uhaul tires? need tire size conversion - Fiberglass RV
Old 04-19-2014, 09:19 AM   #1
Trailer: Hunter I
My tires are Uhaul brand. The tire reads " uhaul not for sale 13x 6.5 6 ply" they are mounted on a 13 inch wheel but when calling tires shops they say they will have to convert the size to modern sizing chart and then never return my call or say that size dosent make sense. Anybody now what size I should be asking for to make their job easy. Just trying to call around and find some in stock but looks like i may have to tow it down to a local shop and have them measure the tire. Anybody deal with this yet?
BuddyLee is offline   Reply With Quote
Old 04-19-2014, 10:46 AM   #2
Trailer: Bigfoot B-17 CB
There are two readily available 13" trailer tire sizes available today. They are;
175-80-13 - 6.88 inches wide and 24 inches diameter
185-80-13 - 7.28 inches wide and 24.65 inches diameter
These measurements are for a new tire. A worn tire would have a smaller diameter. The width is measured an the widest point on the tire (usually the sidewall) with the tire mounted on a wheel and inflated.
If it was me, I would get the biggest ones that would fit and give me decent wheel well clearance. I would use a readily available size so if I'm on a trip and need to get a new tire it would be available.
Old 04-19-2014, 11:06 AM   #3
Trailer: 1984 UHaul CT13
I use these 185/80R13. Greenball Transmaster from Firestone dealer $75 each.
keekers is offline   Reply With Quote
tires, uhaul
Size does matter (with tires) Bob H Towing, Hitching, Axles and Running Gear 21 07-16-2010 12:01 AM
Correct size tires/wheels for 19 ft. Bigfoot pascualito Towing, Hitching, Axles and Running Gear 0 04-20-2010 10:52 AM
What size tires on a 1300? Terry Jones Towing, Hitching, Axles and Running Gear 9 05-24-2009 04:54 PM
13' Scamp Tires - What size? Sheryl M Towing, Hitching, Axles and Running Gear 9 04-27-2009 08:14 PM
Need a UHaul Tire Rim? Kevin A Problem Solving | Owners Helping Owners 1 05-29-2007 06:17 PM
