Trailer rocks when towing over uneven road surface- time for new springs or? - Page 4 - Fiberglass RV
Old 11-18-2015, 08:57 PM   #43
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Originally Posted by WaltP View Post
Whew. No wonder we keep having discussions on tire pressure on all the forums. The sticker on my Bigfoot says 32psi, Goodyear says 40 psi, and Discount Tire says 50psi.
So that's three different recommendations from three "authoritative" sources. What's a poor trailer owner to do?
I have always run at 40psi, on the gut feeling that 32 will cause too much tread wear and 50 a too rough ride for the trailer and contents.
Perhaps more problematic with the Discount Tire recommendations is to limit tires to between 5,000 and 12,000 miles use. For many of us, even the upper figure would mean buying new tires more than once a year. Whew. Raise your hand if you do that. Or if you are willing to accept that. Not I. Walt
Unless someone has a mechanical issue, I doubt tire wear will ever become a factor to tread wear. I find it interesting that anybody would even bother using a factory tire sticker from a trailer 10 or more years old for todays tires. Tire tech has changed and any info from those old stickers are moot today. As long as your tires are of the right load rating for your trailer weight you use the side wall specs. Take the old stickers off. Wonder how many egg owners here really have had a blow/flat out from age. My own experience has only been from metal objects I've picked up in 45 years. BTW, with a tandem axle it's always the rear tire, the front one kicks it up and the second one gets nailed .
Borrego Dave is online now   Reply With Quote
Hot Springs Campground - Hot Springs, NC GerthT Camping, Campout Reports 2 06-08-2015 07:18 PM
Scamp 5th wheel "bucking" on uneven surface ? Westcliffe01 Towing, Hitching, Axles and Running Gear 15 11-12-2013 10:29 PM
torsion springs or leaf springs Cat futrell Problem Solving | Owners Helping Owners 18 08-26-2012 08:12 AM
Uneven tire wear Tamid Towing, Hitching, Axles and Running Gear 6 03-29-2010 11:13 AM
Uneven trailer braking John & Sandy M Care and Feeding of Molded Fiberglass Trailers 15 02-03-2007 12:18 PM
