Towing without overdrive - Page 4 - Fiberglass RV
Old 06-07-2013, 09:55 AM   #43
cpaharley2008's Avatar
I'll try the experiment next time which will be a north/south direction.
Old 06-07-2013, 10:05 AM   #44
IllAnnoy
Because automatics make up about 80% of vehicles produced.
At least in the U.S. where people buy according to color and style...Not substance!
Old 06-07-2013, 10:19 AM   #45
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Hmmm, Continental Divide effect. An alternative explanation.
jack
Old 06-07-2013, 11:06 AM   #46
honda03842's Avatar
Name: Norm and Ginny
Our tow vehicle is 9 years old, has a manual transmission and the original clutch. We are now on one of ourhilliest adventures. Yesterday we drove the cape race road, about 24 miles of severe gravel hills. Today we met a guy in the park with a Nissan truck who asked us what did we do about the hill on the Cape Race road....we drove up it of course. Go Honda.
The only issue is backing up hills when it's almost necessary to slip the clutch
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
honda03842 is online now   Reply With Quote
Old 06-07-2013, 08:44 PM   #47
Perry J's Avatar
Trailer: 16' Casita
Norm, how many miles do you think you've towed with your Honda Norm??
I agree you can't beat a Honda or Toyota.
I was in bakersfield yesterday and thought of you and Ginny as I went through the In n Out Burger drive through yesterday.
John
Old 06-08-2013, 05:21 AM   #48
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I just did about 1600 miles. I had tow mode off, overdrive on for the drive north, and tow mode on, overdrive off for the trip south. Mileage was within a few tenths either way. The quality of each tank of gas seemed to change it more than anything (damn you and your mileage killing moonshine, iowa). However, it kicked from fifth down to either third or fourth and unlocking the torque converter quite a few times on the way up. It also hunted on hills, making me downshift. On the way back, it never shifted out of fourth, and the torque converter stayed locked. I'm sticking to tow mode with overdrive off.
I averaged 12-12.5mpg (2004 nissan titan, scamp 19'), doing 70-80. It only gets 17 on its own, so I'm happy.
Old 06-08-2013, 01:51 PM   #49
Brian B-P's Avatar
I'm surprised they have not improved the mechanical cruise control with a computerized system that eliminates those down shifts and passing gear upshifts while in cruise mode.
Modern vehicles use an electronic connection of accelerator pedal to engine, rather than the old mechanical cable. This means that the cruise control function is just code in the engine computer.
I find this means much smoother and nicer cruise control, but letting it maintain speed while towing in hills still means too much downshifting and high power application in our Sienna.
Old 06-08-2013, 04:24 PM   #50
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I'm not sure how you could get the information that the hill you are about to hit is a small one, so let the vehicle slow down rather than downshift, or know when you are just about to hit the peak of the hill, so again, no need to downshift, just let it slow down a couple of miles per hour.
Maybe when they reach the point where cars are suppose to drive themselves there will be enough sensors to do the trick, but my foot seems to work better in hilly country than the cruise control, at least when towing. I have noticed that it works better in my RAV4 than it did in my previous vehicle, a 2003 Town & Country.
Old 06-08-2013, 06:29 PM   #51
Brian B-P's Avatar
Cruise control is a classic feedback-type control system situation, so the usual control loop tuning parameters apply... and it is not necessary to know how steep or long the hill might be. The system can be adjusted to less aggressively maintain the set speed.
Although knowing what's coming up isn't necessary, it does help.
I'm not surprised; this may be a mechanical versus electronic throttle linkage difference.
Old 06-08-2013, 07:39 PM   #52
Radar1's Avatar
Name: Dave (and/or John)
I have a gauge that shows instant MPG on my Dakota 4.7 V-8 and can be reset easily to check average MPG over any distance. Dodge recommends towing normally without the overdrive locked out on my model, unless you are going up and down hills that cause the transmission to shift a lot. On the times that I can leave the transmission in overdrive, I get better mileage in overdrive than if the overdrive is locked out. I sometimes experiment on the same trip and road/wind conditions and it's always the same, better mileage for me if I use overdrive. Example: If I am getting 16.2 in overdrive, and then try the same road with overdrive locked out for a few miles, then the mileage drops to about 15.1.
If the hills or headwind cause the transmission to shift a lot, then I lock the overdrive out.
Guess every rig is different.
John-Dave and Marilyn
Sharpsburg, GA
04 Dodge Dakota V-8 and 17 Dodge Durango V-6
radar1-scamping.blogspot.com
Old 06-12-2013, 05:49 AM   #53
honda03842's Avatar
PerryJ,
We haven't kept track of the exact tow mileage but we 've been towing for 6 years for 7-11 motns a year and just passed 191,000 miles on the odometer. Towing miles have included 2 loops of the USA, a cross labrador andpresently about 4,000 miles in Newfoundland.
On this trip we've averaged 21.4 miles per gallon. Lots of steep hills, dirt roads and wind. Ginny thinks Cape Race was the windiest place we've been though I thinke Port Orford, OR wins.
A nice part of Nfld is very limited traffic.
Working our waynorth to look for an iceberg.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 06-12-2013, 05:53 AM   #54
honda03842's Avatar
PERRYJ
In and Out, love to see one in Nfld. We did eat cod tongues and fell in love with tea biscuits, their bread and eat alot more seafood.
As to absolut towing miles I would guess the order of 50,000.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Towing Definitions-Understanding Towing weight terms cpaharley2008 Towing, Hitching, Axles and Running Gear 40 04-16-2017 03:42 AM
Toyota Matrix, auto - overdrive?? GordM Towing, Hitching, Axles and Running Gear 16 06-25-2010 09:33 PM
Towing in Overdrive ? Ken C Towing, Hitching, Axles and Running Gear 9 02-03-2010 08:44 AM
Overdrive question..... kentj Towing, Hitching, Axles and Running Gear 8 07-18-2008 05:51 AM
Towing in Overdrive? Legacy Posts Problem Solving | Owners Helping Owners 19 05-05-2003 09:04 PM
