Water in 7-pin connector - Fiberglass RV
Old 11-06-2015, 11:59 AM   #1
Trailer: 1974 Trillium 13'
Massachusetts
Recently, after a heavy rain, my brake controller box started acting funny. I wasn't towing at the time, but it flashed red at me, as if the trailer was disconnected. Then it did solid red. Green for a while. Couldn't make up its mind. I went back and checked it, and there was a little pool of water inside the plastic tube for the 7-pin plug. It dried out over the course of the day, and was behaving normally several hours later, and worked fine the next time we plugged in the trailer (we checked it was dry before we did that).
My question is: Is this normal? Or is there something wrong with the cap on my connector? And how should I dry it out if this happens when we are about to tow, like if it's rained the night before we break camp?
Thanks for any advice!
SarahC is offline   Reply With Quote
Old 11-06-2015, 12:17 PM   #2
The 7 pin connector on the tow vehicle should have a "weather door" that also acts as a latch when connected. Also the connector could be pointed up towards the rear of tow vehicle slightly. I would have it replaced with a new one. Any RV or trailer shop can do and it's not very expensive.
Old 11-06-2015, 01:09 PM   #3
I would flush out the connector with WD-40. This spray was designed for this purpose. flood the connector with the spray an the water get displaced from the surface and flows out with the excessive fluid. Wipe it dry and your good to go.
Old 11-06-2015, 01:42 PM   #4
Is WD-40 conductive? If it is that would not be a good idea. I've never tested so I really don't know, but before I did put WD-40 in a connector I would want to know.
Old 11-06-2015, 01:52 PM   #5
No its not conductive. it was designed for this purpose. Wd-40 Water Displacing revision 40.
Old days we would drown the ignition on our cars in the rain or road splash. you take wd-40 spray the ignition cap and wires remove the cap and spray out the condensation in the cap and wipe off the excess and reinstall and drive off on your merry way.
Old 11-06-2015, 01:54 PM   #6
Stevebaz isn't absolutely correct. Not conductive and displaces water. I use it inside the distributor cap of our 1974 VW Thing.
Old 11-07-2015, 01:02 PM   #7
It has dielectric properties which means it won't conduct electricity but it won't hinder conductivity. It was developed in the early days of the space program to stop condensation from forming on electronic components of the space ships. Without it the condensation would cause short circuits with catastrophic results. Of course WD-40 has many many great uses.
Lee
Captleemo is offline   Reply With Quote
Old 11-07-2015, 01:47 PM   #8
tractors1's Avatar
Trailer: Escape 21 - Felicity
Fun read on WD40, especially the links at the bottom of this page:
WD-40 History - History and Timeline of WD-40 Company
Charlie Y
7 pin connector on Casita water heater? jon carpenter Problem Solving | Owners Helping Owners 1 08-02-2015 02:05 PM
Yellow wire on 7 pin connector ? Mikeny Towing, Hitching, Axles and Running Gear 2 04-13-2008 01:22 PM
boler 7 pin connector troubles al gilliland Problem Solving | Owners Helping Owners 6 04-24-2007 01:02 PM
7 pin connector Dan Simon Problem Solving | Owners Helping Owners 2 08-05-2006 09:54 PM
Wiring 04 Highlander to 7 pin Bargman connector Gary Little Towing, Hitching, Axles and Running Gear 18 06-02-2006 07:46 PM
