Towing with a 2000 Ford Ranger 3.0 Auto - Fiberglass RV
Old 05-07-2015, 05:36 PM   #1
Hi folks, I have been looking at Scamps for a while since I think I can tow one with my Ranger. The problem is the bed size. I just found out that the 17' Casita has a larger bed (I am 6'2"....bump my head or sleep well). The Casita weights a bit more 2500 lbs. but is still considerably under my rating for the ranger.
Anyone towing one with a Ranger out there?
Thanks,
Bob
mgbbob is offline   Reply With Quote
Old 05-07-2015, 05:46 PM   #2
All Casitas and Scamps are 6'8" wide, so bed length is the same in all of them, about 76". Difference is the width, which gets complicated. Casita 13' and 16' models have a 45" wide bed, while the 17' has a 54" bed. Scamp Deluxe (wood interior) models have a 54" bed. Scamp Standard (fiberglass interior) models have a 45" bed, EXCEPT starting 2014 a 54" bed is an option in the 13' Standard (but not in the 16' Standard). Clear as mud?
A Casita 17D weighs about 3300 pounds loaded, and averages 425 pounds on the hitch. I'm thinking that might be overweight for your Ranger. See Trailer Weights in the Real World for information on actual towing weights. A Scamp 16' Deluxe would be more like 2600 pounds loaded.
Old 05-07-2015, 06:04 PM   #3
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Bob, I have an '02 Ranger 4dr 4.0 v6 auto and tow an SD 17 and it pulls it well. No WDH but did add Timken rubber helpers on the rear as Rangers tend to squat with a load. Just did a trip with 50mph crosswind gusts through the mountains and the trailer tracked fine. My TW is #364 ready to go. I also travel with a full fresh water tank which is in the rear, helps take a few pounds off the tongue. Not sure how much your truck is rated at, mine is #5850.
Old 05-07-2015, 08:14 PM   #4
Trailer: Scamp 19 5'er
Thanks,
Bob
Bob:
I bought a package deal last fall....a 2002 Scamp 19' Deluxe with a 2004 Ford Ranger 6 cyl. 3.0L, automatic transmission. I found the Ranger lacking in power. It would pull the Scamp, but it wasn't pretty!! And, the gas mileage just coming across the Plains was atrocious!! Another issue for me is that I live in Colorado and need some power to make it up the mountains. I haven't weighed my Scamp, but it's listed for a total weight of 2800 lbs on the list developed on this forum (I think). You can search for "Trailer Weights in the Real World" and find the list.
I've since modified the hitch, raised the camper 4", and now pull the camper with my Dodge Ram 1500 5.9L. This is much nicer.
Best of luck in your search....
piperjim
piperjim is offline   Reply With Quote
Old 05-07-2015, 08:51 PM   #5
I have a 2011 Ranger with the bigger 4.0 engine. I recently got a Casita 17 spirit deluxe and towed it home from NoCal up to SW Warshington. I've since gone other places and yes, the gas gauge moves quickly, but the comfort of the trailer is worth it. And yes, it slows down going over the pass, but I don't punch it to keep it up to speed and even slowing down, I am going faster than the loaded semi trucks on the pass.
So, yes, a Ford Ranger can pull one.
slowpat is offline   Reply With Quote
Old 05-07-2015, 11:01 PM   #6
IllAnnoy
My 15 year old Ranger(4.0L 5spd manual) is approaching 170,000 miles, about half of them with a trailer attached. Car dolly, car trailer, utility trailer and dozens of Rv trailers, plus an occasional chain or tow strap.
I don't open the hood between oil changes except to jump start someone else's stranded vehicle.
This past February I made my annual 3000 mile trip to Southern Florida with my Scamp13D in tow, crossed Monteagle at the speed limit with the cruise control engaged. Of course the total payload was only about 2500-2700 pounds.
Total trip fuel consumption 18.5 MPG.
I'm expecting another 15 years if I live that long!
Last I checked, Scamp still owned their mid nineties 3.0L Ranger which has been used to deliver Scamp 5ers for a couple of decades. That is a much lesser engine than the late model 3.0.
Old 05-08-2015, 05:34 AM   #7
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
What year is the Ranger and does the transmission have a "S" (Sport) mode?
With a 2014 Ford Escape 2.0L Ecoboost FWD, and with the transmission in Sport mode,
we didn't even slow down going over Donner Pass and over the continental divide (pulling a Scamp13).
Sport mode puts the 2.0L I4 Ecoboost into the 2150 to 2250 rpm range where that engine develops much of its 270 lb-ft of torque. Even going through the foothills and mountains, fuel economy was still 20+ mpg.
For towing, and especially in the mountains, I believe it might be pretty important to run
at an rpm that will produce high, nearly optimum torque. (Of course, I could be wrong. 😉 )
As always, YMMV. 😉
Ray
rdickens is offline   Reply With Quote
Old 05-08-2015, 07:55 AM   #8
I'm not a motor head. I try to conserve gas going up over our White Pass so I'm going around 40 or 45 on the steeper grades. I could kick it in and go faster but then the gas consumption increases. Oh, the speed limit is 50 on that stretch and I'm usually in no big hurry. Chances are I'll get stuck behind the Drinkamugamilkaday truck or another type because it is a two lane road with very few passing lanes.
Old 05-09-2015, 04:06 AM   #9
Name: Ben and Janie
Trailer: 2013 16foot Scamp tug 2003 Ford Ranger
Kentucky
I pull a Scamp 16 ft layout 4 with a 2003 3.0 extend cab Ranger with a automatic transmission 3.73 ratio rearend it does a great job get 14 -15 MPG towing 17-18 not towing the truck bed is loaded when towing Scamp weights 2500 lbs I have pulled the camper over the Smokies on I 40 with no problems run 55 - 60 mph while towing
Ben and Janie is offline   Reply With Quote
Old 05-09-2015, 06:24 AM   #10
Towing with a Ranger
Thanks for the information. Some person told me to use 80% of the rated towing rating as a maximum for the vehicle. From what everyone has kicked in here I think that is probably right on target. I think I must look at a trailer in the 2500 max range for the Ranger.
Old 05-09-2015, 07:49 AM   #11
honda03842's Avatar
Name: Norm and Ginny
I have no idea where the 80% rule comes from. It assumes that the manufacturer puts no margin in his number.
As a rule of thumb, in Europe it is common to say that tag-along trailers should weigh no more than 80% of the tow vehicle weight. This has nothing to do with the rating of the tow vehicle.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 05-09-2015, 08:15 AM   #12
IllAnnoy
Rangers can be rated at over 6000 pound tow capacity.
Old 05-09-2015, 09:07 AM   #13
Yup and some in 2000 model year were as low as 1580 lbs tow capacity.
The PDF from Ford showing the towing capacities of the various models of the 2000 Ford Ranger can be found here:
WWW.fleet.ford.com/truckbbas/non-html/2000/bbcamper.PDF
The Ranger specs are on Page 9
Old 05-09-2015, 09:28 AM   #14
Max looks to be in the 3600-4300 range, depending on exact configuration, for a 2000 with the 3.0L. Given that this truck is now 15 years old, a 17' Casita seems borderline at best and unlikely to give a satisfactory experience. Sticking with something around 2500 pounds loaded makes sense to me.
Towing with a 2000 Ford Ranger 3.0 Auto mgbbob Towing, Hitching, Axles and Running Gear 27 03-01-2015 03:33 PM
Casita 17' Deluxe and towing with Toyota Tacoma or Ford Ranger? JaneM. Towing, Hitching, Axles and Running Gear 47 04-25-2011 12:52 PM
Towing with a Ford Ranger 4X4 4.0L Tom H. Towing, Hitching, Axles and Running Gear 4 06-10-2009 06:03 AM
towing options w/ ford ranger Justin, M Towing, Hitching, Axles and Running Gear 18 04-18-2008 12:30 AM
