Towing package and tongue weight - Fiberglass RV
Old 04-01-2009, 04:29 PM   #1
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
I was looking at a RAV4 today at the dealer. The manual said the tongue weight limit was 200 lb but mentioned a factory "towing package" option for only $160 which increased the limit to 350 lb. They could not tell me anything about this package. I'd very much like to know what it entails because I'd like to increase the tongue weight capacity on my current TV. Anyone have any knowledge about it?
Old 04-01-2009, 04:52 PM   #2
Name: Laura & Rick
Trailer: Had an Escape 21 ft
I have a Highlander with the tow package. The RVA4 tow package is similar to the Highlander’s. The tow package consists of heavy-duty radiator with an engine oil cooler, 200-watt fan coupling, transmission oil cooler, 150 amp alternator and "pre-wire harness." Toyota does not list the tongue weight limits for the Highlander, only towing capacity. With the towing package, a Highlander can tow up to 5,000 pounds. Without the tow package, the limit drops down to 2,000 pounds. The Highlander is a '08 model earlier models had lower limits. Hope this helps.
2014 Escape 21
2008 Highlander
Laura & Rick is offline   Reply With Quote
Old 04-01-2009, 07:24 PM   #3
All that for $160? That's a deal (I'd like to see it in writing before I forked over the money tho). A heavy duty radiator would cost that much in the difference. If this is all true for that price... GET IT!
Old 04-01-2009, 07:30 PM   #4
WaltP's Avatar
SW Virginia
I have a Highlander with the tow package. The RVA4 tow package is similar to the Highlander's. The tow package consists of heavy-duty radiator with an engine oil cooler, 200-watt fan coupling, transmission oil cooler, 150 amp alternator and "pre-wire harness." Toyota does not list the tongue weight limits for the Highlander, only towing capacity. With the towing package, a Highlander can tow up to 5,000 pounds. Without the tow package, the limit drops down to 2,000 pounds. The Highlander is a '08 model earlier models had lower limits. Hope this helps.
Thanks, that helps a lot. Donna's right, well worth it.
Walt
Old 04-01-2009, 09:47 PM   #5
Pete Dumbleton's Avatar
I'd bet that $160 is the difference in price between two new vehicles!
Tongue weight is usually not specified for vehicles, except the ones with very low towing capacities, because it is part of the 'payload' or cargo weight, with the hitch equipment being part of the curb weight.
weighing, weight
Dealer or aftermarket towing package? Ron Stewart Towing, Hitching, Axles and Running Gear 9 03-22-2009 10:40 PM
Do you have a SMALL SUV with a factory towing package? Karalyn Towing, Hitching, Axles and Running Gear 54 12-28-2008 10:15 PM
tongue weight Rob M Towing, Hitching, Axles and Running Gear 10 01-10-2008 07:26 AM
Tongue-weight and level when towing Bobbie Mayer Problem Solving | Owners Helping Owners 7 09-08-2007 12:27 PM
Do you have a SMALL SUV with a factory towing package? Karalyn Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
