u haul axles - Fiberglass RV
Old 01-19-2012, 08:12 AM   #1
Trailer: uhaul, 84, 13CT
Massachusetts
u haul axles
Would anyone know if the axles on u haul ct 13's were standard or do the dimensions change from unit to unit? I have a spare axle, probably shot, and know I could probably get better measurements from the one on the bench compared to sliding around beneath the camper. thanks mike
h.mike is offline   Reply With Quote
Old 01-19-2012, 11:00 AM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I'd be surprised if the axles vary from one unit to another. That said, once you custom order an axle, you own it.
I also noted when I was measuring mine that the distance from the outside of the frame to the inside of the wheel lip is very tight. UHaul used a deeply offset wheel to get around this. If you plan to use a zero offset wheel, make sure that you account for this difference in offset.
I did not replace my axle, but instead am in the process of machining hub adapters to take me from the 4 bolt UHaul / Camaro hub to a standard spindle so that I can add brakes.
Old 01-19-2012, 04:00 PM   #3
Mike: At least it's much easier to experiment with on the bench rather than laying on the cold ground under the trailer. You thinking about adding brakes? Tom has a good idea, but I'm thinking there may be other options although I haven't thought about it much or even looked under the trailer. Bob
Old 01-21-2012, 06:16 AM   #4
Massachusetts
axles
Hi Bob and Mary: Hope you enjoyed your time down south. i'm not really looking to change axles but I do have the spare one we got the spare tire rims from. Thought I'd take some measurements and store them for the future.
Old 01-21-2012, 06:40 AM   #5
Thomas G.'s Avatar
It would be great if you posted your measurements, as this seems to be a recurring question.
Old 01-21-2012, 08:13 AM   #6
Massachusetts
axles
Good thinking, As I type the axle is under snow, but I will post measurements.
Help for tired axles Lyndon Laney Modifications, Alterations and Updates 15 05-08-2014 05:32 AM
al-ko axles Dan B Problem Solving | Owners Helping Owners 2 06-02-2008 10:44 PM
Tandem Axles? Pete Dumbleton Modifications, Alterations and Updates 13 12-22-2006 05:30 PM
Flexiride Axles Benita Care and Feeding of Molded Fiberglass Trailers 3 09-17-2006 03:12 PM
Double Axles Legacy Posts Care and Feeding of Molded Fiberglass Trailers 26 06-15-2003 01:37 PM
