Tow Vehicle Upgrade - Fiberglass RV
Old 07-25-2013, 07:48 PM   #1
Trailer: Scamperless
Tow Vehicle Upgrade
Since down sizing to a Scamp, it became apparent we needed to haul more items in the truck. So out with the behind the cab tool box, and I installed a toneau cover. But I didn't want to roll up the toneau cover every time I needed to get something out of the truck. So welcome to my "sled bed". All though Sledbed is an actual product, I can't use that name. What ever you want to call it, it works great. It holds a ton of stuff and works great for all that bulky stuff. It also gives me two levels of storage in the bed of the truck.
I really wish I could take credit for the design of this, but I can't. I found in on the the Google. It is easy to build and relatively inexpensive.
Jerry71 is offline   Reply With Quote
Old 07-26-2013, 02:16 PM   #2
Trailer: FunFinder
that looks great Jerry ! Do have any more detail pics of how you actually built and assembled it ?
gmw photos is offline   Reply With Quote
Old 07-26-2013, 03:00 PM   #3
Sure, just follow this link.
Build This Sliding Truck-Bed Drawer, and Get Easy Access to All Your Tools - Fine Homebuilding
There is a brief utube video and down towards the bottom there is a link to drawing and plans.
The one in the video was build heavy enough for contractor items. I lightened mine up since I am not hauling air compressors and generators. For example instead of 3" casters, I opted for 2 1/2". And instead of placing them 12" on center, I placed them 16" on center. So you can actually get by with 2 fewer casters. For the bottom sheet of plywood I used 1/2" and for the upper piece of plywood I used 5/8" instead of 3/4". I also only put one 2x4 on the bottom sheet of plywood under the casters, and used 2x2's for the rim around the sliding bed. Again, I lightened it up for hauling camping equipment like lawn chairs and a fold-able table.
I glued and screwed everything.
If you would like to see a specific picture, just let me know and I'll try to get one posted.
Old 07-26-2013, 04:09 PM   #4
Trailer: FunFinder
Thanks Jerry, I'll check it out.
Old 07-27-2013, 02:17 PM   #5
Brian B-P's Avatar
Great work, Jerry - thanks for sharing it.
The drawer bottom seems to be well above the truck bed floor. It would be nice to lose less useful storage height, but that would require putting the rollers beside - rather than under - the drawer.
In addition to in pickup beds, similar systems are often used in "basement" storage compartments of motorhomes and large RV trailers. Since cross-RV compartments are even longer than pickup boxes, some of the same products would work equally well in both situations, but strangely the commercial products seem to be marketed only for one purpose or the other. Either way, they can be expensive, so the home-built approach is a valuable alternative.
Brian B-P is online now   Reply With Quote
Old 07-27-2013, 06:20 PM   #6
Brian, the space below the sliding bed is not lost. That is were I put our folding aluminum camp table and our two lawn chairs. I tie a small rope to the table so by simply pulling on the rope, the two chairs slide right out the back when needed. So this sliding table actually adds storage space to the back of the truck.
If you are talking about losing space when I am not hauling camping gear, since the assembly is not fastened to the box in any way, the table slides out in about a minute, and the base slides right out in another minute. So I can have my full truck box for other uses in a very short time.
Old 07-27-2013, 08:05 PM   #7
cpaharley2008's Avatar
I like it, I have a fiberglass cap but with something like this I could get by with a tonneau and one of these setups!!
Jim
Never in doubt, often wrong
Old 07-27-2013, 10:00 PM   #8
Brian B-P's Avatar
Clever!
And how about this for a tow vehicle? CindyL General Chat 4 05-16-2013 06:19 PM
My new tow vehicle cpaharley2008 Towing, Hitching, Axles and Running Gear 35 11-26-2012 05:24 PM
Got tow vehicle, now which RV? Frank G. General Chat 0 05-06-2007 03:01 PM
Need a new tow vehicle? George Cathcart Jokes, Stories & Tall Tales 3 10-27-2006 08:52 PM
Tow vehicle Steven F Problem Solving | Owners Helping Owners 7 01-09-2006 05:49 PM
