What kind of tires? - Fiberglass RV
Old 05-19-2003, 09:59 AM   #1
What kind of tires?
Hi Everyone.
I just picked up a 96 13 ft Scamp in great shape. The original tires show some wear and checking so I want to replace them. Do I need a trailer tire? Will automobile tires work? The RV shop where I bought the rig inflated the tires to 50 psi. Is this correct? Seems kind of high to me.
Any and all tire guidance is welcome!
Old 05-19-2003, 10:16 AM   #2
Hi Gerry
I beleive that some of these FG RVs came with car tires.I know the Bolers did.If you can afford it go to Trailer tires.As for air my unit has air posted at 32lbs.Hope this helps.Other folks will chime in with there ideas.
Old 05-19-2003, 05:21 PM   #3
Hi Gerry ... I agree! It sounds like it's time to replace the tires.
What you want to look for are special "ST" trailers ... in your tire size, of course ... but a trailer tire should be branded "ST"... as in ST205-75-14.
When you back or turn a trailer sharply, there is incredible sidewall forces at play ... ST tires have reinforced sidewalls to withstand these pressures ... car tires don't.
Don't take my word for it. Put two fingers on your table, simulating the two trailer tires, then back your "trailer" into a sharp turn, simulating backing into a campsite. One finger will roll in a long arc ... but one finger will slide sideways, as you make your turn. This sideways, twisting force is why you need ST tires.
You can buy them at Walmart or most tire stores.
Old 05-19-2003, 08:39 PM   #4
Trailer Tires
For trailer tires 50 lbs is correct. It will say on your sidewall
of your tire about max pressure. ST's are the way to go - with load
range C if possible. I think load range C is 6 or 8 ply rating.
Much stronger since they take quite a beating as has been pointed
out.
Thanks...
Old 05-20-2003, 09:10 PM   #5
Howdy, I use car tires on my 13 ft. Boler and have no problems at all with handling, etc. There was quite a controversy about this on another website and I called a tire store in Winnipeg that sells only tires and was told that car tires were fine for my application and anyone trying to sell me trailer tires was just doing it to sell me trailer tires. We also used to use a flat deck car trailer to car shows in Minneapolis, Ohio and the Dakotas and also ran it on LT truck tires at maximum pressure without a problem. Also I believe that only time that you would have high side loads on trailer tires is when you have tandem axles, then they scrub when turning while backing up but on a single axle trailer I`ve never noticed any tire scrubbing. Even on a 90 degree jack knife the inner tire just pivots while the outer one rolls. Maybe if using an anti sway and not loosening it off when backing. If scrubbing was such a problem then you should run trailer tires on the front of your car because when you turn your front wheels they always scrub. Also run my tires on the Boler at 36 psi. Benny
Old 05-21-2003, 04:58 AM   #6
Benny is right there has been alot of controversy over car vs trailer tires. But trailer tires were made for trailers and have thicker side walls for a reason.
For our Trill there is a difference in price of about $20 per pair. For that small difference in price why would anyone bother putting car tires on a trailer?
Nancy
Old 05-21-2003, 05:20 AM   #7
What kind of tires?
We had a blowout on the 401 (a very entertaining experience!) just outside of Kitchener on a Sunday, and our choice of places to go for replacements was limited. Wound up at Canadian Tire, and bought a pair of radial (car) tires. They worked OK, but because of the tire profile, our Casita's bottom was a full inch closer to the ground! Not good when the trailer has minimal clearance to begin with! We quickly bought a pair of trailer tires when we got home.
Old 05-21-2003, 05:24 AM   #8
I'm a supporter of ST tires as well. Regular tires (tires with sizes starting with 'P') are not designed to run heavily loaded all their life. That's pretty much a description of our trailer tire's usage. 'ST' tires are designed for long(er) life at full loads. If you can fit a large enough 'P' tire on your trailer, then you might be OK.
Do you know exactly how much your trailer weighs while loaded for a trip? You'd need to know that before choosing a 'P' tire size. A 'P' tire shouldn't be loaded to more than 88% of it's maximum load capacity (per Tire & Rim Assn.) By the time you select an over-sized 'P' tire, you've pretty much lost any cost save.
The ST tire size specified for my trailer seems like the best choice for me.
Everybody gets to do pretty much what they want. Industry guidelines are there to protect the most people the way most of them use their tires most of the time, mostly;). You can do everything right and still have a flat, or other tire issue. I surmise that it's about doing what you can to reasonably reduce risks. (Hey, don't tug on Superman's cape, don't spit into the wind, etc.) Whatever makes you comfortable.
Old 05-21-2003, 09:29 AM   #9
Wow, ask a 'simple' question...
It seems to me that due to the relatively light weight of the 13 ft trailer, the difference between a car tire and a trailer tire would not really be noticed. The 13 ft standard trailer is what, about 1200 pounds dry (The manual with the 1996 says 950..yeah, right), and 1400 - 1600 pounds loaded. But, for the relatively small price difference, I think I'll go with trailer tires.
Thanks for the info.
Old 05-21-2003, 06:44 PM   #10
Trailer vs Car Tires
Hi folks!:wave
I admit I am no expert (it has been 30 years since I sold/installed tires), but I thought I read somewhere that the rubber used in trailer tires is formulated to withstand UV better than car tires. This would make sense, since the tires on trailers typically don't wear out the tread surface, they break down. This, along with the reinforced sidewalls would drive me to only put a trailer tire on my Casita. But then again, I live in the desert, where UV is a real problem.
UV in the northern latitudes, as well as areas of the country that don't have 320+ sunny days a year like we do, may not be such a problem. It is up to the individual to research both the requirements for his/her situation and the products that fill those requirements.
I guess my instructor was correct... you CAN apply systems engineering practices to nearly any situation.
Old 05-21-2003, 10:25 PM   #11
Hi again...Well if I was running a heavier trailer I may consider ST tires but for my purposes the car tires are ideal and I think that the trailer rides somewhat smoother. As I mentioned on the the other web site, a lot of the folks pulling fishing boats over the the crushed rock roads are running car tires because they seem to repel sharp stone penetration and repel bruising better than the ST tires. But whatever suits your fancy.....Benny
Old 05-22-2003, 06:32 AM   #12
Benny, I respectfully disagree with you. I've been around boating all my life. If your boat is bigger than a dingy, you need to put ST trailer tires on the boat trailer.
Walk around any marina and look at the trailers of large sailboats or speed boats. If you find a trailer running on car tires, ask the owner why he's not using ST trailer tires, 99 out of 100 will say "I didn't know there was such a thing as trailer tires!!"
And I really don't know how to react to your "sharp stone" comment ... other than to say I'm glad you used the word "seem" because your statement certainly is not true.
Listen, no sense beating this to death.
If you want to run on car tires, run on car tires. I, however, have always ... and will always ... run on ST trailer tires ... which are designed for use on trailers.
ST tires are not some conspiracy cooked up by the tire companies to get you to part with an extra $10 or $20 ... but if you choose to believe that, then, ok.
Old 05-22-2003, 05:36 PM   #13
What Brand?
What brand of tires? I hear a lot of bad things about Carlisle tires. I've not heard anything bad about any other brand of trailer tires.
My Scamp 16 has the Goodyear trailer tires it had installed by Scamp.
-- Dan Meyer
Old 05-22-2003, 09:14 PM   #14
Hi, Dan. Do a google search for Goodyear Trailer Tire Failure.
You'll find that Carlisles aren't the only tires that have had problems. There's at least one other rv forum where the Goodyears were discussed a year or two ago.
BTW, my '99 Casita also has Goodyears... :wink
tires
P185-80 tires OR ST185-80 Tires ericmarlo Towing, Hitching, Axles and Running Gear 19 12-30-2014 02:14 PM
Tow vehicle with rear tires larger than front tires? Cory Lewis Towing, Hitching, Axles and Running Gear 2 02-15-2010 11:33 PM
One Of A Kind Benita General Chat 11 08-14-2006 03:14 PM
one of a kind Brian Hatfield Jokes, Stories & Tall Tales 16 05-27-2006 12:09 AM
