welded vs bolted axle - Page 4 - Fiberglass RV
Old 08-28-2013, 03:58 AM   #43
Raz
Raz's Avatar
Vermont
Originally Posted by Mike Magee View Post
I'm a bit puzzled. (Not hard to puzzle me!) In another thread, someone stated that a torsion axle should not be welded because the welding heat can ruin the rubber inside the axle. But here we are on page 3 of this discussion, and no one has mentioned this issue. What's the deal?
In my old Dexter manual they have a paragraph devoted to warning about damage due to welding on the axle as well as it being the customers problem to remove the welded axle should replacement under warranty be required. I reviewed the current documents at the Dexter site and I can't seem to find it??
Old 08-28-2013, 04:07 AM   #44
frank_a's Avatar
Trailer: 2012 ParkLiner #006
That is a concern about warping due to excessive weld heat, a very common problem with inexperienced welders. I don't know what to tell you about the Dexter manual.
Frank
Old 08-28-2013, 04:51 AM   #45
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Is "excessive" weld heat necessary to carbonize rubber splines inside the axle tube? Is duration of the heat important? Is welding on a flange or bracket appendage equivalent to welding on the tube or housing in the Dexter proscription?
jack
Old 08-28-2013, 08:45 AM   #46
In a rubber suspension axle the factory welds a mounting flange to the axle before the rubber is installed. The customer is welding the mounting flange to the trailer or in the case of a bolt on axle a seperate mounting flange is welded to the trailer and bolting the axle to the trailers flange. In no case is the customer welding directly to the axle causing a heat issue. If your inexperienced welder is causing so much heat to transfer from the axles mounting flange down to the rubber core of the axle you best call the fire department so they can put the egg out.
Old 08-28-2013, 07:54 PM   #47
Trailer: 1980Trillium 1300
...This is what I do when I weld steel/galvanized materials together and I am only an amateur: I only prefer arc(stick) welding due to it's strong bond...When welding a connection of a thinner pipe to a thicker one, I would start @ the thicker pipe and quickly "draw" the weld to thinner material. Always paying attention to thinner and draw the heat away from it in time to not punching it. When welding steel with plastic/rubber materials adjacent to it, I just wrap a soak/wet rag around or before plastic/rubber material to protect it from the heat. I could see steam coming up form this rag and gotto soak it again....Just my work....
Old 08-28-2013, 08:00 PM   #48
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Galvanized really shouldn't be welded at all.
Old 08-28-2013, 08:05 PM   #49
...All galvanized pipes are OK to weld if you are OK with the ...SPARKS. If one is not used to with sparks during welding, he/she could easily get rid off that by grinding/sanding the galvanized layer off the pipe and just weld it....
Old 08-28-2013, 08:22 PM   #50
Jared J's Avatar
Kansas
No, no it's not. You're giving out horribly dangerous advice. Look up metal fume fever, then look up heavy metal poisoning, and paw paw Wilson. The galvanized is not safe, and should not be messed with unless need be, and then, only with some form of breathing protection. You can grind it off first, but that isn't good for you, either.
Old 08-29-2013, 03:14 AM   #51
...Thanks for advice as of manufacturing standards. But like I said, i am no professional and as amateur, he/she would do whatever is available to him/her and this case including the possibility. I just share with my own ptacitcal experiences...Thanks again...
Old 08-29-2013, 05:27 AM   #52
Jared J's Avatar
Kansas
Amateurs die like everybody else, it's not something to take lightly. People have gotten sick and died from galvanized fumes. Death isn't common, but it has happened.
Old 08-29-2013, 07:28 AM   #53
Trailer: 16' Standard
Ohio
You are correct about the fumes from galvanized metal. I welded for many years and experienced fume poisoning, it makes you sick with flue like feelings of hot sweats and cold shakes. The good thing is once you have experienced it you learn not to do it again. Making one or two welds on something galvanized shouldn't be a problem if you don't inhale the fumes. Make sure the fumes are extracted away from your face and out of the area. Now having said all that, as a welder I would rather the axels come bolted on from the factory to make it easier to change if need arise. If the brackets on the frame are squared properly at the factory your alignment becomes a no brainer and any novice could make the change out.
Kenny in Ohio is offline   Reply With Quote
Old 08-29-2013, 09:34 AM   #54
Trailer: 77 Scamp 13
No welding of galvanized without specific protections, think positive pressure mask. In manufacture the zinc coating goes on after the welding. Any fan solution that would remove the fumes will also tend to pull the inert gas envelope from around the welding arc.
The wet rag approach is one I have used to limit the spread of heat. Works fairly well to a point. Don't want to quench a hot weld with water, leads to brittle metal.
It is probably a good time to mention take care in where you place your ground. If you connect ground to location that causes current to run through bearings...bearings don't work all that well after current arcs across all the little gaps.
Don't actually know anyone that has done this to a torsion axle but do know of it being done.
Not sure why galvanized is an issue, are any of these axles or brackets zinc plated?
Old 08-29-2013, 09:50 AM   #55
rabbit's Avatar
Delaware
The undercarriage of the Lil Snoozy appears to be a close relative of boat trailers, including the galvanizing. None of them old enough to require axle replacement, whatever the attachment method.
jack
Old 08-29-2013, 11:37 AM   #56
Trailer: asdf
Alabama
Originally Posted by Jeff Richardson View Post
Here's a picture of Donna's Scamp that I took at the 2011 Spring NOG. Click on the picture to enlarge it.
Jeff
What's the point if Donna's not in the picture!
jwcolby54 is offline   Reply With Quote
axle
Torsion Axle vs. Leaf Spring axle camper1887 Towing, Hitching, Axles and Running Gear 9 10-01-2012 05:32 AM
1982 Burro Frame welded, new coupler installed MikeCM Modifications, Alterations and Updates 2 09-29-2009 07:21 PM
2003 Custom Welded 25ft. Welded Aluminum bonnie w Classified Archives 7 10-28-2008 05:27 PM
Stuff Welded On To Frame Suzanne P. Problem Solving | Owners Helping Owners 21 07-10-2007 07:27 PM
1982 Burro Frame welded, new coupler installed MikeCM Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
