weight distribution hitches - Page 2 - Fiberglass RV
Old 07-09-2007, 06:06 AM   #15
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van and 1996 Precision 21' Sailboat
Iowa
And I thought I was confused before . Does this mean yes, or no to a wdh?
cheers
Ian
Ian, what's your point?
In short, it depends. Can you tow safely without it? If you balance your trailer's loading, air up the tires, have the proper amount of tongue weight, and don't exceed your manufacturers recommended tongue, tow, and gross combined vehicle weight ratings... most likely. Will it tow and handle better and more safely with it? If you do all of the aforementioned things, and then add the WDH/sway control... most likely. Very few folks who have towed a rig heavy enough to use WDH/sway control, and have towed it both with and without it will tell you that they preferred the handling of their rig without the WDH/sway control.
MY opinion of my Toyota/Burro rig is that it handled better and the rig was better behaved using the dual-cam setup, even though the Burro never wiggled without it.
Roger
Old 07-09-2007, 08:29 AM   #16
Ian-Vicki's Avatar
Name: Ian or Vicki
Trailer: 17 ft Burro Widebody / 2007 Explorer Sport Trac
Thanks Roger, Brian and Pete and all others who read or weighed in. Sounds like it's a good ideea, even if only from an belt-AND-suspenders point of view. Thanks for all the advice and hopefully we;ll see you on the road soon.
Thanks again.
Cheers
Ian
Ian-Vicki is offline   Reply With Quote
Old 07-09-2007, 02:47 PM   #17
Brian B-P's Avatar
Sure, I can see going for the most complete solution. Now the bad news... all that understanding of axle loads is still required to properly adjust the WD system. On the other hand, adjusting any friction-type sway control component is essentially random.
I second Roger's point: you still need to set the rig up properly, regardless of whether or not you add on devices.
If you get all of the hardware, then take the rig to a weigh scale, you can find out both how to adjust the WD system, and whether you needed it or not in the first place.... now that you have the axle ratings.
By the way, the WD heads are normally quite long (due to the height adjustment which always comes with them), so it will likely place the ball further back than it would need to be without WD, thus increasing load transfer from the truck's front axle to the rear. In other words, the WD hardware will increase the requirement for WD... which makes it easier to later rationalize buying the stuff!
weighing, weight
Weight Distribution Hitch Parker Buckley Towing, Hitching, Axles and Running Gear 4 09-17-2009 09:03 PM
Looking for a Weight Distribution Hitch ROIDON L Towing, Hitching, Axles and Running Gear 2 07-18-2009 10:39 AM
howstuffworks article on weight distribution hitches Ron Stewart Towing, Hitching, Axles and Running Gear 2 07-11-2009 12:16 PM
Weight Distribution kfletcher Towing, Hitching, Axles and Running Gear 1 08-06-2007 07:56 PM
The importance of proper weight distribution Legacy Posts Jokes, Stories & Tall Tales 6 03-21-2003 06:48 AM
