Towing a TAB 400 with a Ford F-150 - Fiberglass RV
Old 04-01-2019, 06:08 PM   #1
Trailer: TAB 400
Hello,
We are looking to purchase a TAB 400 trailer to tow with our 3.7L, 6 cyl. 2012 Ford F-150XL with 6 1/2 ft bed. The truck can tow a maximum of 5,500 lb. The TAB 400 maximum wet wt would be 3613 lb with all 3 tanks full. If we carried a 2nd propane tank, then the tongue wt would increase to 425 lb, which would be 12% of the total load of the trailer. The maximum payload capacity for this truck is 1,710 lb, so we could carry an additional 800 lb of excess gear, but not sure how close to maximum payload is advisable!
Being new to RVing, I'm not sure what type of trailer hitch to have installed. Also, not sure if I should have a transmission cooler and/or sway bar (single friction) installed. And lastly, would a Timbren "suspension enhancement system" for weight distribution be beneficial?
Thanks!
Hydrographer is offline   Reply With Quote
Old 04-01-2019, 06:29 PM   #2
John in Santa Cruz's Avatar
Mid Left Coast
don't forget driver and passenger(s) count as payload in the truck.
I'm seeing the Tab 400 has a GAWR: 3,500 Lbs, and max hitch weight of 460 lbs, so way I figure, thats 3940 lbs GWR... between bedding, clothes, towels, food, beverages, its real easy to come out a lot heavier than you might think.
I'd skip any WDH type system until you've towed it a couple times and see how it rides. if the front of the truck is 'pitchy' when you go over bumps, then you might want a WDH. or if the rear of the truck sags too much when you drop the hitch weight on.
btw, T@B's are not considered molded fiberglass, they are framed and skinned like a conventional 'stick built'.
hitch, sway bar
Ford f-150 questions dcs02d General Chat 2 08-28-2018 07:23 AM
Ford F-150 extended range fuel tank? War Eagle Towing, Hitching, Axles and Running Gear 13 05-31-2016 09:41 PM
Ford F-150 Ecoboost 2.7L vs 3.5L - Real world? War Eagle Towing, Hitching, Axles and Running Gear 14 05-21-2016 02:06 PM
Ford Agrees to Expand F-150 Recall by 1 Million Vehicles Donna D. General Chat 15 05-10-2011 11:07 AM
