Toyota Tacoma, 2-wheel drive with 4 cyl engine tows fine - Fiberglass RV
Old 11-16-2008, 07:12 PM   #1
Trailer: Casita Spirit Deluxe 17 ft / 4 cyl Tacoma
I use a 2008 Toyota Tacoma, 2-wheel drive, 4 cylinder engine and 5 speed O/D manual tranny to tow my camper and it handles the load just fine. The truck is rated at 3500 lbs, which makes it more than ideal for a lightweight (2500 lbs +) camper. The truck when ordered with a factory towing package and V6 engine is rated at 6000 lbs, I think. The only problem with towing the Casita 17' SD model is the tongue weight is about 100 lbs more than a 16' Casita. The springs on the Toy are a little light for a better ride, so I had to add a WD hitch to keep the truck from squatting too much. See it here:
I just added the Reese Pro Series WD hitch to my Casita. A lot of the owners have been using the Equal-i-zer hitch, but there were several reasons I wanted to try this one instead... price was one reason. Of course these two mentioned have a built-in sway control you should find interesting. If you want to see pictures of the installation and an explanation, go to my web page here:
http://web.me.com/dr.pepper007/Site/Casita...asita_Mods.html
lonlawrence is offline   Reply With Quote
Old 11-16-2008, 07:25 PM   #2
Booker B.'s Avatar
Trailer: 1976 Trillium 13 ft
Does your Tacoma require trailer brakes after 1000lbs? That seems to be becoming more common on the newer trucks.
Old 11-16-2008, 07:58 PM   #3
brian m.'s Avatar
Trailer: 17 ft Casita Spirit Deluxe
Link no bueno.
http://web.me.com/dr.pepper007/Site/...sita_Mods.html
brian
2003 Casita SD 17'
http://www.coolcampcreations.com/
brian m. is offline   Reply With Quote
Old 11-17-2008, 12:23 AM   #4
Deb & Chuck's Avatar
Name: Deb & Chuck
Trailer: Bigfoot (8), Boler, Trillium, ECO, U-Haul, Burro, Escape (3), Trailswest, Compact Jr., Casita, Scamp
I put RoadMaster progressive springs on my 2005 Tundra. The cost was $325.00 installed. I can haul a ton of feed without the truck squatting.
chuck
Deb & Chuck is offline   Reply With Quote
Old 11-17-2008, 07:35 AM   #5
Booker B.'s Avatar
The correct link is:
Old 11-17-2008, 09:33 AM   #6
Sorry, I don't know what happened, but I re-edited the link and now it seems to work even though this website truncates the URL and puts a bunch of ..... in the link. I just checked it and now it works. Let me know if you still have trouble.
I thought about SuperSprings for the Toyota rather than a WD hitch, but didn't want to affect the good ride when I'm running empty (about 99% of the time), and any extra springs are going to affect your ride, regardless what the ads say.
Trailer brakes? Definitely. All Casitas come with trailer brakes and yes, I ordered the wiring harness from Etrailer also with my hitch (since you can't get the 4 cylinder Toyota with the full trailer towing packing like you can with the V6). It was quite a bit of work to wire up the trailer brakes. You have to also get Etrailer's brakelight kit, patch that in first, then run the other wiring harness kit under the truck to the engine compartment and back into the firewall/cab and hook it to the brakelight switch. There's no real good place to mount the trailer brake controller so it's a knee banger for us long-legged guys. I'll probably unplug it and take it out except when I'm going to travel with the camper.
Old 11-17-2008, 09:41 AM   #7
Booker B.'s Avatar
My prodigy JUST clears my knee in our Subaru with the seat full back. I was worried about it when it was installed but my legs just have clearance.
Old 11-17-2008, 11:40 AM   #8
Pete Dumbleton's Avatar
That's good for a load in the truck, but WDH is superior for a towing-related load because the WDH actually moves most of the rear weight up to the front wheels/suspension (the rest goes to the trailer axle) -- All the springs do is keep the body level; none of the load is transferred to the front end.
I just thought of a way to demonstrate the different effects. Take a wheelbarrow with a soft tire and load it with a bunch of concrete blocks *to the rear*. Notice the tire deformation, then lift the rear of the WB and place something under the rear legs -- Again, notice the tire deformation. Now, stand behind the wheelbarrow and lift the handles so the full weight is on the tire and your feet -- Notice the tire deformation.
Old 11-17-2008, 07:38 PM   #9
Deb & Chuck, even if you could put a ton in the bed of your 2005 Tundra, it would exceed its maximu passenger and cargo of 1,475 lbs.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 11-18-2008, 11:05 AM   #10
2,000 lbs distributed over the truck bed with a COG between the axles is also a different load than 400 lbs out on the trailer ball behind the rear axle.
Toyota Tacoma late models... Frame problems??? Alf S. Towing, Hitching, Axles and Running Gear 6 07-18-2008 05:33 AM
Tacoma 2.7 4cyl. engine Paddy Morris General Chat 15 04-21-2008 10:45 PM
Brake Controller for Toyota Tacoma?? Vic&Kathy Towing, Hitching, Axles and Running Gear 7 04-08-2008 08:43 PM
Can a 2007 Toyota Tacoma tow a Scamp 5th wheel trailer? Gary Foster Modifications, Alterations and Updates 4 03-28-2007 02:21 PM
Brake Controller for Toyota Tacoma?? Vic & Kathy Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
