03-27-2013, 07:36 AM
#41
Originally Posted by Andrew Gibbens
Is there a particular brand of I-beam from a high-rise office building that you can recommend?
My preference is Acme brand, though the Regal-I brand is good, too.
Do the high-rise office buildings not need their I-beams any more, or is this the modern equivalent of stealing lead from church roofs?
Yes, it turns out that like our own appendix, there are certain parts in an office building that were never really necessary. This includes all I beams above the top floor.
03-27-2013, 07:47 AM
#42
Trailer: Class A Motorhome
Not included in the weight math was the weight of a W/D hitch itself vs. a simple drawbar. The w/d hitch and tension bars used with the kids Coleman weighs almost 80 lbs. by itself. Not a biggie on the Yukon Denali, but something to consider on a FreeStar.
03-27-2013, 10:06 AM
#43
Trailer: FunFinder
True enough, Bob, these devices are heavy. A BlueOx weighs 68 pounds for the head, and the bars with chains weigh 12 pounds. From a functional standpoint, when in use, some of that weight is redistributed to the front axle and the trailer axle.
My biggest concern with the Freestar or similar would be as someone else pointed out, making sure the hitch attachment is done correctly.
A guess ( and that is all it is, a "guess" ) would be that the automatic transmission could be a weak point in the system, so having a cooler and regular fluid changes would likely be wise.
03-27-2013, 10:10 AM
#44
That is a valid point Bob. Spread over the 6 axles it would add about 15lbs of weight to each axle. That may or may not be a factor in the overall picture.
Note the Yukon Denali and the Freestar both have a payload capacity of close to 1,500lbs.
03-27-2013, 10:48 AM
#45
Trailer: Egg Camper
So the correct answer is both. You need the airbags to raise the rear suspension in order to make the tow vehicle level again. You also need the weight distribution hitch to restore the weight removed from the front axle by the weight of the trailer pushing down on the hitch.
Also of consideration, especially on a uni body vehicle, expect high twisting load on the hitch from use of WD hitch. Secondary consideration is A frame or front of trailer frame bending from leverage applied by WD hitch.
WD hitches are not designed to restore a sagging rear suspension. They are to restore weight to front/steering axle of tow vehicle.
Airbags, helper springs, overload springs, etc. are designed to add extra weight capacity by effectively stiffening the rear springs. However the confusing terminology does not mean you can carry more, but you restore ride height while staying within manufacturer's rated capacity.
Does that all sound correct?
Jason
PS: Something else I thought of. A vehicle with larger overhang will benefit more from WD hitch than a vehicle with short over hang.
03-27-2013, 10:54 AM
#46
Ya... but....the Denali/Suburban can tow up to 12,000 lbs with a w/d hitch, 6000 lbs without per GMC and that's right on the factory installed hitch.
And, if the FreeStar hitch sets a maximum tongue weight of, say 300 lbs, you should add most of the weight of the hitch into the trailers tongue weight value.
03-27-2013, 11:25 AM
#47
Originally Posted by SilverGhost
So the correct answer is both. You need the airbags to raise the rear suspension in order to make the tow vehicle level again. You also need the weight distribution hitch to restore the weight removed from the front axle by the weight of the trailer pushing down on the hitch...
Jason
Not strictly. Per Reese's set up instructions, the fore-and-aft attitude is adjustable due to the WDH. They suggest measuring the wheel well height before hooking up and then tensioning the WDH until the nose-up attitude comes back down to the original height once hooked up.
03-27-2013, 01:08 PM
#48
Trailer: '98 BURRO 17WB
Delaware
Jason's answer recognizes the elephant in the room and is the correct answer for trailers with light gauge frames and tow vehicles with unibody construction. The captive spring arms can produce huge bending forces on both. Attaching a bionic arm to a 98lb. weakling is the comparison I'd make.
jack
03-27-2013, 01:35 PM
#49
True enough. I suspect more unibodies tow fiberglass trailers than tow stick built behemoths. Makes a point for matching WDH ratings with the tow and trailer.
Even so, there are always going to be problems with generalizations, including the one I'm making now, I suppose.
03-27-2013, 04:36 PM
#50
Trailer: Egg Camper
Originally Posted by Steve L.
Jason
True, the WD hitch is working like a giant pry bar on the tow vehicle. In the process of pushing the front down the rear is lifted. So instead of the rear dropping 2 inches and front rising 1/2 inch, the whole vehicle lowers 1 inch? (Caution, made up numbers for the sake of example)
Sounds like a measurement of the rake (how level the tow vehicle is) before and after would be the most accurate way to setup the WD hitch. And some sort of suspension helper (IE: airbags) to raise the ride height if needed.
I would caution getting too carried away with a WD hitch. A lot of the tow vehicles people are considering on this forum are FWD (or AWD version of FWD base vehicle). As such many are already setup roughly 70/30 weight distributed over the front axle. Trying to level a vehicle solely by pushing the weight back onto front axle risks making the rear axle (of the TUG) too light and compromises safe handling. Reducing the weight carried by the rear axle raises the possibility of jack knifing the whole rig.
Jason
03-27-2013, 04:39 PM
#51
Well, we can continue this thread later after I install my new Andersen w/d hitch ordered today. No bars, but chains instead.
#52
The whole point of a WDH is to put weight back onto the drive wheels, which are the front wheels in most FWD and AWD vehicles.
03-27-2013, 04:50 PM
#53
here is a picture of a bad set up
03-27-2013, 04:51 PM
#54
Trailer: '78 Trillium 4500
That may be the whole point, but it also puts weight back on the trailer -supposedly at the wheels but surely concentrated at the tongue rail.
And as long as we're on the subject:
Though perhaps not in this particular thread, I've seen posts from folks advocating w/d hitches for towing trailers as small or smaller than mine. (2,000 pounds loaded)
Can anyone explain to me the logic behind adding almost a hundred pounds so as to "redistribute" 200 pounds or so of tongue weight????
Francesca
03-27-2013, 04:52 PM
#55
seems counter intuitive doesn't it
03-27-2013, 04:53 PM
#56
the smaller trailers are more subject to sway so perhaps a w/d with sway control set up is really what is meant to be needed.
03-27-2013, 04:56 PM
#57
My WDH and bars weighs 68 lbs.
The vehicle and trailer ride much better. The two times I had to swerve to avoid a collision, the RAV and Toad tracked as one.
I wouldn't go to the trouble of hooking up with it, if it didn't make a significant difference.
baglo
03-27-2013, 06:26 PM
#58
I agree... with any vehicle.
I don't think anything on the road is that extreme, but I agree the FWD vehicles tend to be front heavy. So are most rear-wheel drive vehicles. Among passenger vehicles and light trucks, only sports cars are far off of a 60/40 distribution empty.
Multipurpose vehicles (SUVs, vans...) typically have a rear axle capacity similar to the front: their carrying capacity is mostly at the rear, which matches the location of the passenger and cargo space much closer to the rear axle. In pickup trucks, the rear axle typically has even higher capacity than the front... again, that's where most of the load is supposed to go. I agree that this reality logically leads to caution about trying to carry more load with the front axle.
I agree. I have never seen a plausible recommendation by a qualified source to use a WD system to change the front axle load with the trailer attached to a value any higher than it would be without the trailer.
Since most vehicles suitable for towing start with the rear higher than the front, to allow for substantial load to be added with a rear bias, shifting some load with a WD system may be all that is required to reach a suitable near-level attitude... not the same as without the trailer, but suitable.
03-27-2013, 08:05 PM
#59
Trailer: FunFinder
It is true that every guideline I have read regarding setting up a WD hitch, whether from the hitch company or the vehicle manufacturer specifically states that you must never have the rear of the tow vehicle higher or lighter than it was when unloaded. From what I have seen you would have to really seriously tweak the WD system to get that to happen.
Regarding weight distribution of of an unloaded tow vehicle, just for fun, here are the numbers from the CAT scale for my '06 Nissan Frontier ( 4WD, crewcab, 4.0 V6, manual trans )
Steer 2660 lbs
Drive 2260 lbs
total 4920
55% front, 45% rear.
And again, for what it's worth, the purpose of the WD hitch is not "to level" the tow vehicle. It is to re-distribute load correctly to all axles.
03-27-2013, 10:15 PM
#60
Oh, absolutely! I hope it's obvious to even those who don't understand the basic principles or purpose of WD that it would be bad to use the trailer to lift the back the tug, rather than having the tug carry the trailer tongue.
As WD action is adjusted up, long before the rear axle is underloaded the front axle hits this too-highly-loaded situation:
Steer 2660 lbs
Drive 2260 lbs
total 4920
Good info - thanks!
That's not as front-heavy as I would have guessed; a standard cab would be a little front-heavier.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Weight Distribution Hitch
cpaharley2008 |
10 |
03-20-2013 10:11 PM |
Weight distribution hitch
Gene Masse |
9 |
05-14-2012 07:05 PM |
Parker Buckley |
4 |
09-17-2009 09:03 PM |
Looking for a Weight Distribution Hitch
ROIDON L |
2 |
07-18-2009 10:39 AM |
Is it the right size weight distribution hitch
Jmercuri |
14 |
07-03-2008 07:38 PM |
