Trillium new axle - Fiberglass RV
Old 06-14-2008, 12:28 AM   #1
Hey .... I am trying to restore a 74 Trillium 1300. I want to remove a leaf spring setup the previous owner had installed and replace with the original Trillium torsion axle. I have ordred the axle fro Trillium (Outback) in Calgary. Pacific Axle and Spring in Langley said they can do the switch. What I am looking for is some photos of how the factory axle is supposed to be attached to the frame. (This leaf spring setup will be cut off and the original attached). Would appreciate if anyone can send me a detail of how the original is placed. Photo of my setup is attached.
Bogdan D is offline   Reply With Quote
Old 06-14-2008, 01:55 AM   #2
Pete Dumbleton's Avatar
After you've seen the original way, I suggest you look into the Dexter bracket that welds onto the frame and then the axle will bolt to it. Makes it much easier to make a subsequent change (wreck, bearing problem, etc.).
While you're at it, if you don't have brakes, order the new axle with them -- Cheapest way to obtain them.
Old 06-14-2008, 07:29 AM   #3
Roy in TO's Avatar
If you can cancel the axle order, I'd suggest getting the [b]brand new frame with axle and brakes that Tom from Trillium RV has posted on the for sale forum here for $975 located about 3.5 hrs south of you.
It is a one time deal with two weeks left! I'm not sure what your pricing was, but my axle on order is $400 and some odd dollars plus installation. I'd be jumping at the chance to get a brand new frame for less than $500.
Old 06-14-2008, 03:19 PM   #4
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
..........I'da just let the very capable guys at Pac/Springs L K after everything. You're in good hands with them (from my past experiences with them).
axle, trillium
Trillium Axle Don N Towing, Hitching, Axles and Running Gear 16 01-24-2009 05:34 AM
Trillium axle replacement Bogdan D Towing, Hitching, Axles and Running Gear 8 04-20-2008 08:31 PM
Trillium Axle Replacement Joseph Olajos Towing, Hitching, Axles and Running Gear 5 06-01-2007 12:59 PM
Trillium Axle JohnWalker Towing, Hitching, Axles and Running Gear 2 05-22-2006 01:11 PM
Trillium axle replacement Bogdan D Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
