Trailer tongue jack - Fiberglass RV
Old 06-19-2015, 11:22 AM   #1
immrbill's Avatar
Trailer tongue jack
1980 Boler...Would like to replace the Tongue Jack to one with wheel. The ones on Amazon appear to have the same triangular bolt pattern. Does anyone know it replacements are readily available.
immrbill is offline   Reply With Quote
Old 06-19-2015, 12:04 PM   #2
You can buy just the wheel.
Too bad you weren't at the Escape Rally. Two people were trying to give theirs away.
Old 06-19-2015, 12:19 PM   #3
If you are looking for the type that has the triangular pad that bolts into the VEE behind the coupler let me recommend the ultimate jack with wheel.
and wheel.
Make sure you get the wheel that fits and has the quick release pin.
This setup gives you a lot of flexibility in the height and can be readily raised for towing clearance or if the wheel is removed the tube can be removed easily.
Pay attention the the directions that tell you to use locktite on the little bolt that holds the plastic guide part in groove or the thing will rattle loose over time.
Old 06-19-2015, 01:43 PM   #4
Timber Wolf's Avatar
North Florida
JD, do you know what the distance is from the center of the jack to the outside of the handle? In other (more mathematical) words, what is the swing radius of this bad boy? I built a shroud around my propane tanks and batteries and wonder if I have enough room left in the front of the A frame to mount one of these and not bust my knuckles trying to use it. I assume if you have enough room to swing the thing you also have room to work the doohickey at the bottom that holds it up and down. Sorry for the "technical" language.
Old 06-19-2015, 02:55 PM   #5
The Minimalist's Avatar
Louisiana
++on the Ultimate Jack. Very flexible vertical adjustment.
Timber Wolf--6 5/8 inch swing radius as measured.
Clif
Old 06-20-2015, 12:13 PM   #6
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
I ordered Ultimate Jack today.
To follow...
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
Old 06-20-2015, 01:19 PM   #7
North Florida
Thanks, seems I don't have enough room with it vertical. But maybe mounted at a slight cant forward it will work. I will get a piece of pipe as a stand-in and play with it some and see. Their website shows our local Tractor Supply supposedly has these in stock. I might have to fab an angled foot but that is not biggie.
Old 06-20-2015, 05:50 PM   #8
Roger C H's Avatar
Smile Another wheel for your jack
BULLDOG Trailer Jack Wheel Caster Assy. #500245
Or just go to your local trailer supply store.
MEASURE the diameter of your tube first. There are different dia's.
With all the RVs that come to FL, I would think you would be up to your armpits in trailer supply stores.
Old 06-20-2015, 06:18 PM   #9
Louisiana
I was in the Tractor Supply Store that opened in my town recently. They
do stock the Ultimate Jack. $59.95 here.
I have both a dolly wheel and a foot for mine. The dolly is nice, and let's me orient the Little Joe any way I want, but if high winds are coming I use the foot.
Clif
Old 06-20-2015, 06:25 PM   #10
Louisiana
TW, I just realized I hadn't answered part of your question about clearances.
I don't have any problem with technical language. As best I can measure, you would have about 1 1/2 inches end clearance on the 'doohickey', AKA 'locking pin' within the swing radius of the handle.
Clif
Old 06-22-2015, 02:48 PM   #11
Trailer: 2014 Scamp 16, 2011 RAV4 V6
Am l missing something on the Ultimate Jack? I installed one and found that the black plastic thing that aligns the vertical tube prevents me from fully removing the tube. The groove in the tube that the plastic part engages doesn't go all tha way to the bottom, so the plastic thing stops it from being completely removed. My solution was to replace the small bolt holding the plastic part on with a wingbolt, so I can easily loosen it to remove the jack. Goes counter to using Loctite on the bolt.
Doug in Sacramento is offline   Reply With Quote
Old 06-25-2015, 10:51 AM   #12
Louisiana
Doug, why do you want to remove it?
Clif
Old 06-25-2015, 01:52 PM   #13
Gilles's Avatar
Quebec
It is probably as the publicity that I saw, when you have a pickup, the back door cannot open completely if this model of Jack is too much settled on the front.
If it is possible, you install it so that it is rather far of tail gate...
Gilles
Bigfoot 15B17G.
Old 06-25-2015, 02:35 PM   #14
Did I hear someone has a problem with the Tug tailgate hitting the jack (or jack handle)??? I am considering this to solve that problem:
Jack-E-Up
Jack-E-Up jack Victor Benz Modifications, Alterations and Updates 12 07-20-2017 04:12 PM
Popping Noise When Using Tongue Jack Today to Put Trailer On Jacks For Winter CampyTime Problem Solving | Owners Helping Owners 19 10-27-2014 04:35 PM
Tongue Jack Stand fits 2" jack FTTRV Commercial Posts and Products 7 06-20-2014 08:53 AM
Trailer tongue power jack The Hobo General Chat 9 02-24-2009 01:52 AM
Power tongue jack Legacy Posts Modifications, Alterations and Updates 20 07-20-2003 02:42 PM
» Recent Discussions
» Trailer Showcase
William
Barb in Ontario
MITY-LITE
rnecksteve
