02-16-2012, 12:40 PM
Towing: 5th Versus Bumper Pull?
I tried searching for this and I am sure it has been addressed but I couldn't come up with the right terms to dig it up. I have never actually driven the tow vehicle when we pulled the trailers we had so it will be an exciting adventure for me as will hooking the two together because usually I am the one giving the driver the directions from outside. In the stick-built world, it seems they feel the 5th wheel tows better, at least the majority of owners with only a few that disagreed over the years. I'm thinking that with the "right" tow vehicle, there probably isn't a whole lot of difference especially with a unit that is so small - when I saw a Scamp 5th the first time, I could not believe it was so tiny as there was also a 42' Prevost in the park at the time. The first 13' Scamp I saw had been pulled by a Pinto wagon! Any thoughts appreciated. Thank you.
02-16-2012, 02:28 PM
Edit: I've changed parts of the post as I miss read the article . Thx for the correction
Hi Cathy,
I'm going to be new to towing this spring as well. Linked below is a piece on sway control that has an interesting bit about fifth wheels vs. tow behind. Essentially a fifth wheel has a pivot point that produces less leverage. I found it a good article all around. As I mentioned I'm new so open to corrections.
Controlling Sway Causes of poor tow
Happy trails
Mark
02-16-2012, 03:31 PM
Trailer: FunFinder
My experience has been, in order of best to worst:
fifth wheel
bumper pull with weight distribution and anti sway
bumper pull without WD or anti sway, but with correct tongue weight
bumper pull without WD or anti sway, inadequate tongue weight
As for tow vehicles, again best to worst:
heavy duty pickup truck ( F-350 super duty, dual rear wheel )
other pickup, 3/4 ton or 1/2 ton
passenger car with body-on-frame construction, solid rear axle
passenger car with uni-body and independent rear suspension.
In any event, no matter what you choose, if you are concerned with your own as well as other road users safety and are doing things in a responsible way, you will ALWAYS stay within the guidelines of the vehicle manufacturer when it comes to trailer towing capacity regarding weight and frontal area, tongue weight, axle and tire capacity.
Many folks believe in the "80% rule".....in other words, if your tow vehicle has a factory stated capacity of 10,000 pounds, you would only tow a load of 8000 pounds max. This gives you a reserve capacity, we'll call "safety margin". Pretty good guideline.
You will do well to leave a safety margin in all aspects ( total weight, axle weight, tongue weight, tire capacities ( both TV and trailer ).
I can tell you the percentage of load vs. capacity, regarding all weights and tire capacity of every single trailer/truck combination I drive on a regular basis. The more you know about your rig, the safer you will be able to operate.
Tires should be carefully chosen, and always operated at the appropriate pressure. Tire pressure should ALWAYS be checked when "cold" ( before being driven, or driven less than one mile). This is the stated method for tire inflation by every single tire company out there, so don't let anybody tell you otherwise. Example, if you are using load range C tires that have a stated pressure of 50psi, you should inflate the tire to 50psi COLD. If you were to check this inflation pressure again after maybe 20 miles on a warm day, the pressure might be 55 psi. This is normal, and you should not deflate the tire. To do so is incorrect and will result in an underinflated tire. When using normal air to inflate tires, a 10 percent increase from cold to warm is typical. Using pure nitrogen to inflate will have a slightly lower difference between cold and warm pressures.
It is also my opinion that drivers that are new to towing will do well to "get some training". This could be from a trusted source, as in someone who really does have a solid technical understanding of vehicle and trailer dynamics, and years of experience. That person can show you how's it's all done, from every step taken before pulling out of the driveway, to "what to do in an emergency". And again, in my opinion, you need good, solid information from someone who can explain things to you in a way that you can understand and put into play.
I'm sure others will chime in with some thoughts and perhaps some things I've forgotten !
george
02-16-2012, 06:31 PM
Thank you both. It sounds more and more like maybe I am tent person. I love being outdoors!
02-16-2012, 06:52 PM
Trailer: FunFinder
Cathy,
Don't take my post as discouraging you from going the "trailer route of camping". It's not that hard, and it's really not that technical. You can do this.....but it does need to be done right. I just hate it when I see folks acting in unsafe ways when it comes to these campers/motorhomes/tow vehicles etc.
The whole towing experience ( and certainly the camping experience ) can be a huge amount of fun. I actually enjoy the heck out of towing. I tow four different trailers at various times ( two horse trailers, a flatbed trailer, and a camper ) and I will admit, I have fun every single time I'm hooked up and moving.
I threw in all the details, because honestly, this is a situation where "the devil's in the details". Done right, towing is safe, fun, and does not have to be "white knuckle". And a key part of that process is having a good match between the tow vehicle and the camper. If they are mis-matched, you have .....well let's be charitable here.... a "less than optimal experience".
I camped for many years in a tent, and for a while we had a pop up. Now I have this little 19' hardside, and I'll tell you, the whole camping experience is ten times.....heck, maybe 100 times more enjoyable. Come back to the discussion....let's talk. Some other folks will chime in here soon I'm sure.
There are some really very cool little fiberglass campers available, that won't break the bank, can be safely towed with reasonable size tow vehicles. You don't need the one ton dually for them. We use it for the 33' four horse gooseneck, and the 28' flatbed. Those kind of tow vehicles are horribly expensive to buy and operate.....so don't get discouraged and think you have to have that for a small camper.
george
02-16-2012, 07:25 PM
Cathy don't let all the big numbers throw you off. Keep in mind that the numbers posted and experiences stated are not in reference to towing the smaller lighter fiberglass trailers that most of us are towing here. The poster has previously indicated he has only had one TT which is his current one and it appears it may weigh far more dry than most here do fully loaded with a months worth of gear. So what you experience in towing a small fiberglass trailer in regards to the handling by various vehicles may be very different than their experience has been in towing other trailer types.
One things for sure you don't need a 10,000lb tow cap to safely tow the majority of fiberglass trailers out there - not even a 5th wheel. ;-)
02-16-2012, 07:49 PM
Oh posh... if I can do it, you can do it. When I bought my trailer, I had only towed a small utility trailer ONE time... and it was only loaded with old furniture. I purchased my Scamp about 40 miles from home and had to get it home through Portland, Oregon rush hour WITHOUT brakes! Fortunately, the couple I bought the trailer from were kind enough to make sure it was hooked up properly and away I went. Granted, that first time was a white-knuckle experience, but I did it! When I finally got the trailer backed into it's parking space (took about 45 minutes and lots of sweat), I about dislocated my shoulder from patting myself on the back and the feeling of accomplishment was NIRVANA!
You go girl and don't let anyone, including yourself, convince you that you're not capable.
02-16-2012, 08:28 PM
POBox 1267, Denison, Texas
Hi, Cathy!
As I understand it, the fifth wheelers cut inside when towing. The bumper types do not and will track right with you. The fifth wheel set-up seems to be a more solid set-up but even many people with pick-ups do not want a fifth wheeler because of taking up the bed.
One of the big considerations on the bumper type is the width of the trailer. It seems that narrower is better for towing from what people have told me. We are going with a narrower (7') width trailer.
02-16-2012, 10:36 PM
Hi, Cathy!
Huh????
There is no such thing as a trailer that will follow exactly in the tracks of the tow tug. All trailers will leave their tire tracks further to the inside of the turn. So long as you remember that and make a wider turn than you would when you are NOT towing, you'll be OK.
General rule (applies to both 5th and straight tows)
The longer the wheelbase of the tow vehicle, the better it tows (and the harder it is to back the trailer!) The Smaller the trailer, the easier it is to tow and the harder it is back up with.
Narrower trailers usually have less wind resistance than wider ones so they might (if all else is equal - which it never is!) get better fuel economy. However, comfort and whether or not the layout suits you should be the deciding factor. Buying brand A because it is 6 inches narrower than brand B if you like everything else better about brand B is a sure cause of misery!
02-16-2012, 11:09 PM
Trailer: 13' burro, 13' casita, 20' nomad f/w
try reading this, also google trailer towing. How to back up a trailer
02-16-2012, 11:50 PM
Hi: Cathy P... Why I like the 5th. wheel is the hitch is located directly over the rear axle. The closer to the axle the better the tow... with any trailer!!! Also... the older I get the less I can bend down so the hook up is at eye level. It is easier to line up by your self too. Once the hitch arm is pulled, you back up to the pin and "CLANK". Plug in the umbilical cord, check the lights and away you tow!!!
02-17-2012, 12:06 AM
Hi, Dave!
Are you saying that if you tow a 7' wide trailer with a fifth wheel, it cuts in the same as towing a 7' bumper type? I did not say that it would follow exactly in the tracks. Of course, trailer size here means a lot.
A number of people who have owned Bigfoots and Escapes have told me that the narrower Escape tows much better and they seem to attribute much of that to the greater width of the Bigfoot. That is their experience. Maybe people have different ideas of what "tows well" means.
The towing ease is definitely one of my big considerations and may even outweigh the layout or size of the trailer. Everyone has his priorities.
Alf, I know you love your Fifth Wheeler!!
Carol, you are right for sure. What applies to those great big trailers is not necessarily the same with a small egg.
02-17-2012, 01:22 AM
I've towed an awful lotta trailers. The one that followed me best was a sticky that I owned many years ago - a Taylor Coach 15 footer.
The worst I ever towed (not counting a few home-made utility trailers) was a 13 foot Boler (much narrower and much lighter than the Taylor)
Just changing tires can make a "whee" of a difference. When I got my Boler 1700 it towed like a dream - it was very easy to forget it was back there. I took off the "many years old" bias-ply tires and put on a new set of radials. Turned it into an absolute cow! I could swear it gained many thousands of pounds and all in the wrong places. It wiggled and wagged and swayed back there and was very hard to pull - much harder on the tug than it had ever been before!
Switching to yet another pair of radial tires (different make) cured the sway and helped with the "heavy feeling" too.
Now I tow a Bigfoot 21 footer . It is very much like the original Taylor Coach - it can be quite quite dangerous because I keep forgetting it is back there !
You will know when a trailer "tows well' if you are heading down the highway at 70-75 mph and you glance in your mirror and it is a bit of shock to see that, yes, there IS a trailer there! If a trailer keeps "reminding you" in some way or other that it is there, then it does NOT tow well! Your towing experience will not be happy and you will not be happy with your decision to hitch on to that kind of trailer. You will regret going camping with it. you will regret buying it.
If towing is a white-knuckle experience then something is wrong. Wrong trailer, wrong tug, maybe just a combination where this trailer does not like this tug, but you are supposed to be doing this for relaxing, not for inducing stress.
I have also towed a lot of flatdeck trailers - some VERY heavily loaded and quite a few of the enclosed cargo-type trailers, again, some very heavily loaded. Some single axle, some twin, some triple axle units. The bigger the frontal area (both width and height) the more air resistance, and the heavier the trailer "feels". I have towed on trips of over 3,000 miles one way, so beleive me, I want one that tows comfortably - which is how I define "Tows well"
For what it is worth - the longer the distance from the hitch to the axle the better it tows. (And the more it cuts inside your turning circle)
The heavier it is, the better it tows. (on the flats.)
In all cases, lets assume the trailer is loaded correctly. Tail-heavy trailers are NOT good to tow - regardless of brand, tires or tug.
The bigger and heavier the tug, the better it tows (anything)
The only 5th I ever towed I cannot comment on as I have no basis of comparison. It was an unfamiliar trailer, hitched onto a pick-up that I had never driven before, so I do not know if it towed well or not. (and I didn't have to go very far with it, so again, no real experience!)
02-17-2012, 06:49 AM
Thank you all. Great input. I worked in the office of a 5-star, very heavy 5th wheel that did factory direct. We had people show up with under-rated pick-ups that had never towed before and older people, even older than me and one in his 80's. They got about a 30 minute prep with a tech and they were off either back home which was usually across the country since we were central US or to a full-timing adventure. Sometimes, the driver would be so nervous that it seemed unbearable to see them hit the road.
I think the poster was "floyd" and he talked about his experience with his 13' Scamp and how convenient that size was for him and it was an excellent post. I was "yes" I could do that!
I talked about "The Long, Long Trailer" and it truly does give someone something to think about in real life terms.
I am not and never will be an "RVer" but a "camper". Most likely that big, nice tent will go with my son to the service provider as they have said that they take the people (with developmental disabilities) camping - now you know this has to be a good service if we can snag the opening here shortly in their residential service.
Thank you again. I'm also a "better safe than sorry" person. OK, probably overly cautious. Extremely cautious!
02-17-2012, 08:01 AM
Trailer: actively shopping for a 5th wheel
Manitoba
Hi Cathy P,
I think that you could teach yourself all about driving trailers.
Experienced "towers" could give you help and hints, but you have to actually experience, get the idea set in your brain and get a feel for it yourself.
If you don't have a trailer, find someone that does and ask them to bring it to an open parking lot for you to practise and get a feel for this new experience. Find a parking lot someplace and pracise driving around things (maybe plastic garbage cans? not light standards), pulling up and parking beside things and backing up.
Take your time, don't get flustered, think it thru and I'll bet you figure it out.
Don't be afraid to pull ahead and correct your angle when you are backing up. You'll see what I mean when you start doing it. Also when backing up, if you crank your neck and watch your trailer, then switch over to the interior or outside mirrors, you will get confused at first. Try to do the same thing each time. Sharp trailer angles when backing up are hard to correct until you get experienced with your combination.
Don't be afraid to get your passenger ( if you have one ) outside watching where you are backing into - you should also get out before attempting to back into a spot and have a good look at where you are trying to go.
Shut off your radio and roll down a window so you can hear them yell STOP or 2 feet more, more to the left, etc.
None of this is hard, it's just a new learning curve. The more you practise the better you get at it. If you are pulling a trailer and it's properly set up, you will be amazed at how fast you adjust to having it behind you.
5th whls I don't know anything about - yet.
Wayne
02-17-2012, 08:12 AM
Rereading the original post, I don't really see an explicit question. I think the implicit question is "Can I do this?".
As others have said, yes, you can do it. You don't eat an elephant in one bite and don't become proficient in towing in one session.
02-17-2012, 03:31 PM
Cathy you as Donna and others have said you CAN DO IT! The first tow is always the worst but once you have done it a few times you will be a lot more comfortable. Yup there are tips and tricks that you should learn and others will be happy to share with you.
My worst tow ever - a horse trailer with one four legged passenger who liked to start a party dance and get his fellow 4 legged passengers to party with him..... dancing/moving cargo is never a good thing! :-))
02-17-2012, 04:40 PM
Name: Norm and Ginny
It's easy
Towing the smaller fiberglass trailers is easy. What's even nicer is that there are many people willing to help you.
When we started RVing 11 years ago we joined a local club and people volunteered to help us get started. There are certainly many people on this site that probably live close to you that would help you.
We've been to three fiberglass rallies and 90% of the people are helpful beyond anything one can imagine and really nice.
The only tough issue with a trailer is learning to back it in. It just takes time. When we started we would sometimes draw a crowd of watchers, someone always offered to help. Gradually we've become good at it and so would you.
If you are a decent driver you can tow a trailer.
All of us were beginners. Don't let the negatives scare you, it's all easy to learn and the rewards are enormous. Outside of choosing my wife, this is the best decision of my life, to hit the road, to relax a little, and see North America.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
02-20-2012, 04:31 PM
Trailer: U-Haul 1985
Cathy, I've got to be on the bottom rung of ability as far as backer-uppers go. But I tow my trailer and also back it up (kind of haha ) You'd be amazed how many campsites can be used as 'pull through' with these little trailers and you never have to even back up! You can also look at maps of the campsites and pick corner sites which have more manuvering room (as you can see from, my posting, I am not a 'practice, practice, practice' person). I never towed a trailer until I got my Uhaul and I do fine. If I see that people want to pass me, I slow down and let them go by. I changed my car for a small SUV (2wd Ford Escape) so I don't feel I'm pushing the limit of towing weights. It sounds like you've done your research, and hopefully you'll find the right trailer for you. Trailers don't come 'perfect', its the owner that makes it 'perfect' for themselves. You CAN do it. Good Luck!
02-20-2012, 04:45 PM
Thanks again everyone for taking the time to respond and I truly appreciate all comments and read them more than once and ponder them. As I thought about it, during the time we have been in campgrounds, I actually saw a few of the older eggs. My memory gets jogged each time I see a name that I had seen. They do draw attention in a campground just like a Prevost does - funny! Tom Thumb and a Giant? You'd do a double take? I just need to work up my determination and courage. Well, if I keep thinking about ending up like one of the very old neighbor ladies in their 80's at home with her cat...........14 cats more likely!
