I am towing with a Honda Odyssey. Fully loaded the trailer weighs 2180 lb. and Honda recommends a weight-distributing hitch once you hit 2,000 lbs. There are four of us in the van and the dip in back/rise in front is borderline. I checked each
axle at the weigh station and I am only 40 lbs. under the maximum allowed on the back
axle. The front
axle, however, can take another 300 lbs. I figured I should try to shift some of that
weight to the front axle and also level out the tow vehicle. My only concern, other than the price of the darn hitch and shank, is that the side-mount crank might interfere with the bars.
Derek
Derek, maybe I missed the post, but what are you towing with? Very few 16' Scamps require a WDH. My 1988 Deluxe weighs unloaded 2150... and tows just fine without a WDH. I have a sway bar, but have never hooked it up. That doesn't mean I won't, I just haven't. I can't imagine needing a WHD.
Any other opinions out there?
