Trillium 1300 '78 Axle Seal Part Number - Fiberglass RV
Old 07-13-2009, 05:02 PM   #1
Larry C Hanson's Avatar
Hello, I am getting ready to hit the road with my Trill. Servicing axles noticed new grease
seals are needed. Does anyone out there have a part number for seals? Thanks, Larry H
Old 07-13-2009, 07:45 PM   #2
Bill F.'s Avatar
Trailer: 92 Bigfoot 13.5 ft / 05 Freestar
If you can measure accurately check the 1)I.D. by measuring the axle diameter where the seal rotates, 2) the O.D. by measuring the recess diameter where the seal sits in the hub and 3) measure the flange height from the existing seal and you don't need a part number. Each seal manufacturer likely has a different number which can be cross referenced to other brands, and there may be a number on the existing seal if you take it out and look.
Bill
Bill F. is offline   Reply With Quote
Old 07-14-2009, 12:47 PM   #3
Thanks Bill, No calibrated calipers on hand. There were no numbers on the
old seals. However, the guy down at Napa was able to find me a seal that works.
Napa part # 17404. Larry H
axle, trillium
VIN number for a Trillium Stephan G Ryan Problem Solving | Owners Helping Owners 2 07-22-2010 02:00 AM
Trillium 1300 Axle Check, Fitting Electric Brakes Richard Hayes General Chat 2 08-23-2009 10:54 PM
Trillium 1300 Rubber Door Seal georgia g Problem Solving | Owners Helping Owners 0 07-28-2009 05:51 PM
Axle Part Number WayneJ Towing, Hitching, Axles and Running Gear 14 12-21-2007 10:28 AM
Burro trim, part number? AndyW Problem Solving | Owners Helping Owners 4 02-24-2006 07:50 AM
