Truck not enough payload capacity - Fiberglass RV
Old 08-15-2017, 08:17 PM   #1
So we tow our Bigfoot 17' with a V6 Tacoma that has a payload capacity of 1050 lbs. We usually carry 4 passengers, about 450lbs total. The hitch weight, not including the hitch itself, is about 375 lbs. The hitch is another 75 pounds, which brings the total to about 900lbs.
We also carry our bikes I the truck bed to create a stable tow, the bikes are about 130 lbs total. The grand total is now 1030, pretty close to the maximum for our truck.
The 4 passengers are likely to grow in weight, does this mean that we will need to upgrade our truck soon? Which truck would give us the most room to grow? We like the Toyota Tundra crewmax but the payload is only 1240lbs, which is only 190lbs more than the Tacoma! Not the headroom that we are hoping for.
Jacqueline in BC is offline   Reply With Quote
Old 08-15-2017, 08:43 PM   #2
madjack's Avatar
Trailer: 2015 Casita 17FD
Rapides Parish La.
May be overkill BUT, going to a 3/4 ton truck will about triple load capacity and about the same for tow capacity...just sayin'.........
madjack
p.s. ...and it wouldn't add more than 50% to the price .................mj
madjack is offline   Reply With Quote
Old 08-15-2017, 08:52 PM   #3
Trailer: Casita 17 ft DLX SD
Look at a Ford F150 or a Chevy Silverado 1500 .
Both are 1/2 ton trucks with far better payload and towing capacity than a Toyota.
steve dunham is online now   Reply With Quote
Old 08-15-2017, 08:55 PM   #4
IllAnnoy
SEMA
Old 08-15-2017, 09:50 PM   #5
rbryan's Avatar
Originally Posted by steve dunham View Post
Look at a Ford F150....
And then stop, because you found the answer.
Old 08-15-2017, 11:35 PM   #6
Trailer: Trillium Jubilee
New Jersey
Hi Jacqueline
My Highlander tow capacity is 5000 pounds
If you buy a Tacoma 4x4 I'm sure will work perfect.
My friend have a Tacoma 4x4 and he pull a big camper with no problem.
Good luck
Falicea is offline   Reply With Quote
Old 08-16-2017, 05:07 AM   #7
TomK's Avatar
The most popular vehicle in North America since 1981, Ford F-150. Our's has a 2.7 eco-boost, 6 cyl engine that will tow 7,600 lbs. Payload to include pax and cargo is 1483 lbs.
Tom
Old 08-16-2017, 06:28 AM   #8
Trailer: Jayco
Alaska
Originally Posted by Falicea View Post
Hi Jacqueline
Good luck
The poster's concern is payload not towing capacity.
jsg67 is offline   Reply With Quote
Old 08-16-2017, 07:39 AM   #9
Hi Jacqueline
Good luck
The Tacoma , Tundra and Ram have very low payload capacity when compared to Ford or Chevy ( I own a Ram) .Ford and Chevy both build trucks that have a payload capacity that is over 1000 lbs greater than the Tacoma / Tundra . My Ram as equipped has a towing caparity of 10,250 lbs but my payload capacity is only 1300 lbs.
I am nowhere near my towing capacity with my 17 ft Casita but I have maxed out my payload capacity and that's with only 2 passengers.
Using the towing capacity as the only criteria leads to people overloading their vehicle .
Just because you know or have seen people that have done
something doesn't mean that it's the right thing to do !!!
A lot of these vehicle towing threads could be eliminated if people only read their owner's manual , did their homework.and the math.
Old 08-16-2017, 09:00 AM   #10
DeBreez's Avatar
Trailer: 2015 Casita 17SD
Miami, FL
While the Chevy and Ford generally have higher capacities, the payloads for all the trucks mentioned vary considerably based on how they are equipped. The crew cab models tend to be toward the bottom of their ranges..
2017 Tundra: 1,440 to 2,080 lbs
2017 F150: 1,621 to 2,329 lbs
2017 Ram: 1,230 to 1,923 lbs
2017 Silverado: 1,740 to 2,020 lbs
Just for comparison, my 2002 V-8 Tundra 2WD extended cab is 1,938 lbs, but the low end of the range for that year is 1,366.
Agreed!
"...I keep blowin' down the road."
2015 Casita 17' Spirit Deluxe
2002 Toyota Tundra V8
DeBreez is offline   Reply With Quote
Old 08-16-2017, 09:34 AM   #11
Ohio
The Taco is a midsize truck like the Chevy Colorado that starts at 3500 tow cap.
cmartin748 is offline   Reply With Quote
Old 08-16-2017, 09:45 AM   #12
Agreed!
One problem I see and have run into is that the payload capacities listed on the internet do not make allowances for options
My truck lists a payload of over 1600 lbs but after subtracting for options my payload is around 1300 lbs ( Payload taken from vehicle sticker) .
Since very few people buy the stripped down version of any vehicle the published numbers are basically useless
The only positive way to know the actual payload is to look at the vehicle sticker and how many people do ?
Old 08-16-2017, 09:52 AM   #13
Raz
Raz's Avatar
Vermont
My 2012 crewcab 4wd Frontier has a cargo capacity of 1268 lbs. Seems odd a Tacoma would be so much less. Any chance this is a 2004 or earlier Tacoma?
Old 08-16-2017, 10:41 AM   #14
Trailer: Sprinter-ing as I shop
Denver, CO
Do you enjoy your toys?
This is intended to inform, not preach.
I bet a lot of us suspect that many tow vehicles are at, or exceed their tow and payload limits.
They may seem to handle pretty normal(ly), in pretty normal conditions.
Problems arise when conditions are more extreme like emergency stops or swerves.
If you are in an accident, count on insurance companies, lawyers, and law enforcement determining whether you were exceeding limits.
If your family was in the other vehicle involved, I bet you would want your lawyer, insurance company and the authorities to do the same thing.
Exceeding limits could place you at some fault, even if you did not cause the accident. Chew on that.
If you enjoy your toys, use them properly. ...ok, a little preachy.
Tom 72 is offline   Reply With Quote
Is 35 amps enough capacity for a charge controller? Ransom Electrical | Charging, Systems, Solar and Generators 44 05-30-2016 04:54 PM
"I am not young enough to know everything" Sid General Chat 12 06-13-2015 04:42 PM
Payload and pickups, interesting facts MC1 Towing, Hitching, Axles and Running Gear 4 09-07-2012 01:18 PM
When is your boat not big enough? Jackie Jokes, Stories & Tall Tales 1 05-14-2006 11:54 PM
I wish you enough.... Legacy Posts Jokes, Stories & Tall Tales 2 08-21-2003 06:47 AM
