Weight of Bigfoot 5th Wheel? - Fiberglass RV
Old 07-09-2013, 05:01 AM   #1
Trailer: Shopping
I would like to know the stated dry weight of a 5th wheel Bigfoot. If you know and will tell, inform which rear dining configuration to which you refer: ie. U-shape dinette, 2 sofas, sofa & 2 chairs, etc. Thanks from a Wananbe.
nodneralc is offline   Reply With Quote
Old 07-09-2013, 05:44 AM   #2
Trailer: Bigfoot B-17 CB
The 1994 sales literature I have only lists one model. Sofa and 1 chair.
Total dry weight 5480, axle weight 4170. hitch weight 1310.
Check out the sticky "trailer weights in the real world" if you haven't done that already.
The Bigfoot published numbers tend to be much lower than the real truth. The same literature shows my trailer at 2100 dry and when I put it on a scale it was 3400 with very little in the trailer.
Jack L is online now   Reply With Quote
Old 07-09-2013, 01:04 PM   #3
Trailer: Fiber Stream
The following weights are *NOT* dry weights, but fully-loaded-as-their owners-were-towing-them weights:
Originally Posted by Frederick L. Simson View Post
This is a spreadsheet of all of the weigh-in results that I have from the past several years.
Sorted 1st by TOTAL, 2nd by TONGUE, and 3rd by Length
ITEM_LENGTH_MAKE_______MODEL________AXLE__TONGUE__ __TOTAL
108__20_____Bigfoot____5th Wheel____3600____1060_____4660
109__20_____Bigfoot____5th Wheel____3780____1000_____4780
110__20_____Bigfoot____5th Wheel____4420_____640_____5060
(of course on a 5th wheel trailer, the "Tongue" weight is actually the "Pin" weight.)
Old 07-09-2013, 01:41 PM   #4
Brian B-P's Avatar
I'm not a Bigfoot expert, but as I recall there were some variations in the design, more fundamental than interior furnishings. For instance, I think some had tandem axles. Those variations will change the weight significantly.
bigfoot, weight
CO Bigfoot 5th Wheel 22' Priest Referrals: Molded Fiberglass Trailers 3 05-17-2013 06:19 PM
CA Bigfoot 5th Wheel Priest Referrals: Molded Fiberglass Trailers 0 05-11-2013 06:59 PM
Bigfoot 5th wheel Priest Referrals: Molded Fiberglass Trailers 1 05-08-2013 06:17 PM
Weight of Scamp 5th Wheel with Deluxe pkg. Dave J General Chat 16 10-01-2007 03:52 PM
bigfoot 5th wheel Kev&Melis B. Problem Solving | Owners Helping Owners 18 03-19-2007 06:49 PM
