Cut and pasted from other websites
Understanding RV Weights
For the safety of your family and others around you, it is crucial to understand and stay within the
weight ratings of your RV and tow vehicle.
Vehicle and trailer
weight numbers
fall into two categories:
Actual weights: Measured
weight of the vehicle or its components. Factory quoted weights may be averages or estimates of actual weight.
Ratings: Weight ratings are limits placed on the vehicle or its components, which should never be exceeded.
DISCLAIMER: While we believe that all information on this web site is accurate, we can not guarantee that it is applicable to You specifically or to Your situation.
The most common confusion about weights occurs when the two above categories are mixed.
GVW: Gross Vehicle Weight Gross Vehicle Weight (GVW) is the actual weight of the fully loaded vehicle or trailer, including all cargo, fluids, passengers, and optional equipment, as measured by a scale.
If you are in a motor home and not towing anything, the GVW is the total weight of the RV and everything in it. If your RV is composed of more than one unit (towing a trailer or a vehicle), then the GVW is only part of the total.
The GVW is important because without this number you can not determine if you are within the limits set forth by the manufacturer, laws, and regulations. This number can be approximated based on information provided by the manufacturer or dealer, but the only way to be sure is to drive the RV on a scale and measure it.
GVWR: Gross Vehicle Weight Rating Gross Vehicle Weight Rating (GVWR) is the maximum number that the GVW or GTW should never exceed. GVWR is applied to trailers as well as vehicles, but you may see this rating referred to as the Maximum Loaded Trailer Weight.
GTW: Gross Trailer Weight Gross Trailer Weight (GTW) is the same as Gross Vehicle Weight (GVW) when referring to a trailer. While GVW can be applied to tow vehicles and trailers, GTW makes it clear that we are speaking of a trailer.
When connected, a portion of the trailer's weight is transferred to the tow vehicle through the hitch. In this case the GTW includes all
axle GAW's and the Tongue Weight or King Pin Weight.
When not connected to the tow vehicle, the trailer's weight rests on its own
tires and on all deployed support and stabilizing jacks. If you are
weighing a trailer without the tow vehicle, be sure to place the entire unit on the scale, including all jacks.
GCW: Gross Combination Weight Gross Combination Weight (GCW) is the actual weight of the fully loaded tow vehicle plus the towed vehicle (trailer, car, boat, etc.), including all cargo, fluids, passengers, and optional equipment.
If your RV is composed of more than one unit (towing a trailer or a vehicle), then the GCW is the total weight of all connected vehicles and every thing in them.
Again, the only way to accurately determine the GCW is to drive the entire assembly on a scale. You may also determine the GCW by adding up the individual GVW's of all components.
If you weigh the components separately, make sure that they are configured and loaded exactly as you will be when traveling.
GCWR: Gross Combination Weight Rating Gross Combination Weight Rating (GCWR) is the maximum number that the tow vehicle GVW plus towed vehicle GVW (or GTW) should never exceed.
GAW: Gross
Axle Weight Gross
Axle Weight (GAW) is the actual weight placed on a single axle. Assuming a well-balanced vehicle, the GAW is then evenly distributed to all
tires on that axle.
In addition to the axle weight rating, the GAW must be within the tire weight ratings as well. To determine the amount of weight placed on each tire, divide the GAW by the number of
tires on the axle.
You may see the more specific RGAW, when referring to the rear axle, or FGAW, when referring to the front axle.
GAWR: Gross Axle Weight Rating Gross Axle Weight Rating (GAWR) is the maximum number that the GAW of a single axle should never exceed. You may see the more specific RGAWR, when referring to the rear axle, or FGAWR, when referring to the front axle.
Tongue Weight or King Pin Weight Tongue Weight (also called Tongue Load) is the actual weight pressing down on the hitch ball by the trailer. The recommended amount of Tongue Weight is 10-15% of the GTW.
King Pin Weight (also called Pin Weight) is the actual weight pressing down on the fifth wheel hitch by the trailer. The recommended amount of King Pin Weight is 15-25% of the GTW.
These weights are added to the tow vehicle's GVW.
Curb Weight Curb Weight is the actual weight of a vehicle or trailer including all standard equipment, full fuel tanks, full fresh water tanks, full
propane bottles, and all other equipment fluids, but before taking on any persons or personal cargo.
We have seen the following variations to this definition:
Includes driver
Includes optional equipment
Pay close attention to how the manufacturer defines Curb Weight because this is often used to calculate other weights, such as the cargo carrying capacity or Payload.
Dry Weight
Dry Weight is the actual weight of a vehicle or trailer containing standard equipment without fuel, fluids, cargo, passengers, or optional equipment.
Includes commonly ordered optional equipment
Includes fluids of
generator and other on board equipment (oil, coolant, fuel)
May or may not include RV batteries
Pay close attention to how the manufacturer defines Dry Weight because this is often used to calculate other weights, such as the cargo carrying capacity or Payload.
UVW: Unloaded Vehicle Weight
Unloaded Vehicle Weight (UVW) is the weight of a vehicle as manufactured at the factory. It includes full engine and
generator fuel tanks and fluids, if applicable. It does not include cargo, water,
propane, or dealer-installed accessories. Be aware that some manufacturers weigh each unit to determine UVW, while others provide only the average or estimated weight for each model.
Includes actual factory installed options
Includes commonly ordered factory installed options
Pay close attention to how the manufacturer defines UVW because this is often used to calculate other weights, such as the cargo carrying capacity or Payload.
Cargo Weight
Cargo Weight is the actual weight of all items added to the Curb Weight of the vehicle or trailer. This includes personal cargo, optional equipment, and Tongue or King Pin Weight.
This number is important because it will determine how many things you can safely pack into your RV. Within this number you need to fit the weight of your clothes, shoes, linens, books, dishes, beer, cleaning supplies, computer equipment, hiking gear, bicycles, water sport implements, food, beer—basically everything you want to take with you.
Payload Even though it does not include an R, Payload is a weight rating. It is the maximum weight that persons plus cargo should never exceed.
Payload is derived by subtracting Curb Weight from GVWR. In other words, the difference between a vehicle with standard equipment and the maximum allowed weight.
source of information
http://www.airsafehitches.com
