What hitch for 16' Casita or Scamp? - Page 2 - Fiberglass RV
Old 04-18-2019, 10:45 AM   #15
Originally Posted by Lisle View Post
So I just searched for manufacturer recommendations for Casita 16' ball height, which is 17". Scamp 16' ball height is 21". Quite a difference! I guess I can get the electrical wiring now, but will have to wait on the ball. Important to know.
A 17' Casita with 14" tires uses a 19 1/2" height for the top of the ball. The 17' with 15" tires requires a 22" height. This allows for some drop of the rear of the vehicle. The 16' new Casitas use the same height. Maybe old ones were different. But 17" is very low. I just looked this up and multiple people said the same thing.
Old 04-24-2019, 02:11 PM   #16
Trailer: scamp
Indiana
Just got a Highlander Hybrid as my tow vehicle. Need to get a hitch put on it so I can bring home my camper when I find it. Planning to buy a 16' Casita or Scamp hopefully 2010 or newer but may be as old as 2001. What do I need to know to get the right hitch at UHaul? And thanks for all your collective wisdom!
Start by going somewhere besides U haul. High prices for not su good stuff.
computerspook is offline   Reply With Quote
Old 04-24-2019, 02:20 PM   #17
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Try for a genuine Toyota Hitch. It fits into the rear bumper, and doesn't stick out much when the ball mount is out.
Otherwise, a Curtis, or Draw-Tite hitch is good. They will sit lower, and may need a rising ball mount.
Old 04-24-2019, 03:21 PM   #18
Trailer: scamp
Indiana
Sounds like good choices. Just never have been happy with u-haul :-(
Old 04-24-2019, 05:25 PM   #19
U-Haul dealers are independent franchises, so itís hard to generalize. For years I had good service at my local U-Haul. Now a new owner has taken over the franchise, and I havenít tried them out.
Old 04-24-2019, 05:46 PM   #20
True, but U-Haul is primarily in the truck and trailer rental business. I've not used them ( I used a hitch shop ), but my buddy has had to return for U-Haul installations to be corrected ( twice ).
Old 04-24-2019, 06:36 PM   #21
Many U-Haul franchises in small markets like ours do a lot of things besides renting moving equipment. The one I used had a large 3-bay service operation that installed a lot of hitches and wiring. They also sold and repaired fishing boats.
They did two installations for me. Both were quick, correct, and neat. I chose them based on a friendís recommendation. Thatís a good place to start in any location. Find some folks with trailers and ask where they get their work done.
Old 04-24-2019, 07:57 PM   #22
Trailer: Buying one in 2019
Massachusetts
Thanks for all the good advice. I actually got to speak with the guy who does the installs on the phone in advance and he explained the hitch height can be adjusted with a different ball. So when I get my actual camper, if I need a different height, the right ball will cost about $25. However, when he actually was working on my car he decided not to install the electric brake controller. He said it would involve drilling a hole in the dashboard and in the wall between the cabin and engine in order to install it. He didn't want to do that without discussing with me, and I wasn't available at the time. Have other people had to do this much to install an electric brake controller? Ideas about different brands, etc? He mentioned something in his voicemail about the possibility of plugging it into the lighter instead? But then I wouldn't be able to charge my phone or laptop while driving the trailer without disconnecting the trailer brakes? Could use some advice on this. Thanks
Lisle is offline   Reply With Quote
Old 04-24-2019, 08:18 PM   #23
Virginia
Toyota tow package uses a 4 pin connector. Be sure you get the seven pin connector!
M. Bober is offline   Reply With Quote
Old 04-24-2019, 08:24 PM   #24
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Lisle. For sure I'm no expert but that sounds dubious to me. I've never heard that before.
I'd find a way to verify it independently before proceeding.
Walt
Old 04-24-2019, 08:48 PM   #25
Raspy's Avatar
Trailer: 2015 Oliver 23, Ram Cummins
Smith Valley, Nevada
Lisle,
Plugging the controller into the cigarette lighter is ridiculous.
The controller will need a ground (-12 volts), a fuzed hot that turns on with the ignition (+12volts), and a controlled output wire that runs to the 7 pin plug. There will also be a reliable ground wire to the 7 pin from the TV.
Aftermarket controllers are typically screwed to the lower dash area in a place that does not interfere with your knees, is easy to reach for manual brake application and easy to see.
The wiring will most likely go through the firewall and then begin it's route to the rear of the TV. Often, there is a rubber plug that can have a hole punched into it, or the wires can follow other wires through some other grommeted hole.
Old 04-25-2019, 08:56 AM   #26
Massachusetts
That's very helpful. I haven't talked with the guy yet to find out the details. He did install a 7 wire plug and the actual hitch and ball. So that part's good. If it's the brake controller equipment that has to be installed under the dash, that makes sense and I like the idea of running the wire with other wires. I'll call him and see if that's what he meant.
Old 04-26-2019, 03:25 PM   #27
Doctor Harold's Avatar
Trailer: 1975 Scamp, 13-foot
Redding, California
Lisle,
In addition to the correct height stinger for my Scamp, I carry a three ball stinger in my truck for "just in case". Available pretty much anywhere, they have three sizes of balls that will fit pretty much anything you would want to tow, and will get you home in a pinch.
Harbor Freight has them for $32, and a 20% off coupon knocks it down to about $26. https://www.harborfreight.com/triple...tch-64286.html
I have no connection with Harbor Freight.
Good luck in your search for a trailer!
Harold
You cannot have a proud and chivalrous spirit if your conduct is mean and paltry; for whatever a man's actions are, such must be his spirit. --Demosthenes
Doctor Harold is offline   Reply With Quote
Old 04-27-2019, 02:43 PM   #28
Highlander Hybrid Towing
We have a 2006 Scamp 16' that we towed with our '08 Highlander Hybrid and now our 2017. In both cases, I installed the hitch and needed to use a ball mount with a rise to achieve the correct ball height of ~21" for the Scamp 16'. That 21" is to the top of the ball which will be ~2Ĺ" above the mount. For the new car, I measured from the ground to the top of the receiver opening (15"), added 3" for the ball and bought a mount with a 3" rise to reach the required 21". Success.
7 pin installation including 12V supply, a brake controller, and back up lights became more complicated with the 2017 as the car's 12V battery is now in the rear and the back-up lights are in the lift gate. It took a while longer than putting on a hitch.
Lynn
casita, scamp
FS: Scamp Fifth Wheel old style hitch crossmember; ISO: new style Fifth Wheel hitch Stendec Parts: Buy | Sell | Trade 3 02-18-2019 12:42 PM
Scamp 19 In Bed Hitch & Custom Scamp 19 hitch JBjunior Parts: Buy | Sell | Trade 1 07-08-2018 04:26 PM
Scamp 19: Old hitch vs. New Reese Hitch Keith2000 Towing, Hitching, Axles and Running Gear 42 03-20-2018 12:39 PM
"U-Hitch" Rear Hitch Receiver Tim Ryce Modifications, Alterations and Updates 9 03-12-2009 04:05 PM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 04:05 PM
