Towing a Scamp 13 with a 4cyl Subaru - Page 2 - Fiberglass RV
Old 12-25-2006, 12:21 AM   #15
Well.... almost all cars do.
One of Dad's many VW Squarebacks with an auto did not.
That's only because it's hard to find that radiator on a older VW.
Old 12-25-2006, 12:35 AM   #16
John Perry's Avatar
Trailer: 1996 13 ft Scamp
Send a message via AIM to John Perry
Christi, I just dug out my old Burro advertising for the 1998 models. The advertised dry weight on the 17' was 1500 lbs with a tongue weight of 125 lbs without options.
Roger
The 99 14' Burro I just sold had an empty tongue weight of 170 lbs with a group 24 battery and a standard propane tank on the tongue. I think that the dry weights of the Burros are misleading. I will bet that my 14' weighed at least 1500 lbs. My fully loaded 13' Scamp and a 600 pound ATV in the back of my truck pulls much easier than my almost empty Burro. I realize the aerodynamics of the Burro is equivilant to that of a brick but I noticed the biggest differance on long uphill pulls.
Weigh your Burro Christi.
John
John Perry is offline   Reply With Quote
Old 12-25-2006, 11:25 AM   #17
Gina D.'s Avatar
West Coast USA
Those little Bajas sure are cute! I considered one when I recently was looking to purchase.
The color schemes alone make them desirable! That has nothing to do with towing or capability, but hey... they are different!
Old 01-01-2007, 09:21 AM   #18
Trailer: 16 ft Scamp
We tow a 16 ft. Scamp with our 2004 Outback. It has an automatic transmission and, as recommended in the manual, we usually use 3rd gear instead of Drive, especially in hilly country. We also periodically check loaded weights and tongue weight to make sure we're within the recommended ranges. I have the transmission fluid checked regularly and so far haven't had any problems. The owner's manual does have a warning regarding towing up long inclines in very hot weather, but we live in the east and don't run into those conditions. We are very happy with our setup and are glad that we don't have to have a separate vehicle for towing.
Mary Gessert is offline   Reply With Quote
Old 09-27-2011, 07:51 PM   #19
Trailer: Plans for a Lil Snoozy
Virginia
Hi, are you still towing your '16 with your Outback? We are considering a loaded '13 to tow with our 4 cylinder '09 Outback. Does your '16 have a shower and/or A/C?
Thanks,
Ken
Ken in SW VA is offline   Reply With Quote
Old 09-28-2011, 08:00 PM   #20
IllAnnoy
Thanks,
Ken
Not the Same but pretty much equivalent... Tens of thousands of miles towing with a 4CYL Ford Escape 5spd manual. Works well with our loaded 13 scamp deluxe front bath....
Old 09-28-2011, 09:12 PM   #21
Trailer: 1984 Scamp 13'
Maryland
When you say that you have the trans fluid "checked," are you sending samples to a lab, like Blackstone? Or are you just checking the fluid level?
-Jesse
Old 10-03-2011, 06:56 PM   #22
Maryland
So, I bought my Subaru Outback about a month ago. It is a 4-cylinder 2.5i Premium (170hp/170tq). I towed the Scamp for the first time today. Just about 60 miles. No mountains, but some small hills. It towed beautifully! I towed it before, as many of you know, with a 2009 Scion xD. I thought it towed pretty well with the xD, but it is a night and day difference! The CVT transmission is great -- you can set the cruise control and there is no shifting... the RPMs just go up if more power is needed, then go down when it isn't. The most it ever went up to was about 3,000 RPMs at 60 MPH. On flat ground, it went down to 1,600 RPMs or so. No jerky shifting or gear "hunting" like traditional automatics. Really smooth.
I can't wait to take it on a real camping trip in two weeks!
Old 10-03-2011, 11:29 PM   #23
Originally Posted by Brian B-P View Post
The 2006 Baja brochure doesn't list an optional package, or a restriction on towing capacity based on transmission type or equipment, so it seems like Subaru has not assessed transmission cooling as the limiting factor for towing.
When my Outback was new back in 07 I asked the Subaru servce manager (who also tows with his Outback) about needing a transmission cooler and was told at the time that Subaru does not make/offer them as an option. Was also advised that adding an after market one while the car was still under warrenty was not a good idea in the event that I did have a transmission problem - as they might point fingers at it. Have towed now for 5 years thousands of miles without one and have had no issues. Its an automatic but I do switch over the manual sport mode on hills etc. and I do have the transmission fluid changed.
Old 10-03-2011, 11:39 PM   #24
Jesse, glad to hear you are loving your Subaru! They are hard not to love.
I actually like the way mine tows as well & most of the time its easy to forget I'm towing. But if you come out West and hit some of our hills hummmm perhaps I should say MOUNTAINS I think you will find that it will start to hunt. But then thats when you will also learn to love the manual sport option!
Old 10-04-2011, 11:00 AM   #25
Maryland
Carol, what I mean about not hunting for the right gear is that my Outback doesn't have gears! It has the CVT transmission. Yes, it revs higher or lower, but there is no back and forth jolt between two gears when it can't decide which to be in. It just changes the RPMs vey smoothly to deliver the right amount of power. There are no "preset" gears.
-Jesse
Old 10-04-2011, 05:08 PM   #26
Mike Magee's Avatar
Trailer: Li'l Hauley
"A night and day difference"... in terms of drivetrain power only, or was there a strong difference in some other ways too (like handling, etc)?
You need to stop making me want a Subaru so much!
I'm just one step away from being
filthy rich. All I need now is money.
Old 10-04-2011, 06:22 PM   #27
Mike I was going to say just go and buy one and get it over with! :-))) but I see in your pofile what you are towing. Not sure on what the tongue weight is on yours but they tend to run a little heaver than the Scamps so it might be a problem with keeping it down to the Subaru limit - sadly the use of an equalizer hitch is a no go with the Outback.
Old 10-04-2011, 06:30 PM   #28
Maryland
It certainly had more power. The power delivery was very smooth, thanks to the CVT. The longer wheel add (than the previous car) surely helped take out some of the bumps, too. The AWD system helped on my gravel driveway. The hill holder feature works very well, too.
-Jesse
Subaru Outback Towing a 16' Scamp? Parker Buckley Towing, Hitching, Axles and Running Gear 51 11-04-2011 10:04 AM
Towing with a Subaru Outback james cronn Towing, Hitching, Axles and Running Gear 0 04-16-2009 03:13 PM
More Subaru Forester Towing Questions Michelle A Towing, Hitching, Axles and Running Gear 12 04-04-2009 10:18 PM
towing a 13' burro with a Subaru Forester Pamela H Towing, Hitching, Axles and Running Gear 5 07-23-2008 08:15 AM
Requests info re: Subaru towing capabilities Legacy Posts Problem Solving | Owners Helping Owners 8 05-07-2003 11:31 AM
