Tow Vehicle & Trailer combos - POST INFO - Page 13 - Fiberglass RV
Old 05-09-2015, 06:29 AM   #169
honda03842's Avatar
Name: Norm and Ginny
Adding Tires
First F250
Thanks Mark, your's is our first Ford F250.
People always question trailer Tire choice. I've decided to add it as a category.
Tow Vehicle:
Engine:
TV tow ratings:
Trailer Brand and Size:
Trailer Weight:
Trailer Tongue Weight:
mpg towing:
mpg not towing:
towing speed:
Special Hardware:
Tire Size:
Tire Brand:
https://docs.google.com/spreadsheets...Pkw/edit#gid=0
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 05-09-2015, 07:27 AM   #170
John & BJ S.'s Avatar
Name: John & BJ
Trailer: 2010 Scamp D19
Mesa AZ
The rest of our info is already in the spreadsheet. We're running Continental Vanco tires in the 215/70R15 size. They're a D range LT type tire.
Sent from my XT1032 using Fiberglass RV mobile app
John & BJ
Mesa, AZ
"We're not lost. We're just finding our way."
www.justfinding.blogspot.com
John & BJ S. is offline   Reply With Quote
Old 05-09-2015, 08:15 AM   #171
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Please add to Jon Vermilye: Tires - ST205/75/15 Maxxis M8008 (D range)
Since some of the same size tires have different "ply" or load ratings, it might be good to add that to the description...
Old 05-09-2015, 08:41 AM   #172
honda03842's Avatar
Thank you Jon and John for the tire information, you too Norm....
Tire sizes numbers are followed by the load range... -D, -C, -B....
I am assuming radial tires unless otherwise mentioned.
https://docs.google.com/spreadsheets...6oSPkw/pubhtml
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 05-09-2015, 05:34 PM   #173
Name: John & BJ
Mesa AZ
Just to add a bit of complexity, Norm, I run a 14" Kumho 857 in a 205R14C size for our spare. It's the same outside diameter and load rating as the Vanco 15" tires. Both the Kumho and the Continental Vanco tires are built to European commercial standards equivaltent to a D load range.
The whole story is on the blog at Just Finding Our Way: Another Tire Update
John & BJ
Mesa, AZ
Old 05-09-2015, 07:25 PM   #174
honda03842's Avatar
Added Info John. Also I've frozen the title names for all columns. As you schroll down the titles always remain at the top.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 05-11-2015, 10:35 AM   #175
Saskatchewan
I'm line 27 in that spreadsheet.
Trailer tires
ST175/80R13 - Carlisle
Averaged 16mpg (american) @ 60mph over 600km this weekend.
dbir is offline   Reply With Quote
Old 05-11-2015, 11:19 AM   #176
honda03842's Avatar
Dale,
Thanks for the tire info
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 05-14-2015, 06:47 PM   #177
honda03842's Avatar
Thanks for the tire info Mex Bob. The little list has had 10,000 hits and the more info we can add like tires will help others, Thanks again
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 05-14-2015, 07:09 PM   #178
J.F.Y.'s Avatar
Norm, Ginny.....
I have tire info to add to my 4/26/15 post:
Carlisle 215-75 R 14, load range C
J.F.Y (Frank)
J.F.Y. is offline   Reply With Quote
Old 05-14-2015, 08:03 PM   #179
Trailer: 2017 Escape 19
Norm, I can now add some info on miles/gal for our set-up when towing. We just got back from a three week trip and averaged 13.6mpg with premium and 12.7 with regular. How did we decide whether to fill with regular or premium? We decided to run a test. Friends of ours who tow an Escape 19 always use premium, claiming the higher cost is offset by the better mpg. We calculated that if the spread in price is no more than 24 cents/gal, we come out ahead (or at least break even) by using premium. If the spread is more than 24 cents/gal, then we fill with regular. This trip took us over some really high passes (over 8,000 ft) and into parts of the country that are at high elevation (5,000 ft or more). I think we'd do better if a trip was mostly on flat terrain at lower elevations. Also we definitely saw better mpg when we drove two lane highways at 55 mph than freeways at 60-65 mph.
I don't have info on our non-towing mpg because we rarely use the truck except for towing. We just filled it up though so we may be able to get a mileage check before our next trip if we use the truck some.
Evergreengirl is offline   Reply With Quote
Old 05-15-2015, 05:16 AM   #180
honda03842's Avatar
Frank, thanks for the tire information.
Kathy, We've never tried premium fuel in our Honda though it's suggested for towing. Usually there are three grades of fuel here. Are you buying the highest grade or the middle grade? I'll have to try it sometime. Thank you.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 05-16-2015, 09:06 AM   #181
Trailer: EggCamper 2012 #109, by 2006 Tundra or 2014 Outback
Western Massachusetts
Regular or Premium Gasoline?
Usually, changing to premium will not make a discernable difference. But towing, especially up grades, might be the exception. With computer controls in all vehicles now, that the driver has no control of, knock or ping are sensed by the computer and timing retarded before the driver notices. But timing retardation reduces both gas mileage and available engine power. So, towing, especially up grades will require more power, and if the engine is smaller and/or low compression, then require more retardation to prevent knock, thus lowering gas mileage also. So, in some cases premium gas, which prevents knock or ping more than regular, may allow the computer to retard in less cases, thus making for better gas mileage and more available power. (Note that although most of us have not heard knock or ping since we owned a 1980's vehicle, but often or sustained engine knock, or ping, even in a new vehicle, will usually result in internal engine damage)
2 important factors here: Gas Mileage, and Power. Is the difference in price worth the increase in gas mileage, and does the rig need more power to go up a grade. Either factor may be a reason for Premium gas. But usually premium is not needed.
YMMV--ha!
Mark
coastsignal is offline   Reply With Quote
Old 05-16-2015, 10:22 AM   #182
Norm, here we often have just two grades of gas available, Regular (87 octane) and Premium (92 octane). When there are three grades, the mid-grade is 89 octane. We stuck with either the Regular or Premium grades so as to not add one more variable to our experiment. I too was skeptical that premium would make a difference, but the figures we got seem to bear out our friends' experience. Again I must emphasize that you need to do some calculating and pay attention to the price spread. If the premium is too much more than the regular, it doesn't make any difference in your fuel costs. Since we do most of our traveling in the West, where we always encounter high elevations and steep grades, premium makes sense for us as long as it's not more than 24 cents/gal higher than regular. As Donna says, YMMV!
SPLIT: Tow Vehicle & Trailer combos - COMMENTS cpaharley2008 Towing, Hitching, Axles and Running Gear 60 04-11-2015 02:39 PM
Trailer wiring on Tow vehicle David Thomson Towing, Hitching, Axles and Running Gear 24 03-19-2015 03:10 PM
Vehicle Info General Chat 0 12-31-1969 07:00 PM
» Virginia Campgrounds
