Trailer rocks when towing over uneven road surface- time for new springs or? - Page 3 - Fiberglass RV
Old 11-17-2015, 01:59 PM   #29
Cathie Sadler-Pare's Avatar
Trailer: New owner of a 73 Hunter compact ll
The surf side tire pressure is 20 psi? The rating on the tires on my Hunter call for 50psi ! I am not going to even try to "blow them up" to the max pressure.
Cathie Sadler-Pare is offline   Reply With Quote
Old 11-17-2015, 02:02 PM   #30
Civilguy's Avatar
Puget Sound, WA
I have really got to get off this thread. The following link is from the Discount Tire web site.
http://www.discounttire.com/dtcs/inf...erTireFacts.do
I have found them to be a professional and well-informed outfit over the years. They sell well-known and high-end trailer tires including Goodyear Marathons, Carlisle, and Maxxis.
No. 1 in big red text on the left edge of the linked page is "Always inflate trailer tires to the maximum inflation indicated on the sidewall."
Additional to that, they have what I consider to be a pretty comprehensive list of recommendations including:
Trailer Tire Applications
  • Trailer tires are designed for use on trailer axle positions only. They are not built to handle the loads applied to, or the traction required by, drive or steering axles.
Inflation
  • Always inflate trailer tires to the maximum inflation indicated on the sidewall.
  • Check inflation when the tires are cool and have not been exposed to the sun.
  • If the tires are hot to the touch from operation, add three psi to the max inflation.
  • Underinflation is the number one cause of trailer tire failure.
Load Carrying Capacity
  • All tires must be identical in size for the tires to properly manage the weight of the trailer.
  • The combined capacity of the tires must equal or exceed the Gross Vehicle Weight (GVW) of the axle.
  • The combined capacity of all of the tires should exceed the loaded trailer weight by 20 percent.
  • If the actual weight is not available, use the trailer GVW. If a tire fails on a tandem axle trailer, you should replace both tires on that side. The remaining tire is likely to have been subjected to excessive loading.
  • If the tires are replaced with tires of larger diameter, the tongue height may need to be adjusted to maintain proper weight distribution.
Speed
  • All "ST" tires have a maximum speed rating of 65 mph.
  • As heat builds up, the tire's structure starts to disintegrate and weaken.
  • The load carrying capacity gradually decreases as the heat and stresses generated by higher speed increases.
Time
  • Time and the elements weaken a trailer tire.
  • In approximately three years, roughly one-third of the tire's strength is gone.
  • Three to five years is the projected life of a normal trailer tire.
  • It is suggested that trailer tires be replaced after three to four years of service regardless of tread depth or tire appearance.
Mileage
  • Trailer tires are not designed to wear out.
  • The life of a trailer tire is limited by time and duty cycles.
  • The mileage expectation of a trailer tire is 5,000 to 12,000 miles.
Why Use An "ST" Tire
  • "ST" tires feature materials and construction to meet the higher load requirements and demands of trailering.
  • The polyester cords are bigger than they would be for a comparable "P" or "LT" tire.
  • The steel cords have a larger diameter and greater tensile strength to meet the additional load requirements.
  • "ST" tire rubber compounds contain more chemicals to resist weather and ozone cracking.
Storage
  • The ideal storage for trailer tires is in a cool, dark garage at maximum inflation.
  • Use tire covers to protect the tires from direct sunlight.
  • Use thin plywood sections between the tire and the pavement.
  • For long term storage, put the trailer on blocks to take the weight off the tires. Then lower the air pressure and cover the tires to protect them from direct sunlight.
Maintenance
  • Clean the tires using mild soap and water.
  • Do not use tire-care products containing alcohol or petroleum distillates.
  • Inspect the tires for any cuts, snags, bulges or punctures.
  • Check the inflation before towing and again before the return trip.
Keys to Avoiding Trouble
  • Make sure your rig is equipped with the proper tires.
  • Maintain the tires meticulously.
  • Replace trailer tires every three to five years, whether they look like they're worn out or not.
...must get off thread and on with life....
- "Wag more, bark less." -
Old 11-17-2015, 02:09 PM   #31
As I mentioned, I run the tires on my Hunter at 50 PSI
Old 11-17-2015, 02:20 PM   #32
Oh CivilGuy- where would I be without all the good info. I now know more about tires than any of my friends!
So last question for you and Bob. Now that the tires are off what do I look for to replace, repair and inspect before I put the new tires back on? And would you recommend taking the trailer to the tire store. I was planning on removing them at home.
Old 11-17-2015, 02:35 PM   #33
Civilguy's Avatar
Puget Sound, WA
Be sure to note that the Goodyear and Discount Tire data don't always agree!
It's tough to say who is going to be a good resource for you here. Eventually someone needs to examine the whole assembled setup so they can evaluate why the tires might have been rubbing, etc. Tire folks are tire folks, and different ones may or may not fully appreciate or understand issues that are somewhat unique to trailers.
I don't know where you are located and what issues there might be in traveling with the trailer at present on those degraded skins. Maybe you could have the tires changed out, then tow it in for the suspension check.
Your neighbor might have some local perspective here.
Bob may have other ideas to suggest too. What with all this pesky search for the truth, I'm plumb tuckered out. Maybe it's time for some of that coffee!
Old 11-17-2015, 02:45 PM   #34
As far as the tire store, whatever is easiest for you. I Use Discount/America's Tire both in CA and in WA and they always take excellent care of us.
New valve stems are a must and, because the original rims are 40 y.o., I would opt for a new set of white spoke rims at the same time. Fairly cheep at D/A Tire. Of course, be sure that they are balanced.
On the trailer, pull both wheel hubs and take then to any garage to have the bearings cleaned, inspected and repacked w/new seals installed. If the shop indicates that there is any wear or discoloration from overheating, new bearings and new bearing races are the order of the day. Also check the axle spindle for any signs of damage or burn marks.
Other than that, not much
Old 11-17-2015, 03:01 PM   #35
Civilguy's Avatar
Puget Sound, WA
A hearty second to “what he said”.
Also, there was a problem with some of the rubber valve stems in recent history. They would degrade and crack. There was a potential for the tire to lose all its air in a rush, which could result in the trailer trying to take over and do all the steering for you. That and previous experiences lead some folks to only use metal valve stems. The PO or Casita put stainless steel ones on our wheels. Can't cost much more.
http://www.dillaircontrols.com/files...r%20Cracks.pdf
Old 11-17-2015, 03:46 PM   #36
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Whew. No wonder we keep having discussions on tire pressure on all the forums. The sticker on my Bigfoot says 32psi, Goodyear says 40 psi, and Discount Tire says 50psi.
So that's three different recommendations from three "authoritative" sources. What's a poor trailer owner to do?
I have always run at 40psi, on the gut feeling that 32 will cause too much tread wear and 50 a too rough ride for the trailer and contents.
Perhaps more problematic with the Discount Tire recommendations is to limit tires to between 5,000 and 12,000 miles use. For many of us, even the upper figure would mean buying new tires more than once a year. Whew. Raise your hand if you do that. Or if you are willing to accept that. Not I.
Walt
Old 11-17-2015, 04:12 PM   #37
All three could be correct
The more important question is what tires did BigFoot have on the trailer when it was new. Passenger car tires have a standard pressure of 36 PSI, so 32 could be right for those tires, but very low for 6 ply rated "C" range tires.
. I run 50 psi on my 43 year old Hunter and have never seen anything fall apart.
Old 11-18-2015, 08:00 AM   #38
Civilguy's Avatar
Puget Sound, WA
Walt,
The 40 psi I noted was based on the specific load and tire size for our Casita. In my case this is ST205/75R15 Marathons. The load is (2,600 + 600) / 2 = 1,550 lbs per tire. The nearest match on the table is 1,530 lbs at 40 psi. Your Bigfoot will probably calculate differently.
Old 11-18-2015, 08:25 AM   #39
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
The max. pressure on my truck tires is 44 lb.
Ford recomended pressure is 30 lb.
I run at 30 lb.
I do not know why I would do differently on my trailer.
Bob in Mb is offline   Reply With Quote
Old 11-18-2015, 10:25 AM   #40
tractors1's Avatar
Trailer: Escape 21 - Felicity
I run at 30 lb.
Trailers usually have a different suspension setup and ST tires have stiffer sidewalls for reducing sway effects.
Charlie Y
Old 11-18-2015, 11:14 AM   #41
I run at 30 lb.
Seems to me like that logic only works if the tires are the exact same size, rating, and construction as the ones on the trailer when it was manufactured, and if no modifications have been made to the trailer itself.
Old 11-18-2015, 04:13 PM   #42
tractors1's Avatar
Tires need to be inflated at a pressure that matches the load on them according to the manufacturers specs. When I had a 2100 lb pickup camper I boosted the air pressure in the rear tires from 35 psi to 80 psi. At 35 psi I only had a 2 inch sidewall height between the rim and the ground.
Charlie Y
Hot Springs Campground - Hot Springs, NC GerthT Camping, Campout Reports 2 06-08-2015 07:18 PM
Scamp 5th wheel "bucking" on uneven surface ? Westcliffe01 Towing, Hitching, Axles and Running Gear 15 11-12-2013 10:29 PM
torsion springs or leaf springs Cat futrell Problem Solving | Owners Helping Owners 18 08-26-2012 08:12 AM
Uneven tire wear Tamid Towing, Hitching, Axles and Running Gear 6 03-29-2010 11:13 AM
Uneven trailer braking John & Sandy M Care and Feeding of Molded Fiberglass Trailers 15 02-03-2007 12:18 PM
