weight distribution hitch - Fiberglass RV
Old 10-12-2013, 11:32 AM   #1
BAMA & Pachyderm Posse's Avatar
Arkansas
Ok ? question is if you use a weight distribution hitch for a front wheel drive , will it adversely effect the surge brake system like the one on Lil Snoozy ? seems to me that it would .
HERSCHEL AKA BAMA
BAMA & Pachyderm Posse is offline   Reply With Quote
Old 10-12-2013, 01:10 PM   #2
Bama from the Curt Hitch website FAQ section:
"Can you use weight distribution on trailers with surge brakes?
No. With Surge Trailer Brakes the deceleration difference between the vehicle and the trailer during braking creates a pressure, which activates the surge trailer brakes. With weight distribution, the vehicle and trailer act as one, causing the Surge Brake System not to function properly."
Old 10-12-2013, 05:10 PM   #3
Arkansas
Originally Posted by carol h View Post
bama from the curt hitch website faq section:
"can you use weight distribution on trailers with surge brakes?
No. With surge trailer brakes the deceleration difference between the vehicle and the trailer during braking creates a pressure, which activates the surge trailer brakes. With weight distribution, the vehicle and trailer act as one, causing the surge brake system not to function properly."
thank you thank you very much
HERSCHEL AKA BAMA
weight
Weight Distribution Hitch lknieper Towing, Hitching, Axles and Running Gear 4 09-27-2013 04:16 PM
Weight Distribution Hitch cpaharley2008 Towing, Hitching, Axles and Running Gear 10 03-20-2013 10:11 PM
Weight distribution hitch Gene Masse Towing, Hitching, Axles and Running Gear 9 05-14-2012 07:05 PM
Weight Distribution Hitch Parker Buckley Towing, Hitching, Axles and Running Gear 4 09-17-2009 09:03 PM
Looking for a Weight Distribution Hitch ROIDON L Towing, Hitching, Axles and Running Gear 2 07-18-2009 10:39 AM
