Tow Vehicle & Trailer combos - POST INFO - Page 9 - Fiberglass RV
Old 03-19-2015, 01:43 PM   #113
Ice-breaker's Avatar
Trailer: Escape
Originally Posted by Glenn Baglo View Post
...I doubt than any of mileage submitted is in miles per imperial gallon.
I have to confess that I submitted in units of IMPG. But I also provided comparable values in USMPG and L/100km, just so that all my bases were covered.
Dave W - 2013 Escape 19' and 2011 Toyota FJ Cruiser
Ice-breaker is offline   Reply With Quote
Old 03-21-2015, 07:43 AM   #114
scotty61's Avatar
Originally Posted by MC1 View Post
Those are very good numbers Norm for the TDI. I like the way those German cars drive and would suspect that good road feel continues on even with trailer in tow.
The combo feels great... The only thing you really notice is the extra width of the trailer as you maneuver through tight areas. The car itself doesn't run any hotter than it does without the trailer either, and also has plenty of power for passing when necessary.
Scotty61 - 1976 Trillium 1300
scotty61 is offline   Reply With Quote
Old 03-21-2015, 07:48 AM   #115
scotty61's Avatar
Originally Posted by Bob Miller View Post
Don't you have to reduce MPG (Imperial) by about 1/5 or multiply by about .8 to get MPG (US)?
Canadian gallons and Imperial gallons are the same. An Imperial gallon is approximately 4.54 litres where a US gallon is approximately 3.78 litres. As an example, 50 mpg Imperial would equal approximately 41.6 mpg US. Hope that helps!
Old 03-21-2015, 07:54 AM   #116
scotty61's Avatar
Originally Posted by honda03842 View Post
I contacted Scotty61 and he confirmed Imperial Gallons. The values have been adjusted, still the best numbers.
https://docs.google.com/spreadsheets...6oSPkw/pubhtml
Hi Norm:
I keep trying the link above and keep getting old information. I'm not seeing any of the updates that you've been doing. Any ideas?
Al
Old 03-21-2015, 09:02 AM   #117
honda03842's Avatar
Name: Norm and Ginny
Al,
Check this out and let me know if it's OK for you.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 03-30-2015, 04:41 PM   #118
Trailer: Escape
Saskatchewan
2010 Toyota Tacoma DCLB (Double Cab Long Box) TRD Sport, 4.0 L V6,
Towing 19' Escape 2600 lbs,
Worst 15 mpg mountains towing, best 24 mpg empty no trailer, typical speed 60-70 mpg.
Shannon MacNeill
Shannon MacNeill is offline   Reply With Quote
Old 03-30-2015, 05:09 PM   #119
honda03842's Avatar
Thanks Shannon.
Always looking for more tow data,
Tow Vehicle,
engine,
TV tow ratings,
trailer,
trailer weight,
mpg towing
mpg not towing,
towing speed
Thanks everyone.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 03-30-2015, 05:23 PM   #120
sokhapkin's Avatar
Trailer: 2014 Scamp 16 layout 4
SW Florida
2013 F-150 5.0L V8 SuperCrew Cab short bed.
Tow rating 8000#.
Scamp 16' layout 4 (side bath). Weight about 2500#.
16-17 mpg towing at 60 mph.
21mpg not towing
Same trailer with 2001 Mercury Grand Marquis 4.6L V8, tow rating 2000# (sic:-) :
25mpg not towing
Sergey
www.callwithus.com
Old 03-30-2015, 05:35 PM   #121
honda03842's Avatar
Thanks Sergey, More data makes it more useful
Tow Vehicle
Engine
TV tow ratings,
Trailer Brand and size,
Trailer weight,
mpg towing
mpg not towing,
towing speed
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 03-30-2015, 05:49 PM   #122
2600 lbs for a 19' Escape? Really? Is this possible a typo?
seems about 1000lbs lighter than other 19' Escape weights I have heard off as well as those on the Real World Weight thread.
Old 03-30-2015, 07:53 PM   #123
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
Vermont
Found an error in the line listing luverOlife setup. Only because I was looking for those who tow a 19 ft. 5th wheel Scamp.
Paul
Old 03-30-2015, 08:12 PM   #124
That's the dry weight according to specs.
Old 03-30-2015, 08:31 PM   #125
honda03842's Avatar
Paul, I believe all the Scamp 19 listings are correct now.
As to Shannon's Escape, I've sent her a PM asking if that is the dry weight.
I generally do not correct submitted information unless I hear from the poster.
Thanks for your help.. I believe we'll gradually get it correct. Many postings have been updated and improved by the owners over time. Thank you to everyone for making it better.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 03-30-2015, 08:44 PM   #126
Trailer: Fiber Stream
Originally Posted by Frederick L. Simson View Post
Tow Vehicle: 2003 Honda Odyssey
Engine: 3.7 liter V-6
Manf. Tow rating (trailer weight/hitch weight)
  • without trailer brakes: 1000 lbs/10%
  • without weight distribution hitch: 1,850 lbs/10%
  • without anti-sway bar: 2000 lbs/10%
with ALL of the above and including the driver
  • 2 occupants: 3,500 lbs/10%
  • 3 occupants: 3,350 lbs/10%
  • 4 occupants: 3,200 lbs/10%
  • 5 occupants: 3,050 lbs/10%
  • 6 occupants: 2,900 lbs/10%
  • 7 occupants: 650 lbs/10% (rear GAWR limit)
... assuming each occupant weighs 150 lbs
Trailer: 1971 Compact Jr.
Trailer Weight: 1700 lbs
Tongue Weight: 120 lbs
(Trailer has Brakes, but standard hitch, not WDH, no sway control)
mpg towing: 17 mpg
mpg not towing: 22
towing speed: 60 mph (between Yuma & Phoenix, AZ)
SPLIT: Tow Vehicle & Trailer combos - COMMENTS cpaharley2008 Towing, Hitching, Axles and Running Gear 60 04-11-2015 02:39 PM
Trailer wiring on Tow vehicle David Thomson Towing, Hitching, Axles and Running Gear 24 03-19-2015 03:10 PM
Vehicle Info General Chat 0 12-31-1969 07:00 PM
» Virginia Campgrounds
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
