What lessons have you learned over the years about towing... - Page 4 - Fiberglass RV
Old 05-08-2015, 06:45 PM   #43
Borrego Dave's Avatar
Trailer: Casita SD17 2006
I've had both and like tandems better. The extra cost of tires or bearings are not on the list.
Old 05-08-2015, 07:15 PM   #44
Originally Posted by Cathi View Post
Many want dual axles because, if there is a blowout, you can then travel a few miles to a good place to stop. No need to stop right there. That is a safety feature, in effect.
This is not advised. People who have had a blow-out and not noticed have had the shredded tire beat the living daylights out of the wheel well. Not only do they have to replace the tire, but go to a fiberglass shop and get the trailer repaired.
As for tracking, I have single axle and 17 foot trailer follows me like a puppy ( only it's more focused ).
Old 05-08-2015, 07:15 PM   #45
Towing on Flat Tires???
WOW, unless it was an absolute emergency, or there was a clear and present danger, I would never even consider continuing on with a blown tire on a trailer just because it has dual axles. Here's' my take on that idea:
1. You will be putting twice the load on the remaining tire on that side, putting it at risk for failure. Wouldn't two blown tires just make your day?
2. Continuing to drive may result in a flat tire shredding and doing significant damage to the trailer itself (This I have seen)
3. Continuing to drive may well turn a minor nail puncture repair into a destroyed tire.
4. Although tire failures are rare, most can be attributed to under inflation and/or overage tires. With 4 tires to replace, owners may well tend to push them further to save the expense.
All that said, dual axles sems to mean larger and heavier trailers.
If that's your need, you will get two axles, if not, you will get one, it's really not a matter of choice, but what happens when you choose a specific size trailer.
Or as some would say "It" Happens ,,,lololol......
Old 05-09-2015, 05:01 AM   #46
Trailer: Escape 5.0 TA
W. Mass
I have had both, the only differences I've noticed while driving is that the single can be turned on a dime as opposed to the double. I was used to the quick turning single when backing into a site and thought it a con going to the double. Some believe it's the other way around as the double backs into a site in a more controlled manner. To each his own.
Most common sighted reason for a double getting a flat doesn't leave you on the ground.
I'm under the impression manufactures use 2 axles when a single will not handle the weight. My single axle trailer had a dry weight of 3200 lb and an axle/wheel combo rated (GVWR) of 3500. Left me with a whopping 300 lbs cargo capacity, which of course no one tells you when you're buying it. The dual axle has a dry weight of 3700 lbs and a GVWR of 5500 lbs. While the 2 trailers are pretty close in dry weight the dual axle is too heavy for just one axle. I like the margin between dry and GVWR with the dual axle.
Bob & Deb
padlin00 is offline   Reply With Quote
Old 05-09-2015, 12:12 PM   #47
Trailer: Shopping
You can get 3000 & 7000 lbs axles as standard capacities. Personally I prefer a double axle. More safety factor & stability. Replacing 2 extra tires is expensive, but bearings are cheap. Half the time doing bearings is setup & cleanup. 2 extra bearings don't take that much extra time.
A fighter pilot escort is bouncing around the B52 he's escorting showing off & talking smack about how he can do anything the B52 can. B52 pilot radioed back "Alright, try that". Fighter pilot radios back asking what the heck he did as he couldn't see any thing different. B52 pilot radios back "I just shut down 2 engines". Fighter pilot goes quiet.
Sent from my A0001 using Fiberglass RV mobile app
Fallon is offline   Reply With Quote
Old 05-09-2015, 02:53 PM   #48
honda03842's Avatar
Name: Norm and Ginny
We have a single axle. I would say the primary manufacturer's reason for double axles is to meet the trailer's load capacity, not for dual axle safety.
I am always concerned about safety and we change our tires out early, I suspect earlier than most, usually after 3 years. To insure that we know what's happening on our single axle's tires, we have pressure and temperature sensor's on our tires.
This comes about from an Alaskan experience. We were following a dual axle huge fifth wheel. I saw a rear tire blow. The driver kept driving as though nothing had happened. The fact was she had one severely overloaded tire on one side of the trailer. As well the blown tire was splaying the underside of the trailer. I flashed my lights, tooted my horn for about 10 miles before I managed to get the driver's attention.
Because of that experience I added those temperature and pressure sensors to our trailer hoping to detect a rising temperature or falling pressure before it's an issue. Monitoring that display is Ginny's job though it does have alarms.
We have been a little lucky and have not lost a trailer tire to failure, can't say the same for the tow vehicle.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 05-09-2015, 05:16 PM   #49
MC1
MC1's Avatar
Our 1973, 23' originally was designed as a single axle trailer and the same trailer had the dual axles as an option. One big advantage of the dual axle version is the doubling of the braking power.
Old 05-09-2015, 05:57 PM   #50
Originally Posted by honda03842 View Post
.... To insure that we know what's happening on our single axle's tires, we have pressure and temperature sensor's on our tires....
Now that sounds like a VERY worthwhile addition! When I first got tires with low pressure warning on my car I said I would never go back to un-monitored tires.
Can you provide some details and / or link to the sensors?
Old 05-09-2015, 06:30 PM   #51
honda03842's Avatar
Gordon.
These sensors are better than what we have on our new Honda Odyssey. First they are external to the tire. Second they continuously report so you can see change and third they report temperature and pressure. Our sensors are from Tyre Dog. I suspect they may not be the best technology to buy since what we have is 3 years old. What we bought covers up to four tires, we presently use it only on the trailer's two tires.
I believe I bought them on Amazon or Ebay.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
What lessons have you learned full-timing? CynicalSailor Fulltiming in a Molded Fiberglass Trailer 39 08-05-2015 02:09 PM
Lessons learned Cam A General Chat 14 06-06-2010 10:50 PM
Changes in Casitas over the years? Mac F. Care and Feeding of Molded Fiberglass Trailers 5 07-22-2009 10:52 PM
(Other) Lessons Learned Myron Leski Modifications, Alterations and Updates 22 08-31-2006 12:57 PM
Lessons learned on a hot summer Sunday Legacy Posts General Chat 2 07-21-2003 08:00 AM
