Towing an Escape 19' - Page 2 - Fiberglass RV
Old 08-06-2012, 02:02 PM   #15
Trailer: 19 ft Escape ( aug 2012)
i believe that the spec i got from castrol for there synthetic oil is 250 f as a top end temp.
DMAC1 is offline   Reply With Quote
Old 08-06-2012, 02:54 PM   #16
honda03842's Avatar
Name: Norm and Ginny
Oil Temoperature
What temperatures are you reading when you say "high oil temperatures"?
Thank you
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 08-06-2012, 03:16 PM   #17
cpaharley2008's Avatar
If I recall, around 220 and if I remember correctly 212 is boiling temperature for water, not sure for oil. Note the pressure gauge is always in the middle or normal, radiator temperature also in middle or normal. Just do not know what is normal is for oil temperature.
Old 08-06-2012, 03:40 PM   #18
The flash point for synthetic oil is over 400 F the operating temp depends on many things including air conditioning adding load.
For turbos needing higher operating temp its perfect.
Old 08-06-2012, 03:57 PM   #19
honda03842's Avatar
We drove across the Cascade Mts today from Seattle and I took the opportunity to see how the air conditioner affected the engine as we were rolling in a down hill section.
Turning the air conditioner on caused the % of Engine load to increase from about 25% to 31% when the AC was activated... my foot was off the accelerator, we were in neutral coasting down hill doing about 60 mph.
This was a long day for us, about 175 miles. We drove between 55-60 mph in relatively light traffic, I guess anything would seem light after leaving Seattle.
Unfortunately the CRV does not report oil temperature, though on the 30-40 mile up hill crossing of the Cascades, the coolant temperature rose to 203 F on one occasion, generally staying in the mid 190 F range for most of the run. Temps are in the high 90's today.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 08-06-2012, 09:15 PM   #20
IllAnnoy
I use mineral based oil or a parasynthetic in my cars, and in forty years of towing and hard driving, I have never had a part which ran in oil show wear.
Pure synthetic oils such as MOBIL 1 are possibly the best oil available and give greater shear strength than simple refined oil and an extra measure of protection, but all modern engine oils are far superior to what was available even a few years ago.
To avoid damage on modern engines I would say be concerned about any code which warns of a lean condition under a load,any misfire codes and also be aware of hard engine braking.
Keep your fuel system clean and change the air and fuel filters as needed.
WARNING...COMMERCIAL!....
For modern fuel injected gasoline engines
Use CHEVRON ProGard Fuel injection cleaner(techron) every 10,000 miles to avoid the fuel problems which range from poor performance to oil contamination.
Old 08-07-2012, 05:40 AM   #21
Raz
Raz's Avatar
Vermont
........ also be aware of hard engine braking.
I'm not sure what you mean. Is high rpm the concern?
Old 08-07-2012, 10:50 AM   #22
IllAnnoy
Using a lower gear while descending a grade is fine as long as it is kept within reasonable limits. Brake first, then downshift or downshift before you start a steep descent to keep the engine within normal operating range.
Hard downshifting along with high RPM decelleration increases the stress and heat on the valvetrain, especially on the exhaust valves and seats.
Old 08-15-2012, 06:18 AM   #23
Here are some numbers from my last trip. Coolant Temp 194, Oil Temp 214, Trans temp 152. These variant no more than 10 degrees regardless of outside temp, going up or down a mountain, or plain level towing. I'll have to check it while not towing and report back. Oh, my mpg dropped from 15.5 to 13.5 due to going and being up at higher altitudes
Old 08-15-2012, 07:46 AM   #24
Trailer: FunFinder
This is going a little bit OT for this thread, but since the discussion has drifted towards the idea of oil temps and oil breakdown, etc, I'll throw this out there. If you really want to know what is happening to your lubricants ( and your engine ) from a long term standpoint, then one way of quantifying it is to have a sample analyzed from a lab. I use Blackstone labs and do an occasional sample thru them. It's not cheap ( $25, or $35 if you want the TBN test done also ), but it is an interesting way to keep tabs on what is going on in your engine. My most recent test from the 4.0L Frontier engine came out excellent. Mobil One, that had run 6700 miles, about half of which was towing.
One advantage of a lab test is that it takes all the guess work out of the process, and puts all the subjective comments ( like: "my oil choice is better than yours !" ) in their place as just that: subjective. The lab test is true data, and it does not care what the name on the bottle is.
gmw photos is offline   Reply With Quote
escape
Now towing a 19' Escape! Cathi General Chat 44 11-17-2013 01:29 PM
Ford Escape Factory Towing Package SurfsideEd Towing, Hitching, Axles and Running Gear 38 03-26-2013 06:43 PM
new Escape Mike Magee General Chat 16 03-21-2011 08:11 PM
First Escape in our Escape! Penney H. & Mike E. General Chat 6 05-07-2009 05:46 AM
Like to see Escape Ken Tucker General Chat 2 08-07-2006 10:47 PM
