trailer electrical connection - Fiberglass RV
Old 06-14-2013, 12:10 PM   #1
tartosuc's Avatar
Trailer: 2007 uhaul ct13
Quebec
its probably been discussed but my search did not show me a good response.
what is the connector system on the older eggs from the 70's or 80's?
i'm thinking if i want to buy one i might need an adapter to fit to my 4 pins connector on my Van? would be better to have it handy !
thanks
tartosuc is offline   Reply With Quote
Old 06-14-2013, 12:11 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
For trailers without brakes, the flat four is probably the most common. If I was shopping for a trailer I'd pick up a set of tow lights, as there is a good chance the lights won't work properly anyway.
http://www.harborfreight.com/12-volt...kit-69626.html
Old 06-14-2013, 12:34 PM   #3
I vote for the magnetic Tow Light set too. This week they are still on sale at Harbor Freight for $10. Here's a few reasons, in probable order (?)
1. The trailers lights don't work anyway either due to lights being burned out or defective wires, but the seller will blame your TV's connections.
2. A previous owner invented their own connection pattern and, as soon as you plug in a matching connector, it will blow fuses on your TV or the lights will be all wrong
3. A previous owner changed it from a 4 pin to a 8 (?) pin cannon connector because that's what they had on hand.
4. No matter what adapter combinations you have, they will all be the wrong ones.
In short, the magnetic tow lights, a handfull of long wire ties, and a 4 pin connector at your end will get you home every time.
3. If you have
Old 06-14-2013, 01:53 PM   #4
tartosuc's Avatar
Quebec
thanks for the replies,
i've ordered a magnetic kit.
Old 06-14-2013, 02:14 PM   #5
GMike A's Avatar
Watch out with those lights. . I was towing on typical Texas roads and one of them popped off and was dragged to its untimely death. For my second set of HF lights I went to the welding section and bought some of the triangular magnets which really stuck to the bumper and then the weaker tow light magnets stuck to the triangles. That is probably one of many solutions.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 06-14-2013, 02:41 PM   #6
Thomas G.'s Avatar
Right, if you read the reviews, they universally say that the magnets are too weak. I'd take some big plastic ties with me and secure them with those. I's also make sure the tow light set worked before I left.
Old 06-14-2013, 04:24 PM   #7
tartosuc's Avatar
Quebec
Ill bring zip ties
Old 06-14-2013, 05:42 PM   #8
Perry J's Avatar
Trailer: 16' Casita
How about some duct tape to attach the wire to the side of the trailer on the way home?
John
Old 06-14-2013, 06:08 PM   #9
tartosuc's Avatar
Quebec
John
My van is alway full of tools duck tape, zip ties bugees ...i'm not worried about that part
Old 06-14-2013, 06:44 PM   #10
My 1988 trailer, before I bought it, had a different connection than after I hitched it up to tow it home.
With any trailer that's 30-40 years old, I'm not sure there is an absolute anything you can count on.
Old 06-14-2013, 06:49 PM   #11
Thomas G.'s Avatar
That duck tape is the best.
Old 06-14-2013, 06:59 PM   #12
tartosuc's Avatar
Quebec
Lol
Working in the show business industry, i have unlimited access to duct tape(we call it gaffer tape)
Old 06-14-2013, 07:16 PM   #13
Ah, but gaffer tape is not Duck tape ( or duct tape, for that matter ). Gaffer tape costs at least four times as much and doesn't leave sticky residue, or peel paint off the surface when removed. I have a couple rolls from when I worked as a photographer.
Doesn't stick when wet or to wet surfaces.
Old 06-14-2013, 07:54 PM   #14
Brian B-P's Avatar
Preferably gaffer's tape, which is similar but designed to remove cleanly.
electrical
U-Haul Electrical extension connection Perk Electrical | Charging, Systems, Solar and Generators 13 06-24-2012 06:09 PM
Tug to Trailer connection Scott B. Problem Solving | Owners Helping Owners 10 08-15-2010 04:13 PM
9-pin electrical connection Legacy Posts Problem Solving | Owners Helping Owners 5 01-06-2003 05:56 PM
Trailer plus connection. Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 10-25-2002 07:31 AM
Trailer height and the Axle Connection Lisa H. Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
