Towing 16' with 4 cylinder - Fiberglass RV
Old 10-03-2006, 02:11 PM   #1
Trailer: 2004 Scamp 13 ft (''Egg-zackly'')
I currently have a 13' Scamp and would like to ugrade to a 16ft'er, but my two vehicle is tow rated at 1500lbs. Is the upgrade do-able, or a pipe dream?
thanks so much!
Arline
Arline Lovell is offline   Reply With Quote
Old 10-03-2006, 04:55 PM   #2
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 2004 Airstream Interstate 22' B-van
Iowa
thanks so much!
Arline
Arline, I think the typical current Scamp 16' with a bath weighs in dry at around 2000 lbs. My '02 custom deluxe front bath side dinette model was rumored by Scamp to tip in at about 2700 lbs dry.
Feel free to check those numbers with Scamp to confirm that I'm not out to lunch...
Roger
Old 10-03-2006, 06:55 PM   #3
John Perry's Avatar
Trailer: 1996 13 ft Scamp
Send a message via AIM to John Perry
thanks so much!
Arline
I would not try it. My 05 Toyota pickup has a 2.7 L, 185 hp engine. It tows my 14 ft. Wide Body Burro just fine but on steep grades I have to gear down. I would not want to tow anything any heavier.
Dry weight on my trailer is 1100 lbs. and fully loaded I am towing probably about 1600 pounds and my truck has a tow capacity of 3500 lbs. I think they rate tow capacitys on flat ground.
John
John Perry is offline   Reply With Quote
Old 10-03-2006, 09:01 PM   #4
Trailer: Fiber Stream
Talking
I have an artist friend who lives in Vermont, and own a 13' Burro. The trailer has an extended (on the back) frame to carry a large utility box for tarps and jacks and "stuff".
He makes an annual trip west to attend Burning Man, and then a retreat Later in September in the Malibu Hills.
I first met him in Malibu. He told of towing across the country with a '90 something Toyota 4 cylinder pick-up, and what an ordeal the trip was that first year, and how he dreading the return trip to Vermont because of that under-sized truck.
He now flies across country, with tent gear as checked baggage, and leaves the truck & Burro home.
Old 10-03-2006, 09:09 PM   #5
Gina D.'s Avatar
West Coast USA
I tow a 13 ft Burro with a 2.4l 160 hp Honda Element.
I am fine with what I have, but wouldn't even consider tugging any bigger.
Old 10-04-2006, 05:00 PM   #6
don bowman's Avatar
Trailer: 87 Casita Liberty Deluxe (restored)
The number of cylinders is not the issue, but the size of the motor and tow rating.
I have a '95 Nissan Pathfinder with a 6 cylinder but only a 2.9L engine. I have a 16ft Casita and on two trips from Austin, TX to Muleshoe,Tx I had to drive for hours with my foot to the floor going against a strong side or head wind and when going up hill.
Something with a 3.5, 3.9 or larger would sure be nice. But I normally only go a hundred or so miles from home and make it with the 2.9L that I do own.
Good luck, don
don bowman is offline   Reply With Quote
Old 10-04-2006, 05:20 PM   #7
Trailer: 1997 13 ft Scamp Deluxe and 2006 Airstream 75th Anniversary International Bambi Prototype
Boy can I chime in on THIS one!!!
I have one of the longest posts here about difficulty towing my 13ft Scamp Deluxe. My trailer is HEAVY (2480lbs fully loaded) which is what I'm hearing 16 and 17ft trailers are weighing at. Mine is just overly heavy due to the solid oak, A/C, fridge, heater, microwave, porcelain toilet (who's idea was THAT?!?!), shower/full bath, stereo, 4 speakers, tv, dvd player, oak nick-nack holders...anyway, my points are two-fold:
1) Tow ratings are ALWAYS over-rated for satisfactory towing and are ALL rated for level ground
2) Scamps, Casita's and the like are GROSSLY under-rated regarding weight from the factory. My trailer was supposed to weigh 1400lbs unloaded. ImPOSSible.
I ran into a guy in Utah a couple weeks ago with a bone stripped Scamp (basically a shell with a dinette...no bath, no fridge, no furnace, no water pump, no A/C, no brakes...NOTHING); he had certified his weight at 1600lbs DRY. Late models of these trailers are a LOT heavier than the factories say.
Anyway, I towed mine with a SCCA Dodge Neon when I bought it in 1996...and the little car did amazingly well looking back. I had to go with a 400hp 400lb/ft torque Chevy SSR to make a notable difference in ease of towing of my particular trailer. I blew up a Caravan last year trying to tow the thing. But, now....I have ample power to literally fly up mountains, but even still.....this trailer still FEELS like it weighs 7500lbs! Although I can pull it with ease (I am seriously in the overkill department power-wise) my point is that I shouldn't NEED this much power, and this trailer should still be SIMPLE to tow. But, its not...and I've ruled out wheel/tire/alignment/bearing/brake/wind buffering issues.
To make a long story short....don't even think about towing a 16ft with a low powered 4-cylinder. This entire discussion in that regard completely defeats the entire idea of having a small/lightweight/easy to tow trailer. If I would have known it was going to be this difficult from the get-go, I would have bought a 35ft 5th wheel and a giant diesel truck. They seem to just zip right up the mountains while I, with my 400hp SSR and tiny egg...while aptly going right up as fast as I want and as efficiently as I want, still feel like I am struggling just a little too much in comparision to these giant rigs.
Jeff
Jeff G. is offline   Reply With Quote
Old 10-04-2006, 11:30 PM   #8
Gina D.'s Avatar
West Coast USA
I have "People" to transport my gear for me...
Old 10-05-2006, 01:14 AM   #9
bonnie w's Avatar
Trailer: 1974 Ventura
Just wanted to ask you Jeff where in the world did you put your full bath with shower and porcelin toilet? I am full of envy. This topic of towing has nearly been flogged to death, but my question is does my GMC 2005 Colorado have less power because it's a standard gear shift. Would there be more power if it were automatic. I now hear mine is actually a 5 cylinder, but hey I still have to lean forward when going up hills.
bonnie w is offline   Reply With Quote
Old 10-05-2006, 05:47 AM   #10
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
Bonnie,
Your 3.7 liter, straight 5 engine makes 242hp and has 242 lb./ft. of torque. I doubt the engine power differs with standard or automatic transmission. With that much power you should be having little trouble towing your Ventura. You might want to join this forum and ask the same question.
http://www.coloradofans.com/
Tom Trostel
Old 10-05-2006, 06:55 AM   #11
Roger H's Avatar
Iowa
Bonnie,
You raise an interesting question. Having had a variety of trailers and tow vehicles in differing combinations over the past couple of years, I can share some observations I've made. First, any tow vehicle towing near it's max tow weight will get around 12 mpg plus or minus a couple regardless of engine size or trailer. Reduced weight causes that to rise a little; but reduced frontal area on the trailer in relation to the tow vehicle causes a SIGNIFICANT difference and a significant difference in ease of towing.
Not all tow vehicle/trailer combinations are created equal, and I've found that assumptions I've made by 'looking' at them aren't valid. I suspect that without windtunnel or trial-and-error testing of the various combinations, there's really no way to know how a specific tow vehicle/trailer pairing is going to work in the real world.
Of course, the faster you go, the harder your trailer is to pull, especially with a flat, square front. Add to that a smaller front-surface area tow vehicle like the Colorado that doesn't move the air smoothly ahead of the trailer and it's like trying to tow a piece of plywood sideways. Some trailers move air smoothly themselves, and some don't. Some tow vehicles leave a 'tunnel' behind them that smooths the way for the trailer and some don't.
Presuming that your truck is running the way it should, and is properly equipped, you may just be a victim of poor aerodynamics.
Roger
Old 10-05-2006, 07:24 AM   #12
Patrick M.'s Avatar
Trailer: 2007 Casita Liberty (Sold 2011)/ Honda Odyssey
I get 17+ at the tow rating for my Element. "Any" might be a bit broadbrush.
The title of this thread is a little misleading as the number of cylinders is not important, it's the tow rating of the vehicle. Anyone know what the highest tow rating is for a 4 cylinder is?
Patrick M. is offline   Reply With Quote
Old 10-05-2006, 08:27 AM   #13
Dave Van Vugt's Avatar
Trailer: 75 Trillium 13 ft
I have been considering a slightly used Nissan Xterra, with the 4 cyl rated at 3500 lbs towing capacity 5000 lbs with the 6. More than enough for my 13 footer I'd say, although some reviews I've read have complained of the 4 cyl version being "underpowered", which makes one wonder how it rates such a high tow rating compared to other 4 cyl SUV's.
Dave Van Vugt is offline   Reply With Quote
Old 10-05-2006, 10:32 AM   #14
Roger H's Avatar
Iowa
As it was intended to be Patrick. What's really interesting is the percentage of drop from the unladen mpg to the laden towing mpg from vehicle to vehicle. In raw numbers though, it seems to be usually between a 5-10 mpg loss, with vehicles with smaller engines and higher tow loads suffering the highest percentage mpg loss. If I were drawing a comparison statistical formula that would be most accurate, I'd guess it's probably weight to horsepower ratio of the GCVWR. The rear end gearing is probably THE second most important factor in miles per gallon.
Roger
Old 10-05-2006, 10:53 AM   #15
Patrick M.'s Avatar
My loss from no-towing to towing is roughtly 8 mpg on average, so I can confirm that.
Old 10-05-2006, 12:37 PM   #16
Trailer: 1982 13 ft Burro
If nothing else, this discussion makes me feel better about the numbers I get - 14 mpg with my 95 Montero SR and a 13-foot Burro vs. about 17 for the Monty by itself.
Of course, the Monty is such a brick, towing a parachute couldn't make the aerodynamics any worse.
We're toying around with trying to pull it with our little 94 Toyota pickup 2WD. I think if we lived in Kansas, it would work just fine, but here in Colorado, I can picture myself rolling backwards trying to get up Eisenhower. But the Toy does get 32 mpg freeway...
AndyW is offline   Reply With Quote
Old 10-05-2006, 02:21 PM   #17
Trailer: 13 ft Scamp
I have enjoyed the comments that I have read so far. I'm new to the fiberglass camper world in that I bought a 13' scamp 3 months ago. We started pulling it with a Ford Ranger "Edge" 3.0L with a towing weight of 2350lbs. While the Ranger would pull the trailer. I was concerned with the ability to pull in mountainous terrain out here in Arizona and western states.
After looking intently at towing vehicles, we traded in our car for a 06 GMC Envoy. I'm impressed with the layout of this vehicle. In two weeks I have now put 550 miles on it (break in period... No towing) and am excited to tow with it now.
I realize that I'm moving against the newer high oil prices, but I also wanted to have a vehicle that I can upgrade campers later on and still use.
My initial milage is pretty good for an SUV 21MPG Hwy. Iwill post towing milage as it comes in.
Factory specs are:
Vortec 4.2L I6
Horsepower 291 hp
Torque 277 lb-ft
Factory built in trailer hitch with trailer wiring (round plug) w/ trailer brakes factory installed in the SUV.
While I realize that some consider this is a significant waste of gas. I also have read many stories of people destroying tow vehicles by overloading them. From the numbers, this seems to be the best in class for towing. I purchased the 5yr 100000 mile waranty which encompases towing a trailer of 4000lbs in the manual.
With such a small trailer, we will have to compensate some weight in the SUV which the Ranger would not have efectively been able to haul over great distances.
Thanks for all of the posts they have been helpful.
Cheers
Doug
dsheets70 is offline   Reply With Quote
Old 10-05-2006, 04:33 PM   #18
John Campbell's Avatar
Trailer: Scamp 13 ft 1990
NW Wyoming
I am relatively new to towing in general and to my Skamp in particular and am always learning from reading everyone's comments. I'm glad, however, that I didn't read all these towing posts before starting my Skamp career or I never would have left the house. I have a S13 with fridge, AC, and furnace. I weighed it on a certified scale as part of licensing requirements at 1240 pounds plus the tongue weight, which I will get around to measuring any day (or month) now.
I tow with an old 1991 1.6 L, 4 cylinder Isuzu Trooper with a 2000 lb tow rating. I regulary haul my egg up and down 8-10% grades here in the mountains of western Wyoming. I am not the fastest mover on the way up the hills, but I'm not much slower than I am with no trailer. The Isuzu itself is like towing a piece of plywood down the road. On the flats, I tow at 55-60 mph and get 18 mpg, about 3 mpg less than without the trailer.
The hitch on my Trooper is welded on, so no adjustment is possible and I tow in a decidely nose up position, which should have added to my woes.
When I win the lottery (or some MFROG reader makes a generous donation), perhaps I will get a more appropriate tow vehicle. But until then, I'm still happy as a clam rolling down (or up) the road -- even knowing what I now know.
Thanks to all of you for all the great posts in this forum. The body of knowledge held by all of you is incredible.
John Campbell
John Campbell is offline   Reply With Quote
Old 10-06-2006, 01:08 AM   #19
bonnie w's Avatar
Hopefully my comment about the subject of towing has been flogged to death wasn't taken too seriously. The old foot in my mouth. I can never learn enough about the trials and tribulations of towing because it is all new to me. It 's a case of "if I knew then what I know now" I would have probably bought a six cylinder preferably a Toyoto, Mazda instead of the GMC Colorado. I can't really fault my truck for it's performance or the gas mileage. That was a great way to explain it when someone said pulling my little "Vinnie" Ventura was like towing a piece of plywood sideways down the highway. The aerodynamics did cross my mind on my trip. Will pay more attention too to the amount of "stuff" I didn't use or need. Thinking back on the 6000 mi. I just did, never did we have a long line up of traffic on the long steep hills, in fact we passed most big rigs on those grades.
Old 10-06-2006, 06:47 AM   #20
CliveAlive's Avatar
Trailer: Boler American #3104
John Campbell
I love those old Troopers. I just wanted to suggest that you look into a 'stinger' (I think you call it) that can drop or raise the height of the ball, available in different heights.
I'll be towing my Boler with my 85 Volvo wagon. I thought I had the rights to most un-aerodynamic and 'Brick-like'.
towing w/ 4 cylinder vehicle Dawn SW Towing, Hitching, Axles and Running Gear 9 04-05-2008 07:50 PM
Towing Jamie Towing, Hitching, Axles and Running Gear 20 08-15-2007 05:16 AM
Is a 4 cylinder honda CRV usable for towing with? Dale662 General Chat 3 05-16-2006 09:48 PM
Towing 101 Legacy Posts Towing, Hitching, Axles and Running Gear 22 05-08-2003 07:44 PM
towing w/ 4 cylinder vehicle Dawn SW Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
