Except for all those clutches and timing chains).
Betting is gambling, buy the Ranger!
Or anything that you like, in good shape that fits the budget.
12-13-2012, 04:15 PM
Maryland
Still don't know why anyone would go out of their way to by a TRUCK for towing a 13 foot fiberglass RV. Now, if you NEED a truck for other things, go for it... But these campers were made to be towed by 4 cylinder cars!
-Jesse
12-13-2012, 04:19 PM
Trailer: 1979 13 ft Boler and 1987 Bigfoot 5th Wheel
Cause some of us just like trucks!
12-13-2012, 04:52 PM
The OP is from Texas. Texans drive pickup trucks, not wimpy Asian SUVs.
12-13-2012, 05:33 PM
Trailer: FunFinder
The reason I suggested a truck, and specifically a Toyota truck of that era is partly because the OP had stated a desire to buy a vehicle that is a simple design and user serviceable. These little 2WD 4cyl manual trans trucks are exactly that. Replacing a clutch or other service component can usually be done without special tools, etc, at home by the average shade tree wrench.
When you are talking about most smaller cars in that category, you generally are dealing with front wheel drive, which makes them somewhat less friendly to work on at home.
The OP has not chimed back in on the thread, but it sounds like she may in fact be on a rather strict budget when it comes to vehicles, so to my mind, small trucks can be an excellent choice as a "do anything" vehicle. I also like a truck because it allows carrying things like generators and fuel cans in a safe manner ( not in the interior ).
Floyd points out the potential for head and or headgasket issues with the old 22R Toyota motor.....for sure, do NOT overheat one of those motors. Get it good and hot and you are almost guaranteed to fry it.
Back in the day you could get a "motor-rad" thermostat for those. It's advantage was that if it failed, it failed in a locked open position, leading at worst to running too cold rather than too hot. I don't know if they still make them or not, but I had one in my '92 Toyo.
To the OP, if you don't already know this, it's a good idea when evaluating these older vehicles to have someone knowledgeable look them over very carefully underneath. Make sure the frame and suspension parts are still solid, and not rusting/rotting away. Bushings and shocks etc, can of course be replaced easily enough, but if the major parts are too far gone, then it's pretty much a pass on that one walk away.
12-13-2012, 05:56 PM
The primary cause of overheating and head gasket failure in the 22R & 22RE Toyota's, is thought to be caused by long term use of the wrong coolant. Toyota "Pink" coolant is the weapon of choice. Until recently most other commercial automotive coolants were not designed to be used with the combination of metals found in the Toyota (and other Asian) engine.
FWIW: The most common damage caused in these engines is a failure of the headgasket in the #4 cylinder and in almost all of those cases inspection of the gasket will show that metal deterioration started at one cooling passage long before the actual failure.
Those that use Toyota coolant exclusively seldom have headgasket problems.
I have had exactly one headgasket failure on one of the five Toyota 4 cylinder motorhomes I have owned. That occured after driving it about 2000 miles, after it had been stored for 4 years with generic antifreeze in it.
The mechanic correctly predicted what he would find when removing the 20+ year old head at 118,000 miles, an eaten away headgasket in the #4 cylinder
12-13-2012, 06:21 PM
Trailer: FunFinder
Bob,
That's interesting about the coolant. When I had my Toyota, I always used the Toyota pink stuff. At that time it was one of the few antifreeze blends that was "silicate and phosphate free". At that time I was also running Honda and Kawasaki water cooled motorcycles, and they were adamant about using coolant that had no phosphates and silicates, in part because of the design of their waterpump seals. By that time in the evolution of all this stuff, I decided to keep it simple by using the coolant that came from the dealerships for these vehicles.
However, let's not even let this discussion go down the road of "dexcool" !
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
New tow vehicle
Doug Arthurs |
16 |
02-18-2012 03:31 PM |
Your next tow vehicle?
Byron Kinnaman |
General Chat |
1 |
10-02-2007 08:08 PM |
'New' Tow Vehicle!
Steven Stanfield |
General Chat |
2 |
02-02-2006 06:52 PM |
Tow vehicle
Steven F |
7 |
01-09-2006 06:49 PM |
Tow Vehicle
Legacy Posts |
5 |
08-10-2003 12:12 AM |
