WD Hitch for 16' Scamp with dual LP tanks - Page 3 - Fiberglass RV
Old 07-25-2013, 08:16 AM   #29
chuyler1's Avatar
New Hampshire
I'll do some more reading on it. The principle of the hitch design definitely makes sense but I can easily see how the forces applied by it can increase dramatically if the trailer wants to bounce or the tongue needs to dip to allow changes in elevation between the front wheels of the tow vehicle and the trailer. You might not hear any sounds driving down the highway but pulling into your campsite a loud "pop" of the weakest link, a chain, a bolt, your receiver, could turn into an expensive repair. I suppose the same could be said for any WD hitch but I would feel safer knowing how progressive or linear those urethane bushings are when it comes to flexing and handling road undulations.
chuyler1 is offline   Reply With Quote
Old 07-25-2013, 08:27 AM   #30
Night Sailor's Avatar
Connecticut
From what I've read here, the best way to completely eliminate the possibility of sway is to use a WD hitch and dial up the springs enough to lift the TV rear tires off the ground and the weld everything in place. This provides a long wheel base and nothing moves. <grin>
Seriously, I really enjoyed reading this thread. I'd recommend it to anyone interested in WD hitches. I have been a believer in them since pulling a 6500 lb plus trailer with a K5 Blazer many years ago. I had no issues with sway and did like the positive steering feel it provided.
The Blue Ox system seems impressive and I particularly enjoyed reading the analysis of how it provides sway control. I'll check back to see if any Blue Ox owners provide further updates, insights, etc.
Thanks again to all you contributors.
Old 07-25-2013, 09:35 AM   #31
Trailer: Scamp 16ft
Alabama
I went to a Andersen WD after a few times towing my 16 Deluxe with 2 propane tanks. My TV is a Wangler Unlimited. The good is you adjust the wt distribution with a socket wrench, lower weigh and would fit. I can't say that it is the best I've not used the others. The Andersen was recommended by a local RV shop I go to. If I was towing a 5000 lbs or more trailer I would probably use something else due to issues with damaged couplers and such.
IMHO
Darrell my 1/2 cent
Darrell in Al is offline   Reply With Quote
Old 07-25-2013, 09:39 AM   #32
honda03842's Avatar
Name: Norm and Ginny
Just curious. How many Scamp 16 owners tow with a W/D hitch?
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 07-25-2013, 05:12 PM   #33
Brian B-P's Avatar
Originally Posted by chuyler1 View Post
Excuse my newbie-ness but from my photos posted will this be an issue for me?
That looks like a common lever-latch coupler, so I assume it's not one which is a specific problem, but I don't really know.
Personally, I wouldn't use an Andersen No-Sway with any typical coupler having that little spring-loaded jaw in the back; perhaps a forged Bulldog, or the relatively new Quick-Bite, or just the classic yoke-type such as my Atwood. Even with my Atwood I would be annoyed if the WD system wore out the jaw, because in normal use that never wears out so no replacement part is available - a new coupler would need to be welded on.
Installing larger tanks in Scamp? Jackpine Plumbing | Systems and Fixtures 5 05-28-2013 08:58 PM
Scamp Camp/Fiberglass Propane Tanks melissab General Chat 12 02-24-2011 09:57 PM
Dual propane tanks for uhaul Judith Kennedy Care and Feeding of Molded Fiberglass Trailers 15 09-23-2009 06:44 AM
Dual Hitch Al V General Chat 0 08-20-2008 12:06 PM
2000 Scamp 16' toilet, bunks, a/c, hot h20,dual propane KirkG Classified Archives 2 07-05-2008 06:27 AM
