towing options w/ ford ranger - Fiberglass RV
Old 04-04-2008, 09:08 AM   #1
hello everyone,
i have a 2.3 L 4 cylinder (not much i know) ford ranger regular cab short bed with a maximum trailer limit of 2240 lbs. searched for posted info, but need help with specifics concerning my ford ranger. my options are limited ( probably to just a pop-up) but am looking a casita patriot standard, 13' scamp, maybe a teardrop, and the little joe or ponderosa by weis craft. Will any of these rigs "safely" work?
Justin, M is offline   Reply With Quote
Old 04-04-2008, 09:47 AM   #2
Booker B.'s Avatar
Trailer: 1976 Trillium 13 ft
You would be surprised at how heavy some popups are, a friend purchased one to tow behind his GMC tracker, turned out it was over 2000lbs unloaded. With that truck you could pull any of the 13' scamps/casitas/bolers with no problem.
Old 04-04-2008, 01:19 PM   #3
Pete Dumbleton's Avatar
At 2,400 lbs I agree with Booker with this caveat -- Not with ALL the options, like a/c, big reefer, awning, etc. One of the Scampers has a 13' that weighs about 2,200 lbs loaded for the road. When I was FullTiming, my 91S13 weighed about 1,700 lbs. Yer gonna have to watch yer weight.
I find it amusing that on RV.NET when someone with less than 3,000 lbs capacity comes on they say you can't tow a trailer, just a pop-up. Pop-ups can get extremely heavy. Small package folded, but dense, and many of the frames can't do WDH...
Old 04-04-2008, 08:26 PM   #4
Thanks guys, I honestly think the pop up rig would be my last resort, but if i were to go that route i was looking at the quicksilvers by livin lite
Old 04-04-2008, 10:29 PM   #5
Just discussing them the other day. Watch the set-up video and picture setting up in a hard rain with wind blowing...
http://www.livinlite.com/video.php
That said, if one goes out to rustic sites and stays for a while, not moving every day or so, there's nothing like a pop-up for feeling close to the outdoors, with the sides zipped down and all. With a trailer, you are inside something parked in the woods, with a pop-up you are in the woods.
Old 04-05-2008, 09:40 PM   #6
Sandra Lair's Avatar
Trailer: 1982 Scamp 13 ft
We tow our 13' Scamp with a Ford Ranger. It has a transmission cooler. We can hardly tell the Scamp is behind us. It tows well and stops easily. I wouldn't try to tow a 17' with it but we are comfortable with how it handles our Scamp.
Sandra
Sandra Lair is offline   Reply With Quote
Old 04-05-2008, 10:10 PM   #7
Sandra
Really? Is your ford ranger a 2.3 L 4 cylinder or 3.0 L v6, I am looking at the patriot or 13' scamp (specifically the ones with the bathroom and shower) and am hoping that my ford ranger can tow it. I would probably have to get a transmission cooler. Thank you
Old 04-06-2008, 01:09 PM   #8
If you have an auto-trans, I recommend an auxiliary cooler. If you have a manual trans you don't need one because manual trans are nowhere near as susceptible to heat damage as auto trans; just a box of gears in oil like axle differential.
My Ranger (4.0L V6) has bigger autotrans, aux coolers for trans and power steering, bigger differentials and separate relay for trailer lights.
Old 04-06-2008, 06:27 PM   #9
Bill F.'s Avatar
Trailer: 92 Bigfoot 13.5 ft / 05 Freestar
hello everyone,
I have towed several different 13' trailers(currently have a 92 Bigfoot) with my 98 Mazda 2.5L four(119 hp) automatic. Two years ago when it had over 180 km on it we pulled the Bigfoot through 3000' passes in Vermont without incident. If you have an automatic a trans cooler is a must and I wouldn't go without electric brakes.
Bill
Bill F. is offline   Reply With Quote
Old 04-06-2008, 08:36 PM   #10
If it wasn't already understood, YES brakes. Six braked wheels better than four, regardless of tow vehicle, plus one has the option to apply trailer brakes with controller if trailer is having problems.
BTW, I have read in numerous places that a plate & fin cooler, such as this one,
Plate & Fin
is more effective than a tube & fin cooler,
Tube & Fin
The above are just types, not recommendations. Google is your friend.
Old 04-07-2008, 10:08 AM   #11
Electric trailer brakes and trans cooler ( plus a reciever hitch) would definetely be needed, but I believe my main question is if the ranger would be capable...meaning is this truck big enough with respect to the engine size and other variables for a 1400 lbs or 1700 lbs trailer ( dry weight but realistically more, but no more than trailer axle limit of 2200 lbs) *reminder* ranger owner manual states max trailer weight is 2240 lbs. ,
Old 04-07-2008, 02:26 PM   #12
If your OM says 2240 lbs towing capacity for your truck with its engine, tranny, body and differential ratio, then 1,700 lbs is a good match. It's not just pulling, it's also stopping and steering.
Old 04-07-2008, 02:40 PM   #13
I agree with you Pete, 1700 lbs seems a good match. That is what I had in mind, but wanted a second opinion considering I have not done any towing with the ranger and do not know what to expect specifically with a small 4 cylinder truck. Im wondering now if the bath version for the 13' scamp would be the way to go or would it be better to stick to standard 13' scamp or standard casitas patriot.
I was also interested in those little rv's by weis craft, but i am curious to its quality and owner review and such. I did some research on them on these forums but would like to know more.
Pete, how do you like your scamp and what options do you have on it?
Old 04-07-2008, 07:45 PM   #14
I just checked & our Ranger is the 6 cylinder.
Sandra
Towing with a Ford Ranger 4X4 4.0L Tom H. Towing, Hitching, Axles and Running Gear 4 06-10-2009 06:03 AM
Selling our Egg Hauler, Ford Ranger Adrian W Classified Archives 0 03-20-2009 10:26 PM
Ford Ranger mileage Bonnie Witt General Chat 6 01-15-2007 09:37 AM
96 Ford Ranger for sale Shelley Classified Archives 0 01-09-2006 10:29 AM
