Towing Accidents - Page 2 - Fiberglass RV
Closed Thread
Old 05-10-2012, 09:41 PM   #15
Originally Posted by David Tilston View Post
I am told that they are required in BC, if your trailer has brakes.
Well there is some confusion on that point! When I imported my trailer I had to take it for an inspection so I looked into the issue of what it had to have and whether or not a brake away switch was required. Talked with various government officials and got a few different answers!
At the end of it all what I discovered was that all commercial trailers that have brakes must have a brake away device regardless of weight. But the section that deals with recreational trailers under 1400 Kilograms (3087 pounds) does not actually mention a brake away devise. But if the trailer is over 1400 Kilograms it does need brakes and a breakaway device. When I went in for the inspection I was told it wasnt required due to the weight of my trailer even though I had brakes on it. But to be honest having a brake away switch on a trailer under 1400 Kilograms is not a bad idea regardless.
Carol H is offline
Old 05-10-2012, 09:50 PM   #16
Originally Posted by honda03842 View Post
george,
In one case a boat fell off a trailer.
I have seen that SO many times! Usually on I-5 in Seattle area. (No idea why, but it seems that about every third time I go through Seattle on I-5, I see another one - usually between Federal Way & Fife areas) In a couple of cases I've seen the trailer stay attached to the car/truck/SUV and in (what seems to be) perfect condition, but there's the boat sitting there in the third lane, or on the median.... Didn't the guy tie/strap/hook it to the trailer? At all?
Usually they are pretty nice looking boats, too!
BCDave is offline
Old 05-10-2012, 10:44 PM   #17
Jeff Richardson's Avatar
Trailer: 1977 13-foot Scamp
Here's a link to etrailer.com break away kits. All come with a small 12v battery to activate the brakes. This would be necessary on a trailer that didn't have a battery such as cargo, heavy equipment, etc.
etrailer.com - Products Trailer Breakaway Kit breakaway kit
At the recent Spring NOG I saw breakaway switches on the Escape trailers that I looked at. I've never seen one on a Scamp as built by the factory.
I'll put one on mine when I get the brakes working. It looks like they cost $7.00 to $10.00. I'll use the trailer battery to activate the brakes.
Jeff
Jeff Richardson is online now
Old 05-10-2012, 11:32 PM   #18
Unfortunately boats off the trailers is not an uncommon sight on Vancouver Island as well. LOL
Carol H is offline
Old 05-11-2012, 08:59 AM   #19
Trailer:
I am told (have no evidence) that there is move afoot to ban surge brakes on trailers due to the risks of a trailer running away following a break-away.
Yurpeen trailers have cable-operated or rod-operated mechanical surge brakes and it's been compulsory to have a (mechanical, not electrical) breakaway cable for decades. The trailer end of the cable is attached to the handbrake lever so if the trailer breaks away, the handbrake is locked on by the cable before the cable snaps.
Andrew Gibbens is offline
Old 05-11-2012, 09:13 AM   #20
IllAnnoy
I went to look for "safetrailers.org" and it was no surprise that there simply is no such thing.
I was refered to "dangeroustrailers.org" where I did find the video below.
I must warn you that it is another redundant safety device and the use of all available ones may subject your trailer to a dangerous overload!
It is interesting though,I only wish they had shown exactly how it is attached....
floyd is online now
Old 05-11-2012, 09:19 AM   #21
Trailer: 1975 Boler
Evan Friesen is offline
Old 05-11-2012, 09:44 AM   #22
Trailer: Fiber Stream
The "dynamite pack" was one of things that was tested along with proof that ALL wheels had brakes, plus coupler was rated for a minimum of "X %" above trailer's certified gross weight, plus trailer-rated rims, plus trailer-rated tires, plus, plus, plus etc.
My Fiber Stream was manufactured with Brakes on the front axle only, although each axle (and the Brakes) is rated for the full GVWR of the trailer. My Compact Jr. does not have Brakes.
Frederick L. Simson is offline
Old 05-11-2012, 10:37 AM   #23
LOL What is interesting about the video to me is it appears that they have attached their brake away switch to the trucks hitch assembly - our perhaps I just need to clean my glasses. Most of the install instructions that I have seen for a brake away switchs say you are not suppose to attach it to the hitch assembly, instead its to be attached to the frame of the vehicle towing. hummmmm
Carol H is offline
Old 05-11-2012, 11:32 AM   #24
Here's a video for those who like to think that small fiberglass trailers & tow vechiles dont often have serious accidents. Hopefully no one was hurt - based on the amount of traffic on that highway they were lucky not to have been hit by someone else.
There is also a party on this list that purchased a pretty new fiberglass trailer from a salvage company a couple of years ago after it had been written off by the insurance company due to being seriously damaged as a result of a roll over or flop over. Havent looked but there may still be photos of what that looked like after the accident.
So people towing small fiberglass trailers do indeed have accidents. Maybe they dont happen to often or perhaps its simply that they dont make the press as often - but when they do happen it doesnt make them any less dangerous.
Carol H is offline
Old 05-11-2012, 11:34 AM   #25
for those towing with small vehicles small trailers.
Carol H is offline
Old 05-11-2012, 01:22 PM   #26
honda03842's Avatar
Name: Norm and Ginny
Purpose
There were two purposes to this thread:
1. to show how we each can reduce the chances of having a serious accident,
2. to show that the bulk of trailer accidents seemed to be loose utility/construction trailers where the trailer came loose.
Of course there are travel trailer towing accidents, though travel trailer accidents do seem to be rare.
I suspect that the primary cause of travel trailer accidents is the lack of knowledge among beginners and even experienced towers. I think the sum of knowing the little things, of paying careful attention can make a big difference... definitely the installation of a break away switch on small trailers can make a difference on braked trailers.
My hope was that this thread might generate additional suggestions on how to reduce the chances of accident and to improve the safety of towing. Since loose trailers seemed to be the primary cuase of accidents.
Jim's (CPAHarley2008) response about the ball lock was what I was hoping for plus all the positive responses on break away switches and the surge brake solution (something I was totally unaware of).
What tips would you give to a newbie about towing safely?
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
honda03842 is offline
Old 05-11-2012, 01:33 PM   #27
Trailer: 1984 Scamp 13'
Maryland
I just wish our couplers were as nicely designed as European ones. Most of their trailers have cable or rod actuated brakes with PARKING brakes! Also, many of the couplers have a green "flag" that pops up to tell you that the coupler is locked to the ball. Most of our couplers are just cheap stamped metal waiting to rust apart.
-Jesse
mcbrew is offline
Old 05-11-2012, 02:13 PM   #28
Trailer: gave up!!
Carol, I honestly haven't seen anyone on this site even suggest that small fiberglass trailers don't have accidents...
John_M is offline
Closed Thread
Towing Accidents honda03842 Towing, Hitching, Axles and Running Gear 27 03-20-2011 08:02 PM
towing with these anyone? Bruce Thomas Towing, Hitching, Axles and Running Gear 24 02-19-2011 11:55 AM
Towing Jamie Towing, Hitching, Axles and Running Gear 20 08-15-2007 05:16 AM
towing ?? Christi V. General Chat 5 07-22-2006 12:14 AM
Towing Legacy Posts Problem Solving | Owners Helping Owners 10 11-23-2002 07:42 PM
