Trillium Axle - Fiberglass RV
Old 01-11-2009, 06:44 PM   #1
Don N's Avatar
Trailer: 1978 Boler 1700
Ours is a 1975 Trillium 1300 and as you can see by the photo, the trailing arm is pointed at about the 2 o'clock position. From what I have read I would think that this arm should be pointing closer to the 4 o'clock position and that my axle has sagged a lot over the years. Any of you other Trillium owners out there that can shed a light on this? Or were these axles set up this way?
Don N is offline   Reply With Quote
Old 01-12-2009, 01:33 AM   #2
Roy in TO's Avatar
Unloaded, I'm thinking you are right.
Someone might correct me on this but ...
Look at your first picture. In my mind the square axle coming out of the axle tube and into the torsion arm should be offset 45 degrees from the square tube of the axle at rest (unloaded is not at rest). If you think about how these are made there are 4 pieces of rubber that fit into the "corners" of the axle tube around the square axle that joins the torsion arm. I believe they alter the angle in the original casting of the torsion arm in your axle.
From the picture, it looks like you could run a straight line through 2 corners of your square axle right to the center of your spindle. My guestimate would be that you originally had a zero degree axle.
Old 01-12-2009, 01:37 AM   #3
Roy in TO's Avatar
Maybe next time someone changes their axle, they can run the old one through a band saw and take a picture of what it looks like on the inside. It would be interesting to see what shape the rubber assumes inside after years of holding the weight over the years.
Old 01-12-2009, 01:14 PM   #4
Alf S.'s Avatar
Hi: Don N... Sorry I can't comment on a Trill. Axle arm angle. The only thing I know are the laymans means of visual checks for scrub marks on the fiberglass above the tires and a min. space on top of the tires of at least the width of your fist as clearance!!!
Alf S. North shore of Lake Erie p.s. our Escape 5.0 looks like a down angle pointing to aprox 4 o'clock.
Old 01-12-2009, 02:49 PM   #5
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
just a thought... can axles be rebuilt? I know mine is due and also want to ask if anyone in Winnipeg had a contact?
Scott S. is offline   Reply With Quote
Old 01-12-2009, 05:24 PM   #6
Trailer: 87 Lil Bigfoot
Don,
Check out this link.
http://www.trilliumrv.com/Parts/PartsList.htm
It has all most of the parts for a Trillium, some parts also have pictures.
Hope it helps.
Rick
Rick H is offline   Reply With Quote
Old 01-12-2009, 09:01 PM   #7
Pete Dumbleton's Avatar
Torsion axles can't be rebuilt -- At original assembly, the rubber rods are cooled in liquid nitrogen and inserted into the axle beam -- When they warm up, they expand and fill the space.
Old 01-13-2009, 05:10 AM   #8
Trailer: Escape Manufacturer
Hi Don
The original Trillium used a 0 degree pitch on the axle which means with no load, the arm would be in the 3 o'clock position.
Reace
Reace is offline   Reply With Quote
Old 01-13-2009, 05:51 AM   #9
Don N's Avatar
Thanks Reace. Thats what I was wondering. So it has dropped some for sure. The new one is going to be adjustable so I will start it at 0 degrees and move it accordingly. Hope to get this one and the new one ordered within the next couple of weeks.
Old 01-23-2009, 07:39 PM   #10
Don N's Avatar
Well, I got the old axle cut out on Monday night and took it up to Cerka trailers to make up one of their own new ones. It was ready to pick up on Thurs morning. Can't complain about the service.
Old 01-23-2009, 07:46 PM   #11
Greg A's Avatar
You doing your own welding and install on the new one Don??
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 01-23-2009, 07:48 PM   #12
Don N's Avatar
Brought the new one home last night. Made up to the same dimensions as the old one. It is a FLEXIRIDE 2200# with 7" electric brakes 5 on 4.5" hubs. Set at 0 Deg but it is adjustable. Started to clean up some of the surfaces on the frame and am not liking what we see with the frame. Couple of soft spots and a not so good repair on the crack up near the bend. Has anybody made up new rails? Have to do some more looking this weekend before we decide to install the new axle.
Old 01-23-2009, 07:51 PM   #13
Don N's Avatar
Got a friend around the corner with the plasma cutter (which we used to cut this one out with), mig and tig welder. Younger guy with much better eyes than mine. It is up on his hoist now. I will be helping him with the install.
Old 01-23-2009, 09:53 PM   #14
Greg A's Avatar
You lucky dog...... Next you'll tell us it's only costing ya a couple of cases of Heineken..
Owner:
Old 01-23-2009, 10:01 PM   #15
Don N's Avatar
Have yet to see him drink his first beer. He lost his dad about 10 years ago so I have kinda adopted him as a second son. Real good fabricator. I will end up paying him but he never charges me a whole lot. Always working out a deal on something with him.
Old 01-24-2009, 02:05 AM   #16
Roy in TO's Avatar
Does he need a brother?
Old 01-24-2009, 06:34 AM   #17
Don N's Avatar
Not sure, he has a sister already..
axle, trillium
Trillium new axle Bogdan D Towing, Hitching, Axles and Running Gear 3 06-14-2008 03:19 PM
Trillium axle replacement Bogdan D Towing, Hitching, Axles and Running Gear 8 04-20-2008 08:31 PM
Trillium Axle Replacement Joseph Olajos Towing, Hitching, Axles and Running Gear 5 06-01-2007 12:59 PM
Trillium Axle JohnWalker Towing, Hitching, Axles and Running Gear 2 05-22-2006 01:11 PM
Trillium axle replacement Bogdan D Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
