u haul axles - Fiberglass RV
Old 01-19-2012, 09:12 AM   #1
Trailer: uhaul, 84, 13CT
Massachusetts
u haul axles
Would anyone know if the axles on u haul ct 13's were standard or do the dimensions change from unit to unit? I have a spare axle, probably shot, and know I could probably get better measurements from the one on the bench compared to sliding around beneath the camper. thanks mike
h.mike is offline   Reply With Quote
Old 01-19-2012, 12:00 PM   #2
Thomas G.'s Avatar
I'd be surprised if the axles vary from one unit to another. That said, once you custom order an axle, you own it.
I also noted when I was measuring mine that the distance from the outside of the frame to the inside of the wheel lip is very tight. UHaul used a deeply offset wheel to get around this. If you plan to use a zero offset wheel, make sure that you account for this difference in offset.
I did not replace my axle, but instead am in the process of machining hub adapters to take me from the 4 bolt UHaul / Camaro hub to a standard spindle so that I can add brakes.
Old 01-19-2012, 05:00 PM   #3
Mike: At least it's much easier to experiment with on the bench rather than laying on the cold ground under the trailer. You thinking about adding brakes? Tom has a good idea, but I'm thinking there may be other options although I haven't thought about it much or even looked under the trailer. Bob
Old 01-21-2012, 07:16 AM   #4
Massachusetts
axles
Hi Bob and Mary: Hope you enjoyed your time down south. i'm not really looking to change axles but I do have the spare one we got the spare tire rims from. Thought I'd take some measurements and store them for the future.
Old 01-21-2012, 07:40 AM   #5
Thomas G.'s Avatar
It would be great if you posted your measurements, as this seems to be a recurring question.
Old 01-21-2012, 09:13 AM   #6
Massachusetts
axles
Good thinking, As I type the axle is under snow, but I will post measurements.
Help for tired axles Lyndon Laney Modifications, Alterations and Updates 15 05-08-2014 05:32 AM
al-ko axles Dan B Problem Solving | Owners Helping Owners 2 06-02-2008 10:44 PM
Tandem Axles? Pete Dumbleton Modifications, Alterations and Updates 13 12-22-2006 06:30 PM
Flexiride Axles Benita Care and Feeding of Molded Fiberglass Trailers 3 09-17-2006 03:12 PM
Double Axles Legacy Posts Care and Feeding of Molded Fiberglass Trailers 26 06-15-2003 01:37 PM
