towing - Fiberglass RV
Old 09-15-2017, 03:56 PM   #1
Trailer: Dutchman Lit
Iowa
towing
I have a 1972 Hunter Compact Jr that I am towing with my 2002 Lincoln Towncar but I can only go 50 or 55 or the camper starts to sway. Can anyone help me with what I might need. Thank you.
Rose Magner is offline   Reply With Quote
Old 09-15-2017, 04:33 PM   #2
I had one of those and it was so light in the tongue that It swayed terribly. After purchase I stopped at a big box store on the way home and bought 4 concrete blocks, placed two inside and two on the tongue. The trailer behaved well the rest of the way home.
All the weight is in the back on these trailers.
When I finished the trailer with more weight shifted forward It did just fine without the blocks.
I once forgot to put the rear stabilizers down with the trailer empty during rehab. When I stepped on the rear step the thing skidded out from under me like I had stepped on a skate board!
At any rate, I am sure that your problem is that the tongue is too light and/or too high (it should be level or slightly lower).
With your propane and battery and spare on the tongue, plus maybe a bit more stuff stored under the bed up front, you will discover a trailer which is pleasant to tow.
Old 09-15-2017, 06:45 PM   #3
Iowa
Thank you Sir. I am going to try that. It sure would be an easy fix...ROSE
Old 09-15-2017, 07:00 PM   #4
I recall another person bought several cases of water. I suppose it would depend on what kind of ballast might be most useful when no longer needed to hold down the front of the trailer!
Old 09-15-2017, 07:21 PM   #5
Bobbie Mayer's Avatar
I just carried some heavier things in front, under the bed, to prevent that in my Campster. You need about 10% of the weight on the tongue.
Old 09-15-2017, 07:51 PM   #6
Maybe a bit more in this case.
Old 09-16-2017, 09:31 PM   #7
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Yep, try to get your tongue weight up to about 130-180 lbs and it should tow straight. You can use a bathroom scale (and a vertical 2x4) under the ball socket to weigh it.
Old 09-18-2017, 06:22 PM   #8
Iowa
Hunter Compact Jr.
Weighed by camper today and it was 1780 pounds. I also weighed the tongue weight and it was 95 pounds. So do I need about 100 more pounds on the tongue
Old 09-18-2017, 06:37 PM   #9
Yes.
The light tongue doesn't surprise me at all, but I'm really shocked by the total weight. Was it packed for a trip? Has it been modified from stock? An unloaded, stock Hunter Compact Jr. should be well under 1500 pounds.
Old 09-19-2017, 04:10 PM   #10
Mike Magee's Avatar
I take back what I said, because you want at least 180 lbs of hitch weight. Adding a battery and/or propane tank to the tongue might be a way to get some of that extra weight.
Old 09-20-2017, 12:05 AM   #11
Borrego Dave's Avatar
Rose, Floyd mentioned in post #2 about the tongue level. You haven't said anything about your setup. The tongue should be level or a bit low at the ball. Being to high will cause sway. How about a pic of your rig hitched up and how you're towing it now?
Old 09-20-2017, 09:02 AM   #12
Mike Magee's Avatar
Well, if Rose adds 100 lbs to the hitch, it will change that angle because the tug will squat more. Might be better to have a pic after the weight is redistributed.
Old 09-20-2017, 02:13 PM   #13
That's true but I kind of wondered if her tow angle was way up like you see once in a while.
Towing Definitions-Understanding Towing weight terms cpaharley2008 Towing, Hitching, Axles and Running Gear 54 01-02-2024 09:43 AM
Towing like you're not even towing? swoosh Towing, Hitching, Axles and Running Gear 18 07-30-2015 09:18 AM
Liability and overweight towing (split from Towing 13' Scamp...) Bob Miller Towing, Hitching, Axles and Running Gear 88 04-18-2014 05:10 PM
Towing fifth wheel versus towing bumper hitch drstock Towing, Hitching, Axles and Running Gear 67 02-20-2014 02:04 AM
» Trailer Showcase
Bigfoot
Dot G
TED
Spanke
