Trails West Campster Dry Weight- replacing leaf springs - Fiberglass RV
Old 06-12-2013, 06:18 PM   #1
Rpryor3's Avatar
Trailer: 1970 Trails West Campster
Hello all,
I have a 1970 trails west Campster that I will be replacing the leaf springs on. Does anyone have any idea what is the dry weight of these? I really don't want to have to drag it to a public scale. The weights I am considering are 2500#, 3000# or 3500#. Any input is greatly appreciated.
Rpryor3 is offline   Reply With Quote
Old 06-12-2013, 06:28 PM   #2
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
I believe in the brochure they claimed 840 lbs? Something like that. What's wrong with your springs?
Bobbie Mayer is online now   Reply With Quote
Old 06-12-2013, 06:47 PM   #3
Rpryor3's Avatar
It sags to one side by about an inch or two. I have tried everything loosening the brackets and bolts to see if it was frozen but nothing. The only thing I can think is either one spring is rusted together and won't flex properly or more likely the springs are mismatched either way it's going to be less than $100 to replace all the running gear and the added confidence of new gear is worth more than that.
Old 06-12-2013, 07:19 PM   #4
Mine was the bracket, luckily. Yes, good to get new stuff and be sure.
Old 06-12-2013, 07:56 PM   #5
Rpryor3's Avatar
I'm thinking if the dry weight is around 800 say 1000 just to be safe then 2000 or 2500 should be good. Don't see how I would add 1000 lbs or more of cargo. I am afraid of the spring being too stiff as I would like to take it off road and dont want it to shake apart.
Old 06-12-2013, 08:07 PM   #6
Here's some info on sizing
How to Determine Correct Leaf Spring Size on 6 X 12 Utility Trailer | etrailer.com
Old 06-12-2013, 11:48 PM   #7
Perry J's Avatar
Trailer: 16' Casita
If your springs are to stiff your trailer will not have enough weight for them to do any good.
Old 06-13-2013, 06:07 AM   #8
Trailer: 2014 Escape 21
Virginia
Ray
The empty shell (no floor) and frame weigh about 800#. At least 100# is below the springs. Make sure you replace your spring and shakle bushings. Springs normally come with new bushings. E- trailer sells the bushings for your shakle. My trailer had bronze shakle bushings but I only found plastic replacements.
Eddie
Eddie Longest is online now   Reply With Quote
Trails West Campster Robert C Snowden General Chat 9 09-01-2013 08:51 AM
Trails West Campster KevinSteele General Chat 13 05-12-2011 10:59 PM
Trails West Campster David Morgan Classified Archives 6 04-04-2010 10:58 AM
Trails West Campster Bobbie Mayer General Chat 32 07-04-2007 04:18 PM
Trails West Campster Sherry Stephens Classified Archives 0 12-31-1969 07:00 PM
